| void | SelectMaterialArray (const char *name) |
| | Material sellection. More...
| void | UnselectMaterialArray (const char *name) |
| | remove a single array More...
| void | UnselectAllMaterialArrays () |
| | remove all arrays More...
| void | SetMaterialArrayStatus (const char *name, int status) |
| | Enable/disable processing on an array. More...
| int | GetNumberOfMaterialArrays () |
| | Query the number of available arrays. More...
| const char * | GetMaterialArrayName (int index) |
| | Get the name of a specific array. More...
| void | SelectMassArray (const char *name) |
| | Mass sellection. More...
| void | UnselectMassArray (const char *name) |
| void | UnselectAllMassArrays () |
| void | SetMassArrayStatus (const char *name, int status) |
| int | GetNumberOfMassArrays () |
| const char * | GetMassArrayName (int index) |
| void | SelectVolumeWtdAvgArray (const char *name) |
| | Volume weighted average attribute sellection. More...
| void | UnselectVolumeWtdAvgArray (const char *name) |
| void | UnselectAllVolumeWtdAvgArrays () |
| void | SetVolumeWtdAvgArrayStatus (const char *name, int status) |
| int | GetNumberOfVolumeWtdAvgArrays () |
| const char * | GetVolumeWtdAvgArrayName (int index) |
| void | SelectMassWtdAvgArray (const char *name) |
| | Mass weighted average attribute sellection. More...
| void | UnselectMassWtdAvgArray (const char *name) |
| void | UnselectAllMassWtdAvgArrays () |
| void | SetMassWtdAvgArrayStatus (const char *name, int status) |
| int | GetNumberOfMassWtdAvgArrays () |
| const char * | GetMassWtdAvgArrayName (int index) |
| void | SelectSummationArray (const char *name) |
| | Summation attribute sellection. More...
| void | UnselectSummationArray (const char *name) |
| void | UnselectAllSummationArrays () |
| void | SetSummationArrayStatus (const char *name, int status) |
| int | GetNumberOfSummationArrays () |
| const char * | GetSummationArrayName (int index) |
| vtkMTimeType | GetMTime () override |
| | Return the mtime also considering the locator and clip function. More...
| int | GetMaterialArrayStatus (const char *name) |
| | Get enable. More...
| int | GetMaterialArrayStatus (int index) |
| | Get enable. More...
| int | GetMassArrayStatus (const char *name) |
| | Get enable. More...
| int | GetMassArrayStatus (int index) |
| | Get enable. More...
| int | GetVolumeWtdAvgArrayStatus (const char *name) |
| | Get enable. More...
| int | GetVolumeWtdAvgArrayStatus (int index) |
| | Get enable. More...
| int | GetMassWtdAvgArrayStatus (const char *name) |
| | Get enable. More...
| int | GetMassWtdAvgArrayStatus (int index) |
| | Get enable. More...
| int | GetSummationArrayStatus (const char *name) |
| | Get enable. More...
| int | GetSummationArrayStatus (int index) |
| | Get enable. More...
| void | SetMaterialFractionThreshold (double fraction) |
| | Volume Fraction. More...
| virtual double | GetMaterialFractionThreshold () |
| virtual void | SetComputeOBB (bool) |
| | OBB. More...
| virtual bool | GetComputeOBB () |
| | OBB. More...
| void | SetUpperLoadingBound (int nPolys) |
| | Loading. More...
| virtual int | GetUpperLoadingBound () |
| | Loading. More...
| virtual void | SetOutputBaseName (const char *) |
| | Output file. More...
| virtual char * | GetOutputBaseName () |
| virtual void | SetWriteGeometryOutput (bool) |
| | If true, save the results of the filter in a text file. More...
| virtual bool | GetWriteGeometryOutput () |
| virtual void | SetWriteStatisticsOutput (bool) |
| virtual bool | GetWriteStatisticsOutput () |
| virtual void | SetBlockGhostLevel (unsigned char) |
| | Variable used to specify the number of ghost level is available in each block. More...
| virtual unsigned char | GetBlockGhostLevel () |
| void | SetClipFunction (vtkImplicitFunction *clipFunction) |
| | Set the clip function which can be a plane or a sphere. More...
| virtual vtkImplicitFunction * | GetClipFunction () |
| virtual void | SetInvertVolumeFraction (int) |
| | Invert the volume fraction to extract the negative space. More...
