vtkNvPipeCompressor Class Reference
#include <vtkNvPipeCompressor.h>
Inheritance diagram for vtkNvPipeCompressor:
Collaboration diagram for vtkNvPipeCompressor:
typedef vtkImageCompressor Superclass
- Public Types inherited from vtkImageCompressor
void SetImageResolution (int img_width, int img_height)
 Communicates the next expected image resolution. More...
virtual void SetQuality (unsigned int)
 Set the quality measure. More...
virtual unsigned int GetQuality ()
virtual int Compress ()
 Call this method to compress the input and generate the compressed data. More...
virtual int Decompress ()
 Decompresses and geenartes the decompressed data as output. More...
virtual void SaveConfiguration (vtkMultiProcessStream *stream)
virtual bool RestoreConfiguration (vtkMultiProcessStream *stream)
virtual const char * SaveConfiguration ()
virtual const char * RestoreConfiguration (const char *stream)
- Public Member Functions inherited from vtkImageCompressor
void SetInput (vtkUnsignedCharArray *input)
 Get/Set the input to this compressor. More...
virtual vtkUnsignedCharArray * GetInput ()
virtual vtkUnsignedCharArray * GetOutput ()
 Get/Set the output of the compressor. More...
void SetOutput (vtkUnsignedCharArray *)
virtual void SetLossLessMode (int)
 When set the implementation must use loss-less compression, otherwise implemnetation should user provided settings. More...
virtual int GetLossLessMode ()
static vtkNvPipeCompressor * New ()
static vtkNvPipeCompressor * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkImageCompressor
static vtkImageCompressor * SafeDownCast (vtkObject *o)
 vtkNvPipeCompressor ()
virtual ~vtkNvPipeCompressor ()
- Protected Member Functions inherited from vtkImageCompressor
virtual void SetConfiguration (const char *)
 vtkImageCompressor ()
 Construct with nullptr input array and empty but allocated output array. More...
 ~vtkImageCompressor () override
unsigned int Quality
- Protected Attributes inherited from vtkImageCompressor
vtkUnsignedCharArray * Output
vtkUnsignedCharArray * Input
int LossLessMode
char * Configuration
Definition at line 21 of file vtkNvPipeCompressor.h.
Definition at line 25 of file vtkNvPipeCompressor.h.
◆ vtkNvPipeCompressor()
vtkNvPipeCompressor::vtkNvPipeCompressor ( )
◆ ~vtkNvPipeCompressor()
virtual vtkNvPipeCompressor::~vtkNvPipeCompressor ( )
protectedvirtual
static vtkNvPipeCompressor* vtkNvPipeCompressor::New ( )
virtual const char* vtkNvPipeCompressor::GetClassName ( )
Reimplemented from vtkImageCompressor.
static int vtkNvPipeCompressor::IsTypeOf ( const char *  type)
virtual int vtkNvPipeCompressor::IsA ( const char *  type)
static vtkNvPipeCompressor* vtkNvPipeCompressor::SafeDownCast ( vtkObject *  o)
void vtkNvPipeCompressor::PrintSelf ( ostream &  os,
◆ SetQuality()
virtual void vtkNvPipeCompressor::SetQuality ( unsigned  int)
The value can be between 1 and 5. 1 means preserve input image quality while 5 emphasizes compression ratio at the expense of image quality.
◆ GetQuality()
virtual unsigned int vtkNvPipeCompressor::GetQuality ( )
◆ Compress()
virtual int vtkNvPipeCompressor::Compress ( )
Implements vtkImageCompressor.
◆ Decompress()
virtual int vtkNvPipeCompressor::Decompress ( )
Input must be compressed data.
◆ SetImageResolution()
void vtkNvPipeCompressor::SetImageResolution ( int  width,
int  height
◆ SaveConfiguration() [1/2]
virtual void vtkNvPipeCompressor::SaveConfiguration ( vtkMultiProcessStream *  stream)
Description: Serialize/Restore compressor configuration (but not the data) into the stream.
◆ RestoreConfiguration() [1/2]
virtual bool vtkNvPipeCompressor::RestoreConfiguration ( vtkMultiProcessStream *  stream)
◆ SaveConfiguration() [2/2]
virtual const char* vtkNvPipeCompressor::SaveConfiguration ( )
◆ RestoreConfiguration() [2/2]
virtual const char* vtkNvPipeCompressor::RestoreConfiguration ( const char *  stream)
◆ Quality
unsigned int vtkNvPipeCompressor::Quality
Definition at line 61 of file vtkNvPipeCompressor.h.
