| | Overridden to handle various view passes. More...
| void | SetVisibility (bool val) override |
| | Get/Set the visibility for this representation. More...
| void | SetAmbient (double) |
| | Forwarded to vtkProperty. More...
| void | SetDiffuse (double) |
| void | SetSpecular (double) |
| void | SetSpecularPower (double val) |
| void | SetAmbientColor (double r, double g, double b) |
| void | SetDiffuseColor (double r, double g, double b) |
| void | SetSpecularColor (double r, double g, double b) |
| void | SetLineWidth (double val) |
| void | SetOpacity (double val) |
| void | SetLuminosity (double val) |
| void | SetRenderLinesAsTubes (bool) |
| void | SetOrientation (double, double, double) |
| | Forwarded to vtkActor. More...
| void | SetOrigin (double, double, double) |
| void | SetPickable (int val) |
| void | SetPosition (double, double, double) |
| void | SetScale (double, double, double) |
| void | SetUserTransform (const double[16]) |
| virtual void | MarkModified () |
| | This is one of the most important functions. More...
| virtual unsigned int | Initialize (unsigned int minIdAvailable, unsigned int maxIdAvailable) |
| | Initialize the representation with an identifier range so each internal representation can own a unique ID. More...
| bool | GetNeedsUpdate () |
| | Specify the array names used for the selection. More...
| void | ResetUpdateTime () |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkAMROutlineRepresentation () |
| | ~vtkAMROutlineRepresentation () override |
| int | RequestInformation (vtkInformation *rqst, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
| | Overridden to check if the input pipeline is streaming capable. More...
| | Setup the block request. More...
| int | RequestData (vtkInformation *rqst, vtkInformationVector **inputVector, vtkInformationVector *outputVector) override |
| | Generate the outline for the current input. More...
| bool | StreamingUpdate (const double view_planes[24]) |
| | Returns true if this representation has a "next piece" that it streamed. More...
| virtual bool | GetStreamingCapablePipeline () |
| | Returns true when the input pipeline supports streaming. More...
| virtual bool | GetInStreamingUpdate () |
| | Returns true when StreamingUpdate() is being processed. More...
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
