vtkPVClipDataSet Class Reference
Clip filter. More...
#include <vtkPVClipDataSet.h>
Inheritance diagram for vtkPVClipDataSet:
Collaboration diagram for vtkPVClipDataSet:
typedef vtkTableBasedClipDataSet Superclass
- Public Types inherited from vtkTableBasedClipDataSet
typedef vtkUnstructuredGridAlgorithm Superclass
- Public Types inherited from vtkUnstructuredGridAlgorithm
enum  DesiredOutputPrecision
virtual void SetUseAMRDualClipForAMR (bool)
 This filter uses vtkAMRDualClip for clipping AMR datasets. More...
virtual bool GetUseAMRDualClipForAMR ()
virtual void UseAMRDualClipForAMROn ()
virtual void UseAMRDualClipForAMROff ()
virtual void SetExactBoxClip (bool)
 For a vtkPVBlox implicit function we can do an exact clip of the exterior portion of the box. More...
virtual bool GetExactBoxClip ()
virtual void ExactBoxClipOn ()
virtual void ExactBoxClipOff ()
- Public Member Functions inherited from vtkTableBasedClipDataSet
vtkTableBasedClipDataSetNewInstance () const
vtkMTimeType GetMTime ()
void CreateDefaultLocator ()
vtkUnstructuredGridGetClippedOutput ()
virtual void SetInsideOut (int)
virtual int GetInsideOut ()
virtual void InsideOutOn ()
virtual void InsideOutOff ()
virtual void SetValue (double)
virtual double GetValue ()
virtual void SetUseValueAsOffset (bool)
virtual bool GetUseValueAsOffset ()
virtual void UseValueAsOffsetOn ()
virtual void UseValueAsOffsetOff ()
virtual void SetClipFunction (vtkImplicitFunction *)
virtual vtkImplicitFunctionGetClipFunction ()
virtual void SetGenerateClipScalars (int)
virtual int GetGenerateClipScalars ()
virtual void GenerateClipScalarsOn ()
virtual void GenerateClipScalarsOff ()
void SetLocator (vtkIncrementalPointLocator *locator)
virtual vtkIncrementalPointLocatorGetLocator ()
virtual void SetMergeTolerance (double)
virtual double GetMergeTolerance ()
virtual void SetGenerateClippedOutput (int)
virtual int GetGenerateClippedOutput ()
virtual void GenerateClippedOutputOn ()
virtual void GenerateClippedOutputOff ()
virtual void SetOutputPointsPrecision (int)
virtual int GetOutputPointsPrecision ()
- Public Member Functions inherited from vtkUnstructuredGridAlgorithm
vtkUnstructuredGridAlgorithmNewInstance () const
vtkDataObjectGetInput (int port)
vtkDataObjectGetInput ()
vtkUnstructuredGridGetUnstructuredGridInput (int port)
vtkUnstructuredGridGetOutput ()
vtkUnstructuredGridGetOutput (int)
int HasExecutive ()
vtkExecutiveGetExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
intGetUpdateExtent ()
intGetUpdateExtent (int port)
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkPVClipDataSetSafeDownCast (vtkObject *o)
static vtkPVClipDataSetNew ()
- Static Public Member Functions inherited from vtkTableBasedClipDataSet
static vtkTableBasedClipDataSetSafeDownCast (vtkObjectBase *o)
static vtkTableBasedClipDataSetNew ()
- Static Public Member Functions inherited from vtkUnstructuredGridAlgorithm
static vtkUnstructuredGridAlgorithmNew ()
static vtkUnstructuredGridAlgorithmSafeDownCast (vtkObjectBase *o)
static vtkAlgorithmNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkPVClipDataSet (vtkImplicitFunction *cf=nullptr)
 ~vtkPVClipDataSet () override
int RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override
int FillInputPortInformation (int, vtkInformation *info) override
int FillOutputPortInformation (int, vtkInformation *info) override
int ClipUsingSuperclass (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector)
 Here we instantiate a new filter instead of simply use polymorphism and call the parent RequestData to benefit from the override mechanism (like Viskores variant). More...
int ClipUsingThreshold (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector)
 Delegate process to vtkPVThreshold. More...
