| virtual void | SetFractalValue (float) |
| | Essentially the iso surface value. More...
| virtual float | GetFractalValue () |
| virtual void | SetMaximumLevel (int) |
| | Any blocks touching a predefined line will be subdivided to this level. More...
| virtual int | GetMaximumLevel () |
| virtual void | SetDimensions (int) |
| | XYZ dimensions of cells. More...
| virtual int | GetDimensions () |
| virtual void | SetGhostLevels (int) |
| | For testing ghost levels. More...
| virtual int | GetGhostLevels () |
| virtual void | GhostLevelsOn () |
| virtual void | GhostLevelsOff () |
| virtual void | SetTimeStep (int) |
| | Dummy time-step. More...
| virtual int | GetTimeStep () |
| virtual int * | GetTimeStepRange () |
| virtual void | GetTimeStepRange (int &, int &) |
| virtual void | GetTimeStepRange (int [2]) |
| virtual void | SetGenerateRectilinearGrids (int) |
| | Generate either rectilinear grids either uniform grids. More...
| virtual int | GetGenerateRectilinearGrids () |
| virtual void | GenerateRectilinearGridsOn () |
| virtual void | GenerateRectilinearGridsOff () |
| virtual void | SetTwoDimensional (int) |
| | Make a 2D data set to test. More...
| virtual int | GetTwoDimensional () |
| virtual void | TwoDimensionalOn () |
| virtual void | TwoDimensionalOff () |
| virtual void | SetAsymetric (int) |
| | Test the case when the blocks do not have the same sizes. More...
| virtual int | GetAsymetric () |
| virtual void | SetOverlap (int) |
| | Test with lower levels overlapping higher levels. More...
| virtual int | GetOverlap () |
| vtkCompositeDataSetAlgorithm * | NewInstance () const |
| vtkCompositeDataSet * | GetOutput () |
| vtkCompositeDataSet * | GetOutput (int) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkHierarchicalFractal () |
| | ~vtkHierarchicalFractal () override |
| int | RequestDataObject (vtkInformation *req, vtkInformationVector **inV, vtkInformationVector *outV) override |
| int | RequestInformation (vtkInformation *request, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
| | This is called by the superclass. More...
| void | Traverse (int &blockId, int level, vtkCompositeDataSet *output, int x0, int x1, int y0, int y1, int z0, int z1, int onFace[6]) |
| int | LineTest2 (float x0, float y0, float z0, float x1, float y1, float z1, double bds[6]) |
| int | LineTest (float x0, float y0, float z0, float x1, float y1, float z1, double bds[6], int level, int target) |
| void | SetBlockInfo (vtkUniformGrid *grid, int level, int *ext, int onFace[6]) |
| void | SetRBlockInfo (vtkRectilinearGrid *grid, int level, int *ext, int onFace[6]) |
| void | AddVectorArray (vtkCompositeDataSet *output) |
| void | AddTestArray (vtkCompositeDataSet *output) |
| void | AddFractalArray (vtkCompositeDataSet *output) |
| void | AddBlockIdArray (vtkCompositeDataSet *output) |
| void | AddDepthArray (vtkOverlappingAMR *output) |
| void | AddGhostLevelArray (vtkDataSet *grid, int dim[3], int onFace[6]) |
| int | MandelbrotTest (double x, double y) |
| int | TwoDTest (double bds[6], int level, int target) |
| void | CellExtentToBounds (int level, int ext[6], double bds[6]) |
| void | ExecuteRectilinearMandelbrot (vtkRectilinearGrid *grid, double *ptr) |
| double | EvaluateSet (double p[4]) |
| void | GetContinuousIncrements (int extent[6], vtkIdType &incX, vtkIdType &incY, vtkIdType &incZ) |
| virtual void | SetTopLevelSpacing (double, double, double) |
| virtual void | SetTopLevelSpacing (double [3]) |
| virtual double * | GetTopLevelSpacing () |
| virtual void | GetTopLevelSpacing (double &, double &, double &) |
| virtual void | GetTopLevelSpacing (double [3]) |
| virtual void | SetTopLevelOrigin (double, double, double) |
| virtual void | SetTopLevelOrigin (double [3]) |
| virtual double * | GetTopLevelOrigin () |
| virtual void | GetTopLevelOrigin (double &, double &, double &) |
| virtual void | GetTopLevelOrigin (double [3]) |
| void | InternalImageDataCopy (vtkHierarchicalFractal *src) |
| | vtkCompositeDataSetAlgorithm () |
| | ~vtkCompositeDataSetAlgorithm () |
| virtual int | FillInputPortInformation (int port, vtkInformation *info) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
A source to test AMR data object.
vtkHierarchicalFractal is a collection of uniform grids. All have the same dimensions. Each block has a different origin and spacing. It uses mandelbrot to create cell data. I scale the fractal array to look like a volme fraction. I may also add block id and level as extra cell arrays. If GenerateRectilinearGrids is true then this filter outputs vtkHierarchicalBoxDataSet otherwise it generates a vtkMultiBlockDataSet.
Definition at line 30 of file vtkHierarchicalFractal.h.
