| void | SetSelectionConnection (vtkAlgorithmOutput *algOutput) |
| | Convenience method to specify the selection connection (2nd input port) More...
| void | RemoveAllSelectionsInputs () |
| | Removes all inputs from input port 1. More...
| void | ResetLabels () |
| | Get/Set the label to display the input. More...
| void | SetLabels (int index, const char *label) |
| | vtkSetStdStringFromCharMacro (DefaultLabel) |
| | Set/Get the default label used for data that isn't labelized by a selection. More...
| | vtkGetCharFromStdStringMacro (DefaultLabel) |
| vtkDataSetAlgorithm * | NewInstance () const |
| vtkDataSet * | GetOutput () |
| vtkDataSet * | GetOutput (int) |
| void | SetInputData (vtkDataSet *) |
| void | SetInputData (int, vtkDataSet *) |
| void | AddInputData (vtkDataSet *) |
| void | AddInputData (int, vtkDataSet *) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkAnnotateSelectionFilter () |
| | ~vtkAnnotateSelectionFilter () override=default |
| | vtkDataSetAlgorithm () |
| | ~vtkDataSetAlgorithm () |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
filter for annotating selection
vtkAnnotateSelectionFilter is a filter that can be used to generate a string array based on a selection.
The input selection is split for each selection node, we should specify the same number of selection node than the number of label.
Definition at line 20 of file vtkAnnotateSelectionFilter.h.
