| int | GetSynchronizationMagicNumber () |
| | Returned a hash number that can be used to verify that both client and server side are in synch representation wise for delivery. More...
| vtkDataObject * | GetPiece (vtkPVDataRepresentation *repr, bool low_res, int port=0) |
| | Returns the local data object set by calling SetPiece (or from the cache). More...
| vtkDataObject * | GetDeliveredPiece (vtkPVDataRepresentation *repr, bool low_res, int port=0) |
| | Returns the data object post-delivery. More...
| void | ClearCache (vtkPVDataRepresentation *repr) |
| | Clear all cached data objects for the given representation. More...
| unsigned long | GetVisibleDataSize (bool low_res) |
| | Returns the size for all visible geometry. More...
| bool | NeedsDelivery (vtkMTimeType timestamp, std::vector< unsigned int > &keys_to_deliver, bool use_lod) |
| | Internal method used to determine the list of representations that need their geometry delivered. More...
| void | Deliver (int use_low_res, unsigned int size, unsigned int *keys) |
| | Triggers delivery for the geometries of indicated representations. More...
| virtual int | GetDeliveredDataKey (bool low_res) const |
| | Views that support changing of which ranks do the rendering at runtime based on things like data sizes, etc. More...
| void | SetView (vtkPVView *) |
| | Get/Set the render-view. More...
| vtkPVView * | GetView () const |
| void | RegisterRepresentation (vtkPVDataRepresentation *repr) |
| | View uses these methods to register a representation with the storage. More...
| void | UnRegisterRepresentation (vtkPVDataRepresentation *) |
| vtkPVDataRepresentation * | GetRepresentation (unsigned int) |
| void | SetPiece (vtkPVDataRepresentation *repr, vtkDataObject *data, bool low_res, unsigned long trueSize=0, int port=0) |
| | Representations (indirectly via vtkPVRenderView::SetPiece()) call this method to register the geometry type they are rendering. More...
| bool | HasPiece (vtkPVDataRepresentation *repr, bool low_res=false, int port=0) |
| vtkAlgorithmOutput * | GetProducer (vtkPVDataRepresentation *, bool low_res, int port=0) |
| | Provides access to the producer port for the geometry of a registered representation. More...
| vtkInformation * | GetPieceInformation (vtkPVDataRepresentation *repr, bool low_res, int port=0) |
| | Set/Get meta-data container for the specific piece. More...
| int | GetNumberOfPorts (vtkPVDataRepresentation *repr) |
| | Returns number of known port for the representation. More...
