| vtkSynchronizedRenderers * | NewInstance () const |
| void | CollectiveExpandForVisiblePropBounds (double bounds[6]) |
| virtual vtkRenderer * | GetRenderer () |
| virtual void | SetParallelController (vtkMultiProcessController *) |
| virtual vtkMultiProcessController * | GetParallelController () |
| virtual void | SetParallelRendering (bool) |
| virtual bool | GetParallelRendering () |
| virtual void | ParallelRenderingOn () |
| virtual void | ParallelRenderingOff () |
| virtual void | SetImageReductionFactor (int) |
| virtual int | GetImageReductionFactor () |
| virtual void | SetWriteBackImages (bool) |
| virtual bool | GetWriteBackImages () |
| virtual void | WriteBackImagesOn () |
| virtual void | WriteBackImagesOff () |
| virtual void | SetRootProcessId (int) |
| virtual int | GetRootProcessId () |
| virtual void | SetCaptureDelegate (vtkSynchronizedRenderers *) |
| virtual vtkSynchronizedRenderers * | GetCaptureDelegate () |
| virtual void | SetAutomaticEventHandling (bool) |
| virtual bool | GetAutomaticEventHandling () |
| virtual void | AutomaticEventHandlingOn () |
| virtual void | AutomaticEventHandlingOff () |
| | vtkCaveSynchronizedRenderers () |
| | ~vtkCaveSynchronizedRenderers () override=default |
| void | HandleStartRender () override |
| | Called at the start of each render. More...
| void | ProcessCaveConfiguration () |
| | During constructor, processes the configuration file to setup the display information. More...
| void | SetNumberOfDisplays (int numberOfDisplays) |
| | Set the number of displays to be defined, must be called before DefineDisplay. More...
| virtual void | SetEyeSeparation (double) |
| | Set the eye separation which will be used when defined displays. More...
| virtual void | SetUseOffAxisProjection (bool) |
| | Set the use of off axis projection which will be used when defined displays, set to true by default. More...
| bool | DefineDisplay (int idx, double origin[3], double x[3], double y[3]) |
| | Define a display origin, x and y coordinates at index idx. More...
| void | InitializeCamera (vtkCamera *cam) |
| | Initialize the camera for CAVE mode using display information. More...
| void | SetRenderer (vtkRenderer *renderer) override |
| | Override Superclass to compute Displays parameters in case of a single screen cave (e.g. More...
| | vtkSynchronizedRenderers () |
| | ~vtkSynchronizedRenderers () |
| virtual void | HandleEndRender () |
| virtual void | HandleAbortRender () |
| virtual void | MasterStartRender () |
| virtual void | SlaveStartRender () |
| virtual void | MasterEndRender () |
| virtual void | SlaveEndRender () |
| virtual vtkRawImage & | CaptureRenderedImage () |
| virtual void | PushImageToScreen () |
| | vtkObject () |
| | vtkObjectBase () |
vtkSynchronizedRenderers subclass that handles adjusting of camera for cave configurations.
vtkCaveSynchronizedRenderers is vtkSynchronizedRenderers used for in CAVE configuration. It is used on the render-server side. It ensures that the camera is transformed based on the orientations specified in the pvx configuration file. This code was previously in class vtkCaveRenderManager.
In case of a single display, if the cave bounds are not set, we compute these values from vtkDisplayConfiguration::Geometry and the client camera view angle.
Definition at line 30 of file vtkCaveSynchronizedRenderers.h.
