support loading states, and data files when loaded from pqRecentFilesMenu. More...
#include <pqStandardRecentlyUsedResourceLoaderImplementation.h>
| pqStandardRecentlyUsedResourceLoaderImplementation (QObject *parent=nullptr) | |
| ~pqStandardRecentlyUsedResourceLoaderImplementation () override | |
| bool | canLoad (const pqServerResource &resource) override |
| Return true of the interface supports loading the given resource. More... | |
| bool | load (const pqServerResource &resource, pqServer *server) override |
| Loads the resource and returns the true if successfully loaded, otherwise false. More... | |
| QIcon | icon (const pqServerResource &resource) override |
| Return an icon, if any, to use for the resource. More... | |
| QString | label (const pqServerResource &resource) override |
| Return label to use for the resource. More... | |
Public Member Functions inherited from pqRecentlyUsedResourceLoaderInterface | |
| virtual | ~pqRecentlyUsedResourceLoaderInterface () |
| static bool | addDataFilesToRecentResources (pqServer *server, const QStringList &files, const QString &smgroup, const QString &smname) |
| Add data files(s) to the recently used resources list. More... | |
| static bool | addStateFileToRecentResources (pqServer *server, const QString &file, vtkTypeUInt32 location=0x10) |
| Add state file to the recently used resources list. More... | |
Protected Member Functions inherited from pqRecentlyUsedResourceLoaderInterface | |
| pqRecentlyUsedResourceLoaderInterface () | |
pqStandardRecentlyUsedResourceLoaderImplementation is an implementation of the pqRecentlyUsedResourceLoaderInterface that support loading resources known to ParaView e.g. data files and state files. pqParaViewBehaviors instantiates this unless pqParaViewBehaviors::enableStandardRecentlyUsedResourceLoader is false.
Definition at line 26 of file pqStandardRecentlyUsedResourceLoaderImplementation.h.
| pqStandardRecentlyUsedResourceLoaderImplementation::pqStandardRecentlyUsedResourceLoaderImplementation | ( | QObject * | parent = nullptr | ) |
Implements pqRecentlyUsedResourceLoaderInterface.
If returned false, the resource is treated as defunct and may be removed. from the recent list.
Default implementation simply returns an empty QIcon.
Reimplemented from pqRecentlyUsedResourceLoaderInterface.
