| virtual void | SetFileName (std::string) |
| virtual std::string | GetFileName () |
| virtual void | SetDisplayUserName (bool) |
| virtual bool | GetDisplayUserName () |
| virtual void | SetDisplaySystemName (bool) |
| virtual bool | GetDisplaySystemName () |
| virtual void | SetDisplayFileName (bool) |
| virtual bool | GetDisplayFileName () |
| virtual void | SetDisplayFilePath (bool) |
| virtual bool | GetDisplayFilePath () |
| virtual void | SetDisplayDate (bool) |
| virtual bool | GetDisplayDate () |
| vtkTableAlgorithm * | NewInstance () const |
| vtkTable * | GetOutput () |
| vtkTable * | GetOutput (int index) |
| void | SetInputData (vtkDataObject *obj) |
| void | SetInputData (int index, vtkDataObject *obj) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkEnvironmentAnnotationFilter () |
| | ~vtkEnvironmentAnnotationFilter () override |
| | vtkTableAlgorithm () |
| | ~vtkTableAlgorithm () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
filter used to generate text annotation for the current project.
vtkEnvironmentAnnotationFilter is designed to help annotate the scene with frequently needed information.
The variables available in the expression evaluation scope are as follows:
- FileName: the name of the file that the user is working on.
- DisplayFileName: Boolean value representing whether the file name is visible.
- DisplayDate: Boolean value representing whether thedate/time is visible.
- DisplaySystemName: Boolean value representing whether the system type is visible.
- DisplayUserName: Boolean value representing whether the username is visible.
Definition at line 26 of file vtkEnvironmentAnnotationFilter.h.
