| | vtkImplicitArrayTypeMacro (vtkIndexedTypeInt8Array, vtkDataArray) |
| vtkDataArray * | NewInstance () const |
| void | InsertTuple (vtkIdType dstTupleIdx, vtkIdType srcTupleIdx, vtkAbstractArray *source) VTK_OVERRIDE |
| vtkIdType | InsertNextTuple (vtkIdType srcTupleIdx, vtkAbstractArray *source) VTK_OVERRIDE |
| void | InsertTuples (vtkIdList *dstIds, vtkIdList *srcIds, vtkAbstractArray *source) VTK_OVERRIDE |
| void | InsertTuples (vtkIdType dstStart, vtkIdType n, vtkIdType srcStart, vtkAbstractArray *source) VTK_OVERRIDE |
| void | GetTuples (vtkIdList *tupleIds, vtkAbstractArray *output) VTK_OVERRIDE |
| void | GetTuples (vtkIdType p1, vtkIdType p2, vtkAbstractArray *output) VTK_OVERRIDE |
| void | InterpolateTuple (vtkIdType dstTupleIdx, vtkIdList *ptIndices, vtkAbstractArray *source, double *weights) VTK_OVERRIDE |
| void | InterpolateTuple (vtkIdType dstTupleIdx, vtkIdType srcTupleIdx1, vtkAbstractArray *source1, vtkIdType srcTupleIdx2, vtkAbstractArray *source2, double t) VTK_OVERRIDE |
| virtual double * | GetTuple (vtkIdType tupleIdx)=0 |
| virtual void | GetTuple (vtkIdType tupleIdx, double *tuple)=0 |
| void | SetTuple (vtkIdType dstTupleIdx, vtkIdType srcTupleIdx, vtkAbstractArray *source) VTK_OVERRIDE |
| virtual double | GetComponent (vtkIdType tupleIdx, int compIdx) |
| virtual void | SetComponent (vtkIdType tupleIdx, int compIdx, double value) |
| virtual void | InsertComponent (vtkIdType tupleIdx, int compIdx, double value) |
| virtual void | ShallowCopy (vtkDataArray *other) |
| virtual void | FillComponent (int compIdx, double value) |
| virtual void * | WriteVoidPointer (vtkIdType valueIdx, vtkIdType numValues)=0 |
| unsigned long | GetActualMemorySize () VTK_OVERRIDE |
| void | CreateDefaultLookupTable () |
| virtual double | GetMaxNorm () |
| int | CopyInformation (vtkInformation *infoFrom, int deep=1) VTK_OVERRIDE |
| int | GetArrayType () VTK_OVERRIDE |
| int | IsNumeric () VTK_OVERRIDE |
| int | GetElementComponentSize () VTK_OVERRIDE |
| double | GetTuple1 (vtkIdType tupleIdx) |
| double * | GetTuple2 (vtkIdType tupleIdx) |
| double * | GetTuple3 (vtkIdType tupleIdx) |
| double * | GetTuple4 (vtkIdType tupleIdx) |
| double * | GetTuple6 (vtkIdType tupleIdx) |
| double * | GetTuple9 (vtkIdType tupleIdx) |
| virtual void | SetTuple (vtkIdType tupleIdx, const float *tuple) |
| virtual void | SetTuple (vtkIdType tupleIdx, const double *tuple) |
| void | SetTuple1 (vtkIdType tupleIdx, double value) |
| void | SetTuple2 (vtkIdType tupleIdx, double val0, double val1) |
| void | SetTuple3 (vtkIdType tupleIdx, double val0, double val1, double val2) |
| void | SetTuple4 (vtkIdType tupleIdx, double val0, double val1, double val2, double val3) |
| void | SetTuple6 (vtkIdType tupleIdx, double val0, double val1, double val2, double val3, double val4, double val5) |
| void | SetTuple9 (vtkIdType tupleIdx, double val0, double val1, double val2, double val3, double val4, double val5, double val6, double val7, double val8) |
| virtual void | InsertTuple (vtkIdType tupleIdx, const float *tuple)=0 |
| virtual void | InsertTuple (vtkIdType tupleIdx, const double *tuple)=0 |
| void | InsertTuple1 (vtkIdType tupleIdx, double value) |
| void | InsertTuple2 (vtkIdType tupleIdx, double val0, double val1) |
| void | InsertTuple3 (vtkIdType tupleIdx, double val0, double val1, double val2) |
| void | InsertTuple4 (vtkIdType tupleIdx, double val0, double val1, double val2, double val3) |
| void | InsertTuple6 (vtkIdType tupleIdx, double val0, double val1, double val2, double val3, double val4, double val5) |
| void | InsertTuple9 (vtkIdType tupleIdx, double val0, double val1, double val2, double val3, double val4, double val5, double val6, double val7, double val8) |