- Protected Member Functions inherited from vtkTableBasedClipDataSet
 vtkTableBasedClipDataSet (vtkImplicitFunction *cf=NULL)
 ~vtkTableBasedClipDataSet ()
void InternalProgressCallback (vtkAlgorithm *algorithm)
void ClipDataSet (vtkDataSet *pDataSet, vtkDataArray *clipAray, vtkUnstructuredGrid *unstruct)
void ClipImageData (vtkDataSet *inputGrd, vtkDataArray *clipAray, double isoValue, vtkUnstructuredGrid *outputUG)
void ClipPolyData (vtkDataSet *inputGrd, vtkDataArray *clipAray, double isoValue, vtkUnstructuredGrid *outputUG)
void ClipRectilinearGridData (vtkDataSet *inputGrd, vtkDataArray *clipAray, double isoValue, vtkUnstructuredGrid *outputUG)
void ClipStructuredGridData (vtkDataSet *inputGrd, vtkDataArray *clipAray, double isoValue, vtkUnstructuredGrid *outputUG)
void ClipUnstructuredGridData (vtkDataSet *inputGrd, vtkDataArray *clipAray, double isoValue, vtkUnstructuredGrid *outputUG)
- Protected Member Functions inherited from vtkUnstructuredGridAlgorithm
 vtkUnstructuredGridAlgorithm ()
 ~vtkUnstructuredGridAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
virtual vtkExecutiveCreateDefaultExecutive ()
bool UseAMRDualClipForAMR
bool ExactBoxClip
- Protected Attributes inherited from vtkTableBasedClipDataSet
int InsideOut
int GenerateClipScalars
int GenerateClippedOutput
bool UseValueAsOffset
double Value
double MergeTolerance
vtkCallbackCommandInternalProgressObserver
vtkImplicitFunctionClipFunction
vtkIncrementalPointLocatorLocator
int OutputPointsPrecision
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
- Static Protected Member Functions inherited from vtkTableBasedClipDataSet
static void InternalProgressCallbackFunction (vtkObject *, unsigned long, void *clientdata, void *)
Clip filter.
This is a subclass of vtkTableBasedClipDataSet that allows selection of input scalars.
Definition at line 25 of file vtkPVClipDataSet.h.
Definition at line 28 of file vtkPVClipDataSet.h.
◆ vtkPVClipDataSet()
vtkPVClipDataSet::vtkPVClipDataSet ( vtkImplicitFunction cf = nullptr)
◆ ~vtkPVClipDataSet()
vtkPVClipDataSet::~vtkPVClipDataSet ( )
virtual const char* vtkPVClipDataSet::GetClassName ( )
static int vtkPVClipDataSet::IsTypeOf ( const char *  type)
virtual int vtkPVClipDataSet::IsA ( const char *  type)
Reimplemented from vtkTableBasedClipDataSet.
static vtkPVClipDataSet* vtkPVClipDataSet::SafeDownCast ( vtkObject o)
void vtkPVClipDataSet::PrintSelf ( ostream &  os,
static vtkPVClipDataSet* vtkPVClipDataSet::New ( )
◆ SetUseAMRDualClipForAMR()
virtual void vtkPVClipDataSet::SetUseAMRDualClipForAMR ( bool  )
To disable that behavior, turn this flag off.
◆ GetUseAMRDualClipForAMR()
virtual bool vtkPVClipDataSet::GetUseAMRDualClipForAMR ( )
◆ UseAMRDualClipForAMROn()
virtual void vtkPVClipDataSet::UseAMRDualClipForAMROn ( )
◆ UseAMRDualClipForAMROff()
virtual void vtkPVClipDataSet::UseAMRDualClipForAMROff ( )
◆ SetExactBoxClip()
virtual void vtkPVClipDataSet::SetExactBoxClip ( bool  )
◆ GetExactBoxClip()
virtual bool vtkPVClipDataSet::GetExactBoxClip ( )
◆ ExactBoxClipOn()
virtual void vtkPVClipDataSet::ExactBoxClipOn ( )
◆ ExactBoxClipOff()
virtual void vtkPVClipDataSet::ExactBoxClipOff ( )
◆ RequestData()
int vtkPVClipDataSet::RequestData ( vtkInformation ,
vtkInformationVector **  ,
overrideprotectedvirtual
◆ RequestDataObject()
int vtkPVClipDataSet::RequestDataObject ( vtkInformation ,
◆ FillInputPortInformation()
int vtkPVClipDataSet::FillInputPortInformation ( int  ,
vtkInformation info
◆ FillOutputPortInformation()
int vtkPVClipDataSet::FillOutputPortInformation ( int  ,
vtkInformation info
Reimplemented from vtkUnstructuredGridAlgorithm.
◆ ClipUsingSuperclass()
int vtkPVClipDataSet::ClipUsingSuperclass ( vtkInformation request,
vtkInformationVector outputVector
See also
vtkObjectFactory and vtkObjectFactoryNewMacro.
◆ ClipUsingThreshold()
int vtkPVClipDataSet::ClipUsingThreshold ( vtkInformation request,
bool vtkPVClipDataSet::UseAMRDualClipForAMR
Definition at line 78 of file vtkPVClipDataSet.h.
◆ ExactBoxClip
bool vtkPVClipDataSet::ExactBoxClip
Definition at line 79 of file vtkPVClipDataSet.h.
