| virtual void | SetBoxSize (double) |
| virtual double | GetBoxSize () |
| void | AddFileName (const char *) |
| | Add/Remove files to read. More...
| void | RemoveAllFileNames () |
| virtual void | SetByteSwap (int) |
| | Set/Get the endian-ness of the binary file. More...
| virtual int | GetByteSwap () |
| virtual void | SetTagSize (int) |
| | When false (default) 32-bit tags are read from the file. More...
| virtual int | GetTagSize () |
| virtual void | SetLevel (int) |
| | Sets the level of resolution. More...
| virtual int | GetLevel () |
| vtkMultiBlockDataSetAlgorithm * | NewInstance () const |
| vtkMultiBlockDataSet * | GetOutput () |
| vtkMultiBlockDataSet * | GetOutput (int) |
| int | HasExecutive () |
| void | RemoveAllInputs () |
| virtual void | Update () |
| int | GetUpdatePiece () |
| | vtkACosmoReader () |
| | ~vtkACosmoReader () |
| int | RequestInformation (vtkInformation *, vtkInformationVector **, vtkInformationVector *) override |
| void | LoadMetaData () |
| | Loads the metadata. More...
| void | ExtractInfoFromFileNames () |
| | Processes the user-supplied FileName and extracts the base file name, as well as, the total number of levels. More...
| void | ReadMetaDataFile (const int levelIdx, std::string file) |
| | Reads the metadata file with the given filename at the specified level. More...
| int | GetBlockIndex (const int level, const int idx) |
| | Given the level and index of the block within that level, this method returns the block index. More...
| void | SetupBlockRequest (vtkInformation *outInfo) |
| | Given an output information object, this method will populate the vector of block Ids to read in. More...
| void | ReadBlock (const int blockIdx, vtkMultiBlockDataSet *mbds) |
| | Read in the block corresponding to the given index. More...
| int | GetBlockStartOffSetInFile (const int level, const int index) |
| | Given the block level and index within the level, this method returns the block's starting offset within the file. More...
| void | ReadBlockFromFile (std::string file, const int start, const int end, vtkUnstructuredGrid *particles) |
| | Given the file and start/end offsets of a block, this method reads in the particles for a contiguous block. More...
| | vtkMultiBlockDataSetAlgorithm () |
| | ~vtkMultiBlockDataSetAlgorithm () |
| virtual int | FillInputPortInformation (int port, vtkInformation *info) |
| virtual int | RequestDataObject (vtkInformation *, vtkInformationVector **, vtkInformationVector *) |
| | vtkAlgorithm () |
| | ~vtkAlgorithm () |
| | vtkObject () |
| | vtkObjectBase () |
Adaptively read a binary cosmology data file.
Definition at line 30 of file vtkACosmoReader.h.