| virtual vtkIdType | InsertNextTuple (const float *tuple)=0 |
| virtual vtkIdType | InsertNextTuple (const double *tuple)=0 |
| void | InsertNextTuple1 (double value) |
| void | InsertNextTuple2 (double val0, double val1) |
| void | InsertNextTuple3 (double val0, double val1, double val2) |
| void | InsertNextTuple4 (double val0, double val1, double val2, double val3) |
| void | InsertNextTuple6 (double val0, double val1, double val2, double val3, double val4, double val5) |
| void | InsertNextTuple9 (double val0, double val1, double val2, double val3, double val4, double val5, double val6, double val7, double val8) |
| virtual void | RemoveTuple (vtkIdType tupleIdx)=0 |
| virtual void | RemoveFirstTuple () |
| virtual void | RemoveLastTuple () |
| virtual void | GetData (vtkIdType tupleMin, vtkIdType tupleMax, int compMin, int compMax, vtkDoubleArray *data) |
| void | DeepCopy (vtkAbstractArray *aa) VTK_OVERRIDE |
| virtual void | DeepCopy (vtkDataArray *da) |
| virtual void | CopyComponent (int dstComponent, vtkDataArray *src, int srcComponent) |
| void | SetLookupTable (vtkLookupTable *lut) |
| virtual vtkLookupTable * | GetLookupTable () |
| void | GetRange (double range[2], int comp) |
| double * | GetRange (int comp) |
| double * | GetRange () |
| void | GetRange (double range[2]) |
| void | GetDataTypeRange (double range[2]) |
| double | GetDataTypeMin () |
| double | GetDataTypeMax () |
| vtkAbstractArray * | NewInstance () const |
| virtual int | Allocate (vtkIdType numValues, vtkIdType ext=1000)=0 |
| virtual void | Initialize ()=0 |
| virtual int | GetDataType ()=0 |
| void | SetComponentName (vtkIdType component, const char *name) |
| const char * | GetComponentName (vtkIdType component) |
| bool | HasAComponentName () |
| int | CopyComponentNames (vtkAbstractArray *da) |
| virtual void | SetNumberOfTuples (vtkIdType numTuples)=0 |
| virtual void | SetNumberOfValues (vtkIdType numValues) |
| virtual bool | HasStandardMemoryLayout () |
| virtual void * | GetVoidPointer (vtkIdType valueIdx)=0 |
| virtual void | Squeeze ()=0 |
| virtual int | Resize (vtkIdType numTuples)=0 |
| virtual void | ExportToVoidPointer (void *out_ptr) |
| virtual vtkVariant | GetVariantValue (vtkIdType valueIdx) |
| virtual void | InsertVariantValue (vtkIdType valueIdx, vtkVariant value)=0 |
| virtual void | SetVariantValue (vtkIdType valueIdx, vtkVariant value)=0 |
| virtual void | DataChanged ()=0 |
| virtual void | ClearLookup ()=0 |
| vtkInformation * | GetInformation () |
| bool | HasInformation () |
| virtual void | SetNumberOfComponents (int) |
| int | GetNumberOfComponents () |
| vtkIdType | GetNumberOfTuples () |
| vtkIdType | GetNumberOfValues () const |
| void | Reset () |
| vtkIdType | GetSize () |
| vtkIdType | GetMaxId () |
| virtual void | SetVoidArray (void *vtkNotUsed(array), vtkIdType vtkNotUsed(size), int vtkNotUsed(save))=0 |
| virtual void | SetVoidArray (void *array, vtkIdType size, int save, int vtkNotUsed(deleteMethod)) |
| virtual void | SetName (const char *) |
| virtual char * | GetName () |
| virtual const char * | GetDataTypeAsString (void) |
| virtual VTK_NEWINSTANCE vtkArrayIterator * | NewIterator ()=0 |
| virtual vtkIdType | GetDataSize () |
| virtual vtkIdType | LookupValue (vtkVariant value)=0 |
| virtual void | LookupValue (vtkVariant value, vtkIdList *valueIds)=0 |
| virtual void | GetProminentComponentValues (int comp, vtkVariantArray *values, double uncertainty=1.e-6, double minimumProminence=1.e-3) |
| virtual unsigned int | GetMaxDiscreteValues () |
| virtual void | SetMaxDiscreteValues (unsigned int) |
| virtual int | GetDataTypeSize ()=0 |
| void | Reset () |