| virtual int | GetInvertVolumeFraction () |
| vtkMultiBlockDataSetAlgorithm * | NewInstance () const |
| vtkMultiBlockDataSet * | GetOutput () |
| vtkMultiBlockDataSet * | GetOutput (int) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkMaterialInterfaceFilter () |
| | ~vtkMaterialInterfaceFilter () override |
| int | FillOutputPortInformation (int port, vtkInformation *info) override |
| void | PrepareForPass (vtkNonOverlappingAMR *hbdsInput, std::vector< std::string > &volumeWtdAvgArrayNames, std::vector< std::string > &massWtdAvgArrayNames, std::vector< std::string > &summedArrayNames, std::vector< std::string > &integratedArrayNames) |
| vtkPolyData * | NewFragmentMesh () |
| int | ProcessBlock (int blockId) |
| void | ConnectFragment (vtkMaterialInterfaceFilterRingBuffer *iterator) |
| void | GetNeighborIterator (vtkMaterialInterfaceFilterIterator *next, vtkMaterialInterfaceFilterIterator *iterator, int axis0, int maxFlag0, int axis1, int maxFlag1, int axis2, int maxFlag2) |
| void | GetNeighborIteratorPad (vtkMaterialInterfaceFilterIterator *next, vtkMaterialInterfaceFilterIterator *iterator, int axis0, int maxFlag0, int axis1, int maxFlag1, int axis2, int maxFlag2) |
| void | CreateFace (vtkMaterialInterfaceFilterIterator *in, vtkMaterialInterfaceFilterIterator *out, int axis, int outMaxFlag) |
| int | ComputeDisplacementFactors (vtkMaterialInterfaceFilterIterator *pointNeighborIterators[8], double displacmentFactors[3], int rootNeighborIdx, int faceAxis) |
| int | SubVoxelPositionCorner (double *point, vtkMaterialInterfaceFilterIterator *pointNeighborIterators[8], int rootNeighborIdx, int faceAxis) |
| void | FindPointNeighbors (vtkMaterialInterfaceFilterIterator *iteratorMin0, vtkMaterialInterfaceFilterIterator *iteratorMax0, int axis0, int maxFlag1, int maxFlag2, vtkMaterialInterfaceFilterIterator pointNeighborIterators[8], double pt[3]) |
| int | ComputeOriginAndRootSpacingOld (vtkNonOverlappingAMR *input) |
| void | ComputeOriginAndRootSpacing (vtkNonOverlappingAMR *input) |
| int | GetNumberOfLocalBlocks (vtkNonOverlappingAMR *input) |
| void | ShareGhostBlocks () |
| void | HandleGhostBlockRequests () |
| int | ComputeRequiredGhostExtent (int level, int inExt[6], int outExt[6]) |
| void | ComputeAndDistributeGhostBlocks (int *numBlocksInProc, int *blockMetaData, int myProc, int numProcs) |
| void | AddEquivalence (vtkMaterialInterfaceFilterIterator *neighbor1, vtkMaterialInterfaceFilterIterator *neighbor2) |
| void | PrepareForResolveEquivalences () |
| void | ResolveEquivalences () |
| void | GatherEquivalenceSets (vtkMaterialInterfaceEquivalenceSet *set) |
| void | ShareGhostEquivalences (vtkMaterialInterfaceEquivalenceSet *globalSet, int *procOffsets) |
| void | ReceiveGhostFragmentIds (vtkMaterialInterfaceEquivalenceSet *globalSet, int *procOffset) |
| void | MergeGhostEquivalenceSets (vtkMaterialInterfaceEquivalenceSet *globalSet) |
| int | ResolveIntegratedAttributes (int controllingProcId) |
| int | PrepareToResolveIntegratedAttributes () |
| int | SendIntegratedAttributes (int recipientProcId) |
| int | ReceiveIntegratedAttributes (int sourceProcId) |
| int | PrepareToCollectIntegratedAttributes (std::vector< vtkMaterialInterfaceCommBuffer > &buffers, std::vector< vtkDoubleArray *> &volumes, std::vector< vtkDoubleArray *> &clipDepthMaxs, std::vector< vtkDoubleArray *> &clipDepthMins, std::vector< vtkDoubleArray *> &moments, std::vector< std::vector< vtkDoubleArray *>> &volumeWtdAvgs, std::vector< std::vector< vtkDoubleArray *>> &massWtdAvgs, std::vector< std::vector< vtkDoubleArray *>> &sums) |
| int | CleanUpAfterCollectIntegratedAttributes (std::vector< vtkMaterialInterfaceCommBuffer > &buffers, std::vector< vtkDoubleArray *> &volumes, std::vector< vtkDoubleArray *> &clipDepthMaxs, std::vector< vtkDoubleArray *> &clipDepthMins, std::vector< vtkDoubleArray *> &moments, std::vector< std::vector< vtkDoubleArray *>> &volumeWtdAvgs, std::vector< std::vector< vtkDoubleArray *>> &massWtdAvgs, std::vector< std::vector< vtkDoubleArray *>> &sums) |
| int | CollectIntegratedAttributes (std::vector< vtkMaterialInterfaceCommBuffer > &buffers, std::vector< vtkDoubleArray *> &volumes, std::vector< vtkDoubleArray *> &clipDepthMaxs, std::vector< vtkDoubleArray *> &clipDepthMins, std::vector< vtkDoubleArray *> &moments, std::vector< std::vector< vtkDoubleArray *>> &volumeWtdAvgs, std::vector< std::vector< vtkDoubleArray *>> &massWtdAvgs, std::vector< std::vector< vtkDoubleArray *>> &sums) |
