| virtual vtkMultiProcessController * | GetController () |
| | Set the communicator object for interprocess communication. More...
| virtual void | SetController (vtkMultiProcessController *) |
| virtual void | SetNP (int) |
| | Specify the number of seeded particles in one dimension (total = np^3) (default 256) More...
| virtual int | GetNP () |
| virtual void | SetRL (float) |
| | Specify the physical box dimensions size (rL) (default 100.0) More...
| virtual float | GetRL () |
| virtual void | SetOverlap (float) |
| | Specify the ghost cell spacing (in rL units) (edge boundary of processor box) (default 5) More...
| virtual float | GetOverlap () |
| virtual void | SetPMin (int) |
| | Specify the minimum number of particles for a halo (pmin) (default 100) More...
| virtual int | GetPMin () |
| virtual void | SetBB (float) |
| | Specify the linking length (bb) (default .2) More...
| virtual float | GetBB () |
| virtual void | SetComputeSOD (int) |
| | Turn on calculation of SOD halos (default off) More...
| virtual int | GetComputeSOD () |
| virtual void | SetCenterFindingMethod (int) |
| | Specify the FOF center to use in SOD calculations (0 = default, center of mass, 1 = average, 2 = MBP, 3 = MCP) More...
| virtual int | GetCenterFindingMethod () |
| virtual void | SetRhoC (float) |
| | Specify rho_c (critical density) (default 2.77536627e11) More...
| virtual float | GetRhoC () |
| virtual void | SetSODMass (float) |
| | Specify the initial SOD mass (default 1.0e14) More...
| virtual float | GetSODMass () |
| virtual void | SetMinRadiusFactor (float) |
| | Specify the minimum radius factor (default 0.5) More...
| virtual float | GetMinRadiusFactor () |
| virtual void | SetMaxRadiusFactor (float) |
| | Specify the maximum radius factor (default 2.0) More...
| virtual float | GetMaxRadiusFactor () |
| virtual void | SetSODBins (int) |
| | Specify the number of bins for SOD finding (default 20) More...
| virtual int | GetSODBins () |
| virtual void | SetMinFOFSize (int) |
| | Specify the minimum FOF size for an SOD halo (default 1000) More...
| virtual int | GetMinFOFSize () |
| virtual void | SetMinFOFMass (float) |
| | Specify the minimum FOF mass for an SOD halo (default 5.0e12) More...
| virtual float | GetMinFOFMass () |
| vtkUnstructuredGridAlgorithm * | NewInstance () const |
| vtkUnstructuredGrid * | GetUnstructuredGridInput (int port) |
| vtkUnstructuredGrid * | GetOutput () |
| vtkUnstructuredGrid * | GetOutput (int) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkPLANLHaloFinder () |
| | ~vtkPLANLHaloFinder () override |
| bool | CheckOutputIntegrity (vtkUnstructuredGrid *outputParticles) |
| | Checks the integrid of the output particles. More...
| void | ComputeFOFHalos (vtkUnstructuredGrid *particles, vtkUnstructuredGrid *haloCenters) |
| | Computes the FOF halos based on the user-supplied linking length and PMin parameters. More...
| void | ComputeSODHalos (vtkUnstructuredGrid *particles, vtkUnstructuredGrid *haloCenters) |
| | Given pre-computed FOF halos, this method computes the SOD halos. More...
| void | VectorizeData (vtkUnstructuredGrid *particles) |
| | Vectorize the data since the halo-finder expects the data as different vectors. More...
| void | ComputeFOFHaloProperties () |
| | Computes FOF halo properties, i.e., fofMass, fofXPos, etc. More...
| void | InitializeHaloCenters (vtkUnstructuredGrid *haloCenters, unsigned int N) |
| | Initializes the haloCenter output (output-2 of the filter) s.t. More...
| void | MarkHaloParticlesAndGetCenter (const unsigned int halo, const int internalHaloIdx, double center[3], vtkUnstructuredGrid *particles) |
| | Marks the halos of the given halo and computes the center using the prescribed center-finding method. More...
| void | ResetHaloFinderInternals () |
| | Resets halo-finder internal data-structures. More...
| void | InitializeSODHaloArrays (vtkUnstructuredGrid *haloCenters) |
| | Initialize the SOD haloArrays. More...
| | vtkUnstructuredGridAlgorithm () |
| | ~vtkUnstructuredGridAlgorithm () |
| virtual int | FillInputPortInformation (int port, vtkInformation *info) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
