vtkANARIHidingDecorator Class Reference
vtkANARIHidingDecorator's purpose is to prevent the GUI from showing any of the ANARI specific rendering controls when Paraview is not configured with PARAVIEW_ENABLE_ANARI More...
#include <vtkANARIHidingDecorator.h>
Inheritance diagram for vtkANARIHidingDecorator:
Collaboration diagram for vtkANARIHidingDecorator:
typedef vtkPropertyDecorator Superclass
- Public Types inherited from vtkPropertyDecorator
enum  { VisibilityChangedEvent = vtkCommand::UserEvent + 1000, EnableStateChangedEvent = vtkCommand::UserEvent + 1001 }
 This event is fired whenever the decorator has determined that the panel may need a refresh since the state of the system has changed which would deem changes in the widget visibility or enable state. More...
bool CanShow (bool showAdvanced) const override
 Overridden to hide the widget when ANARI is not compiled in. More...
- Public Member Functions inherited from vtkPropertyDecorator
virtual void Initialize (vtkPVXMLElement *xml, vtkSMProxy *proxy)
 Constructor. More...
virtual bool CanShow (bool vtkNotUsed(showAdvanced)) const
 Override this method to override the visibility of the widget in the panel. More...
virtual bool Enable () const
 Override this method to override the enable state of the widget in the panel. More...
static vtkANARIHidingDecoratorNew ()
static vtkANARIHidingDecoratorSafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkPropertyDecorator
static vtkPropertyDecoratorNew ()
static vtkPropertyDecoratorSafeDownCast (vtkObject *o)
static vtkSmartPointer< vtkPropertyDecoratorCreate (vtkPVXMLElement *xml, vtkSMProxy *proxy)
 Creates a new decorator, given the xml config and the proxy containing the property For unsupported/unknown, implementations should simply return nullptr without raising any errors (or messages). More...
static vtkObjectNew ()
static vtkObjectBaseNew ()
 vtkANARIHidingDecorator ()=default
 ~vtkANARIHidingDecorator () override=default
 vtkANARIHidingDecorator (const vtkANARIHidingDecorator &)=delete
- Protected Member Functions inherited from vtkPropertyDecorator
 vtkPropertyDecorator ()
 ~vtkPropertyDecorator () override
vtkPVXMLElementXML () const
vtkSMProxyProxy () const
void InvokeVisibilityChangedEvent ()
void InvokeEnableStateChangedEvent ()
Definition at line 13 of file vtkANARIHidingDecorator.h.
Definition at line 17 of file vtkANARIHidingDecorator.h.
◆ vtkANARIHidingDecorator() [1/2]
vtkANARIHidingDecorator::vtkANARIHidingDecorator ( )
protecteddefault
◆ ~vtkANARIHidingDecorator()
vtkANARIHidingDecorator::~vtkANARIHidingDecorator ( )
overrideprotecteddefault
◆ vtkANARIHidingDecorator() [2/2]
vtkANARIHidingDecorator::vtkANARIHidingDecorator ( const vtkANARIHidingDecorator )
protecteddelete
static vtkANARIHidingDecorator* vtkANARIHidingDecorator::New ( )
virtual const char* vtkANARIHidingDecorator::GetClassName ( )
Reimplemented from vtkPropertyDecorator.
static int vtkANARIHidingDecorator::IsTypeOf ( const char *  type)
virtual int vtkANARIHidingDecorator::IsA ( const char *  type)
static vtkANARIHidingDecorator* vtkANARIHidingDecorator::SafeDownCast ( vtkObject o)
void vtkANARIHidingDecorator::PrintSelf ( ostream &  os,
◆ CanShow()
bool vtkANARIHidingDecorator::CanShow ( bool  showAdvanced) const
override
