Generates a contour surface given one or more cell arrays and a volume fraction value.
| | vtkPVAMRDualContour () |
| | ~vtkPVAMRDualContour () override |
| void | AddInputCellArrayToProcess (const char *name) |
| | Add to list of cell arrays which are used for generating contours. More...
| void | ClearInputCellArrayToProcess () |
| virtual double | GetVolumeFractionSurfaceValue () |
| | Get / Set volume fraction value. More...
| virtual void | SetVolumeFractionSurfaceValue (double) |
| virtual void | SetIsoValue (double) |
| virtual double | GetIsoValue () |
| virtual vtkMultiProcessController * | GetController () |
| virtual void | SetController (vtkMultiProcessController *) |
| virtual void | SetEnableCapping (int) |
| | These are to evaluate performances. More...
| virtual int | GetEnableCapping () |
| virtual void | EnableCappingOn () |
| virtual void | EnableCappingOff () |
| virtual void | SetEnableDegenerateCells (int) |
| virtual int | GetEnableDegenerateCells () |
| virtual void | EnableDegenerateCellsOn () |
| virtual void | EnableDegenerateCellsOff () |
| virtual void | SetEnableMultiProcessCommunication (int) |
| virtual int | GetEnableMultiProcessCommunication () |
| virtual void | EnableMultiProcessCommunicationOn () |
| virtual void | EnableMultiProcessCommunicationOff () |
| virtual void | SetEnableMergePoints (int) |
| | This flag causes blocks to share locators so there are no boundary edges between blocks. More...
| virtual int | GetEnableMergePoints () |
| virtual void | EnableMergePointsOn () |
| virtual void | EnableMergePointsOff () |
| virtual void | SetTriangulateCap (int) |
| | A flag that causes the polygons on the capping surfaces to be triagulated. More...
| virtual int | GetTriangulateCap () |
| virtual void | TriangulateCapOn () |
| virtual void | TriangulateCapOff () |
| virtual void | SetSkipGhostCopy (int) |
| | An option to turn off copying ghost values across process boundaries. More...
| virtual int | GetSkipGhostCopy () |
| virtual void | SkipGhostCopyOn () |
| virtual void | SkipGhostCopyOff () |
| vtkMultiBlockDataSetAlgorithm * | NewInstance () const |
| vtkMultiBlockDataSet * | GetOutput () |
| vtkMultiBlockDataSet * | GetOutput (int) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | SINGLE_PRECISION |
| | DOUBLE_PRECISION |
| | DEFAULT_PRECISION |
| int | AbortExecute |
| | vtkAMRDualContour () |
| | ~vtkAMRDualContour () override |
| void | InitializeRequest (vtkNonOverlappingAMR *input) |
| | This should be called before any number of calls to DoRequestData. More...
| void | FinalizeRequest () |
| | This should be called after any number of calls to DoRequestData. More...
| vtkMultiBlockDataSet * | DoRequestData (vtkNonOverlappingAMR *input, const char *arrayNameToProcess) |
| | Not a pipeline function. More...
| int | FillOutputPortInformation (int port, vtkInformation *info) override |
| void | ShareBlockLocatorWithNeighbors (vtkAMRDualGridHelperBlock *block) |
| void | ProcessBlock (vtkAMRDualGridHelperBlock *block, int blockId, const char *arrayName) |
| void | ProcessDualCell (vtkAMRDualGridHelperBlock *block, int blockId, int x, int y, int z, vtkIdType cornerOffsets[8], vtkDataArray *volumeFractionArray) |
| void | AddCapPolygon (int ptCount, vtkIdType *pointIds, int blockId) |
| void | CapCell (int cellX, int cellY, int cellZ, unsigned char cubeBoundaryBits, int cubeCase, vtkIdType edgePtIds[12], double cornerPoints[32], vtkIdType cornerOffsets[8], int blockId, vtkDataSet *inData) |
| void | InitializeCopyAttributes (vtkNonOverlappingAMR *hbdsInput, vtkDataSet *mesh) |
| void | InterpolateAttributes (vtkDataSet *uGrid, vtkIdType offset0, vtkIdType offset1, double k, vtkDataSet *mesh, vtkIdType outId) |
| void | CopyAttributes (vtkDataSet *uGrid, vtkIdType inId, vtkDataSet *mesh, vtkIdType outId) |
| void | FinalizeCopyAttributes (vtkDataSet *mesh) |
| | vtkMultiBlockDataSetAlgorithm () |
| | ~vtkMultiBlockDataSetAlgorithm () |
| virtual int | RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
| static vtkInformationIntegerKey * | PORT_REQUIREMENTS_FILLED () |
| static vtkExecutive * | DefaultExecutivePrototype |
