| virtual void | SetRefinementMode (int) |
| | Get/Set how the output refinement is to be determined. More...
| virtual int | GetRefinementMode () |
| virtual void | SetCenter (double, double, double) |
| | Get/Set the center for the plane. More...
| virtual void | SetCenter (double [3]) |
| virtual double * | GetCenter () |
| virtual void | GetCenter (double &, double &, double &) |
| virtual void | GetCenter (double [3]) |
| virtual void | SetNormal (double, double, double) |
| | Get/Set the normal for the plane. More...
| virtual void | SetNormal (double [3]) |
| virtual double * | GetNormal () |
| virtual void | GetNormal (double &, double &, double &) |
| virtual void | GetNormal (double [3]) |
| virtual void | SetBoundingBox (double, double, double, double, double, double) |
| | Get/Set the bounding box for the plane. More...
| virtual void | SetBoundingBox (double [6]) |
| virtual double * | GetBoundingBox () |
| virtual void | GetBoundingBox (double &, double &, double &, double &, double &, double &) |
| virtual void | GetBoundingBox (double [6]) |
| virtual void | SetResolution (int) |
| | Specify the resolution of the plane. More...
| virtual int | GetResolution () |
| virtual void | SetCellSize (double) |
| | Specify the cell-size of the plane. More...
| virtual double | GetCellSize () |
| virtual void | SetPadding (double) |
| | Specify the padding to use along each of the directions. More...
| virtual double | GetPadding () |
| vtkPolyDataAlgorithm * | NewInstance () const |
| vtkPolyData * | GetPolyDataInput (int port) |
| vtkPolyData * | GetOutput () |
| vtkPolyData * | GetOutput (int) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkBoundedPlaneSource () |
| | ~vtkBoundedPlaneSource () override |
| | vtkPolyDataAlgorithm () |
| | ~vtkPolyDataAlgorithm () |
| virtual int | FillInputPortInformation (int port, vtkInformation *info) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
