vtkBoundingRectContextDevice2D Class Reference
#include <vtkBoundingRectContextDevice2D.h>
Inheritance diagram for vtkBoundingRectContextDevice2D:
Collaboration diagram for vtkBoundingRectContextDevice2D:
typedef vtkContextDevice2D Superclass
- Public Types inherited from vtkContextDevice2D
enum  TextureProperty
virtual void SetDelegateDevice (vtkContextDevice2D *)
 Set/get delegate device used to compute bounding boxes around strings. More...
virtual vtkContextDevice2DGetDelegateDevice ()
void Reset ()
 Reset the bounding box. More...
vtkRectf GetBoundingRect ()
 Get the bounding rect that contains all the primitives rendered by the device so far. More...
void DrawString (float *point, const vtkStdString &string) override
 Expand bounding box to contain the string's bounding box. More...
void DrawMathTextString (float *point, const vtkStdString &string) override
void DrawImage (float p[2], float scale, vtkImageData *image) override
 Expand bounding box to contain the image's bounding box. More...
void DrawImage (const vtkRectf &pos, vtkImageData *image) override
void DrawPolyData (float vtkNotUsed(p)[2], float vtkNotUsed(scale), vtkPolyData *vtkNotUsed(polyData), vtkUnsignedCharArray *vtkNotUsed(colors), int vtkNotUsed(scalarMode)) override
 Draw the supplied PolyData at the given x, y (p[0], p[1]) (bottom corner), scaled by scale (1.0 would match the actual dataset). More...
void SetColor4 (unsigned char color[4]) override
 Implement pure virtual member function. More...
void SetTexture (vtkImageData *image, int properties) override
void SetPointSize (float size) override
void SetLineWidth (float width) override
void SetLineType (int type) override
void SetMatrix (vtkMatrix3x3 *m) override
 Forward current matrix to delegate device. More...
void GetMatrix (vtkMatrix3x3 *m) override
 Get current matrix from delegate device. More...
void MultiplyMatrix (vtkMatrix3x3 *m) override
 Multiply the current matrix in the delegate device by this one. More...
void PushMatrix () override
 Push matrix in the delegate device. More...
void PopMatrix () override
 Pope matrix from the delegate device. More...
void EnableClipping (bool enable) override
void SetClipping (int *x) override
void ApplyPen (vtkPen *pen) override
 Forward the pen to the delegate device. More...
vtkPenGetPen () override
 Get the pen from the delegate device. More...
void ApplyBrush (vtkBrush *brush) override
 Forward the brush to the delegate device. More...
vtkBrushGetBrush () override
 Get the brush from the delegate device. More...
void ApplyTextProp (vtkTextProperty *prop) override
 Forward the text property to the delegate device. More...
vtkTextPropertyGetTextProp () override
 Get the text property from the delegate device. More...
void DrawPoly (float *points, int n, unsigned char *colors=nullptr, int nc_comps=0) override
 Expand bounding box to contain the given polygon. More...
void DrawLines (float *f, int n, unsigned char *colors=nullptr, int nc_comps=0) override
 Expand bounding rect to contain the given lines. More...
void DrawPoints (float *points, int n, unsigned char *colors=nullptr, int nc_comps=0) override
 Expand bounding rect to contain the given points. More...
void DrawPointSprites (vtkImageData *sprite, float *points, int n, unsigned char *colors=nullptr, int nc_comps=0) override
 Expand bounding rect to contain the point sprites. More...
void DrawMarkers (int shape, bool highlight, float *points, int n, unsigned char *colors=nullptr, int nc_comps=0) override
 Expand bounding rect to contain the markers. More...
void DrawEllipseWedge (float x, float y, float outRx, float outRy, float inRx, float inRy, float startAngle, float stopAngle) override
 Expand bounding rect to contain the ellipse. More...
void DrawEllipticArc (float x, float y, float rX, float rY, float startAngle, float stopAngle) override
 Expand bounding rect to contain the elliptic arc. More...
void ComputeStringBounds (const vtkStdString &string, float bounds[4]) override
 Forward string bounds calculation to the delegate device. More...
void ComputeJustifiedStringBounds (const char *string, float bounds[4]) override
void Begin (vtkViewport *) override
 Call before drawing to this device. More...
void End () override
 Call after drawing to this device. More...
bool GetBufferIdMode () const override
 Get value from delegate device. More...
void BufferIdModeBegin (vtkAbstractContextBufferId *bufferId) override
 Begin ID buffering mode. More...
void BufferIdModeEnd () override
 End ID buffering mode. More...
