| bool | Paint (vtkContext2D *painter) override |
| | Paint event for the item. More...
| bool | Hit (const vtkContextMouseEvent &mouse) override |
| | Returns true if the supplied x, y coordinate is inside the item. More...
| virtual void | SetTextPad (double) |
| virtual double | GetTextPad () |
| vtkBlockItem * | NewInstance () const |
| virtual bool | MouseEnterEvent (const vtkContextMouseEvent &mouse) |
| virtual bool | MouseMoveEvent (const vtkContextMouseEvent &mouse) |
| virtual bool | MouseLeaveEvent (const vtkContextMouseEvent &mouse) |
| virtual bool | MouseButtonPressEvent (const vtkContextMouseEvent &mouse) |
| virtual bool | MouseButtonReleaseEvent (const vtkContextMouseEvent &mouse) |
| virtual void | SetLabel (const vtkStdString &label) |
| virtual vtkStdString | GetLabel () |
| void | SetScalarFunctor (double(*scalarFunction)(double, double)) |
| virtual void | SetDimensions (float, float, float, float) |
| virtual void | SetDimensions (float[4]) |
| virtual float * | GetDimensions () |
| virtual void | GetDimensions (float &, float &, float &, float &) |
| virtual void | GetDimensions (float[4]) |
| vtkContextItem * | NewInstance () const |
| virtual double | GetOpacity () |
| virtual void | SetOpacity (double) |
| vtkAbstractContextItem * | NewInstance () const |
| virtual void | Update () |
| virtual bool | PaintChildren (vtkContext2D *painter) |
| virtual void | ReleaseGraphicsResources () |
| unsigned int | AddItem (vtkAbstractContextItem *item) |
| bool | RemoveItem (vtkAbstractContextItem *item) |
| bool | RemoveItem (unsigned int index) |
| vtkAbstractContextItem * | GetItem (unsigned int index) |
| unsigned int | GetItemIndex (vtkAbstractContextItem *item) |
| unsigned int | GetNumberOfItems () |
| void | ClearItems () |
| unsigned int | Raise (unsigned int index) |
| unsigned int | Lower (unsigned int index) |
| virtual vtkAbstractContextItem * | GetPickedItem (const vtkContextMouseEvent &mouse) |
| virtual bool | MouseDoubleClickEvent (const vtkContextMouseEvent &mouse) |
| virtual bool | MouseWheelEvent (const vtkContextMouseEvent &mouse, int delta) |
| virtual bool | KeyPressEvent (const vtkContextKeyEvent &key) |
| virtual bool | KeyReleaseEvent (const vtkContextKeyEvent &key) |
| virtual void | SetScene (vtkContextScene *scene) |
| virtual void | SetParent (vtkAbstractContextItem *parent) |
| virtual vtkVector2f | MapToParent (const vtkVector2f &point) |
| virtual vtkVector2f | MapFromParent (const vtkVector2f &point) |
| virtual vtkVector2f | MapToScene (const vtkVector2f &point) |
| virtual vtkVector2f | MapFromScene (const vtkVector2f &point) |
| virtual unsigned int | StackAbove (unsigned int index, unsigned int under) |
| virtual unsigned int | StackUnder (unsigned int child, unsigned int above) |
| vtkContextScene * | GetScene () |
| vtkAbstractContextItem * | GetParent () |
| virtual bool | GetVisible () |
| virtual void | SetVisible (bool) |
| virtual bool | GetInteractive () |
| virtual void | SetInteractive (bool) |
a vtkContextItem that draws a block (optional label).
This is a vtkContextItem that can be placed into a vtkContextScene. It draws a block of the given dimensions, and reacts to mouse events.
Definition at line 22 of file vtkChartWarning.h.