| int | BroadcastIntegratedAttributes (int sourceProcessId) |
| int | SendGeometricAttributes (int controllingProcId) |
| int | PrepareToCollectGeometricAttributes (std::vector< vtkMaterialInterfaceCommBuffer > &buffers, std::vector< vtkDoubleArray *> &coaabb, std::vector< vtkDoubleArray *> &obb, std::vector< int *> &ids) |
| int | CleanUpAfterCollectGeometricAttributes (std::vector< vtkMaterialInterfaceCommBuffer > &buffers, std::vector< vtkDoubleArray *> &coaabb, std::vector< vtkDoubleArray *> &obb, std::vector< int *> &ids) |
| int | CollectGeometricAttributes (std::vector< vtkMaterialInterfaceCommBuffer > &buffers, std::vector< vtkDoubleArray *> &coaabb, std::vector< vtkDoubleArray *> &obb, std::vector< int *> &ids) |
| int | PrepareToMergeGeometricAttributes () |
| int | GatherGeometricAttributes (int recipientProcId) |
| void | ResolveLocalFragmentGeometry () |
| void | ResolveRemoteFragmentGeometry () |
| void | CleanLocalFragmentGeometry () |
| void | BuildLoadingArray (std::vector< vtkIdType > &loadingArray) |
| int | PackLoadingArray (vtkIdType *&buffer) |
| int | UnPackLoadingArray (vtkIdType *buffer, int bufSize, std::vector< vtkIdType > &loadingArray) |
| void | CopyAttributesToOutput0 () |
| void | CopyAttributesToOutput1 () |
| void | CopyAttributesToOutput2 () |
| int | WriteGeometryOutputToTextFile () |
| int | WriteStatisticsOutputToTextFile () |
| int | BuildOutputs (vtkMultiBlockDataSet *mbdsOutput0, vtkMultiBlockDataSet *mbdsOutput1, vtkMultiBlockDataSet *mbdsOutput2, int materialId) |
| int | Accumulate (double *dest, vtkDataArray *src, int nComps, int srcCellIndex, double weight) |
| int | AccumulateMoments (double *moments, vtkDataArray *massArray, int srcCellIndex, double *X) |
| void | ComputeGeometricAttributes () |
| int | ComputeLocalFragmentOBB () |
| int | ComputeLocalFragmentAABBCenters () |
| void | DeleteAllBlocks () |
| int | InitializeBlocks (vtkNonOverlappingAMR *input, std::string &materialFractionArrayName, std::string &massArrayName, std::vector< std::string > &volumeWtdAvgArrayNames, std::vector< std::string > &massWtdAvgArrayNames, std::vector< std::string > &summedArrayNames, std::vector< std::string > &integratedArrayNames) |
| void | AddBlock (vtkMaterialInterfaceFilterBlock *block, unsigned char levelOfGhostLayer) |
| void | CheckLevelsForNeighbors (vtkMaterialInterfaceFilterBlock *block) |
| int | FindFaceNeighbors (unsigned int blockLevel, int blockIndex[3], int faceAxis, int faceMaxFlag, std::vector< vtkMaterialInterfaceFilterBlock *> *result) |
| int | HasNeighbor (unsigned int blockLevel, int blockIndex[3], int neighborDirection[3]) |
| virtual void | SetMaterialFractionArrayName (const char *) |
| void | SaveBlockSurfaces (const char *fileName) |
| void | SaveGhostSurfaces (const char *fileName) |
| void | ComputeFacePoints (vtkMaterialInterfaceFilterIterator *in, vtkMaterialInterfaceFilterIterator *out, int axis, int outMaxFlag) |
| void | ComputeFaceNeighbors (vtkMaterialInterfaceFilterIterator *in, vtkMaterialInterfaceFilterIterator *out, int axis, int outMaxFlag) |
| long | ComputeProximity (const int faceIdx[3], int faceLevel, const int ext[6], int refLevel) |
| void | FindNeighbor (int faceIndex[3], int faceLevel, vtkMaterialInterfaceFilterIterator *neighbor, vtkMaterialInterfaceFilterIterator *reference) |
| | vtkMultiBlockDataSetAlgorithm () |
| | ~vtkMultiBlockDataSetAlgorithm () |
| virtual int | RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
Extract particles and analyse them.
This filter takes a cell data volume fraction and generates a polydata surface. It also performs connectivity on the particles and generates a particle index as part of the cell data of the output. It computes the volume of each particle from the volume fraction.
This will turn on validation and debug i/o of the filter.
#define vtkMaterialInterfaceFilterDEBUG
This will turn on profiling of how long each part of the filter takes
#define vtkMaterialInterfaceFilterPROFILE
- Warning
- : Does not support AMR of vtkRectilinearGrid
Definition at line 60 of file vtkMaterialInterfaceFilter.h.