- Public Member Functions inherited from vtkContextDevice2D
vtkContextDevice2DNewInstance () const
virtual void DrawQuad (float *, int)
virtual void DrawQuadStrip (float *, int)
virtual void DrawPolygon (float *, int)
virtual void DrawString (float *point, const vtkUnicodeString &string)=0
virtual bool MathTextIsSupported ()
virtual int GetWidth ()
virtual int GetHeight ()
virtual void DisableClipping ()
virtual void SetViewportSize (const vtkVector2i &size)
virtual vtkVector2i GetViewportSize ()
virtual void SetViewportRect (const vtkRecti &rect)
virtual vtkRecti GetViewportRect ()
virtual void ComputeStringBounds (const vtkUnicodeString &string, float bounds[4])=0
static vtkBoundingRectContextDevice2DSafeDownCast (vtkObject *o)
static vtkBoundingRectContextDevice2DNew ()
static vtkRectf GetBoundingRect (vtkAbstractContextItem *item, vtkViewport *viewport)
 Get the bounding rect that contains the given vtkAbstractContextItem. More...
- Static Public Member Functions inherited from vtkContextDevice2D
static vtkContextDevice2DSafeDownCast (vtkObjectBase *o)
static vtkContextDevice2DNew ()
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkBoundingRectContextDevice2D ()
 ~vtkBoundingRectContextDevice2D () override
void AddPoint (float x, float y)
 Add a point to the cumulative bounding rect. More...
void AddPoint (float point[2])
void AddRect (const vtkRectf &rect)
 Add a rect to the cumulative bounding rect. More...
- Protected Member Functions inherited from vtkContextDevice2D
 vtkContextDevice2D ()
 ~vtkContextDevice2D ()
bool Initialized
 Is the bounding rect initialized? More...
vtkRectf BoundingRect
 Cumulative rect holding the bounds of the primitives rendered by the device. More...
vtkContextDevice2DDelegateDevice
 Delegate ContextDevice2D to handle certain computations. More...
- Protected Attributes inherited from vtkContextDevice2D
int Geometry [2]
vtkVector2i ViewportSize
vtkRecti ViewportRect
vtkAbstractContextBufferIdBufferId
vtkPenPen
vtkBrushBrush
vtkTextPropertyTextProp
- Public Attributes inherited from vtkContextDevice2D
 Nearest
 Linear
 Stretch
 Repeat
Definition at line 45 of file vtkBoundingRectContextDevice2D.h.
Definition at line 48 of file vtkBoundingRectContextDevice2D.h.
◆ vtkBoundingRectContextDevice2D()
vtkBoundingRectContextDevice2D::vtkBoundingRectContextDevice2D ( )
◆ ~vtkBoundingRectContextDevice2D()
vtkBoundingRectContextDevice2D::~vtkBoundingRectContextDevice2D ( )
virtual const char* vtkBoundingRectContextDevice2D::GetClassName ( )
static int vtkBoundingRectContextDevice2D::IsTypeOf ( const char *  type)
virtual int vtkBoundingRectContextDevice2D::IsA ( const char *  type)
Reimplemented from vtkContextDevice2D.
static vtkBoundingRectContextDevice2D* vtkBoundingRectContextDevice2D::SafeDownCast ( vtkObject o)
void vtkBoundingRectContextDevice2D::PrintSelf ( ostream &  os,
static vtkBoundingRectContextDevice2D* vtkBoundingRectContextDevice2D::New ( )
◆ SetDelegateDevice()
virtual void vtkBoundingRectContextDevice2D::SetDelegateDevice ( vtkContextDevice2D )
◆ GetDelegateDevice()
virtual vtkContextDevice2D* vtkBoundingRectContextDevice2D::GetDelegateDevice ( )
◆ Reset()
void vtkBoundingRectContextDevice2D::Reset ( )
◆ GetBoundingRect() [1/2]
static vtkRectf vtkBoundingRectContextDevice2D::GetBoundingRect ( vtkAbstractContextItem item,
vtkViewport viewport
◆ GetBoundingRect() [2/2]
vtkRectf vtkBoundingRectContextDevice2D::GetBoundingRect ( )
◆ DrawString()
void vtkBoundingRectContextDevice2D::DrawString ( float point,
const vtkStdString string
Implements vtkContextDevice2D.
◆ DrawMathTextString()
void vtkBoundingRectContextDevice2D::DrawMathTextString ( float point,
◆ DrawImage() [1/2]
void vtkBoundingRectContextDevice2D::DrawImage ( float  p[2],
float  scale,
vtkImageData image
◆ DrawImage() [2/2]
void vtkBoundingRectContextDevice2D::DrawImage ( const vtkRectf pos,
vtkImageData image
◆ DrawPolyData()
void vtkBoundingRectContextDevice2D::DrawPolyData ( float   vtkNotUsed(p)[2],
float   vtkNotUsedscale,
vtkPolyData vtkNotUsedpolyData,
vtkUnsignedCharArray vtkNotUsedcolors,
int   vtkNotUsedscalarMode
inlineoverride
Warning
Not currently implemented.
Definition at line 99 of file vtkBoundingRectContextDevice2D.h.
◆ SetColor4()
void vtkBoundingRectContextDevice2D::SetColor4 ( unsigned char  color[4])
Does not affect bounding rect.
◆ SetTexture()
void vtkBoundingRectContextDevice2D::SetTexture ( vtkImageData image,
int  properties
◆ SetPointSize()
void vtkBoundingRectContextDevice2D::SetPointSize ( float  size)
◆ SetLineWidth()
void vtkBoundingRectContextDevice2D::SetLineWidth ( float  width)
Forward line width to delegate device.
◆ SetLineType()
void vtkBoundingRectContextDevice2D::SetLineType ( int  type)
Forward line type to delegate device.
◆ SetMatrix()
void vtkBoundingRectContextDevice2D::SetMatrix ( vtkMatrix3x3 m)
◆ GetMatrix()
void vtkBoundingRectContextDevice2D::GetMatrix ( vtkMatrix3x3 m)
◆ MultiplyMatrix()
void vtkBoundingRectContextDevice2D::MultiplyMatrix ( vtkMatrix3x3 m)
◆ PushMatrix()
void vtkBoundingRectContextDevice2D::PushMatrix ( )
◆ PopMatrix()
void vtkBoundingRectContextDevice2D::PopMatrix ( )
◆ EnableClipping()
void vtkBoundingRectContextDevice2D::EnableClipping ( bool  enable)
Does nothing.
◆ SetClipping()
void vtkBoundingRectContextDevice2D::SetClipping ( int x)
Does nothing.
◆ ApplyPen()
void vtkBoundingRectContextDevice2D::ApplyPen ( vtkPen pen)
◆ GetPen()
vtkPen* vtkBoundingRectContextDevice2D::GetPen ( )
◆ ApplyBrush()
void vtkBoundingRectContextDevice2D::ApplyBrush ( vtkBrush brush)
◆ GetBrush()
vtkBrush* vtkBoundingRectContextDevice2D::GetBrush ( )
◆ ApplyTextProp()
void vtkBoundingRectContextDevice2D::ApplyTextProp ( vtkTextProperty prop)
◆ GetTextProp()
vtkTextProperty* vtkBoundingRectContextDevice2D::GetTextProp ( )
◆ DrawPoly()
void vtkBoundingRectContextDevice2D::DrawPoly ( float points,
int  n,
unsigned char *  colors = nullptr,
int  nc_comps = 0
◆ DrawLines()
void vtkBoundingRectContextDevice2D::DrawLines ( float f,
int  n,
int  nc_comps = 0
◆ DrawPoints()
void vtkBoundingRectContextDevice2D::DrawPoints ( float points,
int  n,
int  nc_comps = 0
◆ DrawPointSprites()
void vtkBoundingRectContextDevice2D::DrawPointSprites ( vtkImageData sprite,
float points,
int  n,
int  nc_comps = 0
◆ DrawMarkers()
void vtkBoundingRectContextDevice2D::DrawMarkers ( int  shape,
bool  highlight,
float points,
int  n,
int  nc_comps = 0
◆ DrawEllipseWedge()
void vtkBoundingRectContextDevice2D::DrawEllipseWedge ( float  x,
float  y,
float  outRx,
float  outRy,
float  inRx,
float  inRy,
float  startAngle,
float  stopAngle
◆ DrawEllipticArc()
void vtkBoundingRectContextDevice2D::DrawEllipticArc ( float  x,
float  y,
float  rX,
float  rY,
float  startAngle,
float  stopAngle
◆ ComputeStringBounds()
void vtkBoundingRectContextDevice2D::ComputeStringBounds ( const vtkStdString string,
float  bounds[4]
◆ ComputeJustifiedStringBounds()
void vtkBoundingRectContextDevice2D::ComputeJustifiedStringBounds ( const char *  string,
float  bounds[4]
◆ Begin()
void vtkBoundingRectContextDevice2D::Begin ( vtkViewport )
◆ End()
void vtkBoundingRectContextDevice2D::End ( )
◆ GetBufferIdMode()
bool vtkBoundingRectContextDevice2D::GetBufferIdMode ( ) const
◆ BufferIdModeBegin()
void vtkBoundingRectContextDevice2D::BufferIdModeBegin ( vtkAbstractContextBufferId bufferId)
◆ BufferIdModeEnd()
void vtkBoundingRectContextDevice2D::BufferIdModeEnd ( )
◆ AddPoint() [1/2]
void vtkBoundingRectContextDevice2D::AddPoint ( float  x,
float  y
◆ AddPoint() [2/2]
void vtkBoundingRectContextDevice2D::AddPoint ( float  point[2])
◆ AddRect()
void vtkBoundingRectContextDevice2D::AddRect ( const vtkRectf rect)
◆ Initialized
bool vtkBoundingRectContextDevice2D::Initialized
Definition at line 281 of file vtkBoundingRectContextDevice2D.h.
◆ BoundingRect
vtkRectf vtkBoundingRectContextDevice2D::BoundingRect
Definition at line 286 of file vtkBoundingRectContextDevice2D.h.
◆ DelegateDevice
vtkContextDevice2D* vtkBoundingRectContextDevice2D::DelegateDevice
Definition at line 291 of file vtkBoundingRectContextDevice2D.h.
