pqSignalAdaptorTreeWidget can be used to connect any property with repeat_command to a tree widget that displays the property value.
#include <pqSignalAdaptorTreeWidget.h>
Inherits QObject.
| void | setValues (const QList< QVariant > &) |
| | Set the values in the widget. More...
| QTreeWidgetItem * | growTable () |
| | Called when user navigates beyond the end in the indices table widget. More...
| void | valuesChanged () |
| | Fired when the tree widget is modified. More...
| void | tableGrown (QTreeWidgetItem *item) |
| | Fired when the table is automatically grown due to the user navigating past the end. More...
The TreeWidget must have exactly as many columns as the number of elements in each command for the property (i.e. number_of_element_per_command). Note that the adaptor does not force the repeat command or size requirements mentioned above.
Definition at line 24 of file pqSignalAdaptorTreeWidget.h.
◆ pqSignalAdaptorTreeWidget()
| pqSignalAdaptorTreeWidget::pqSignalAdaptorTreeWidget |
QTreeWidget * |
treeWidget, |
bool |
editable |
Constructor.
- Parameters
| treeWidget | is the tree widget we are connecting. |
| editable | indicates if items in the widget can be edited by the user. |
◆ ~pqSignalAdaptorTreeWidget()
| pqSignalAdaptorTreeWidget::~pqSignalAdaptorTreeWidget |
◆ values()
| QList<QVariant> pqSignalAdaptorTreeWidget::values |
const |
Returns a list of the values currently in the tree widget.
◆ appendValue() [1/2]
| QTreeWidgetItem* pqSignalAdaptorTreeWidget::appendValue |
const QList< QVariant > & |
values | ) |
Append an item to the tree.
The size of values == this->TreeWidget->columnCount(). Returns the newly created item, or 0 on failure.
◆ appendValue() [2/2]
const QStringList & |
values | ) |
◆ setItemCreatorFunction()
| void pqSignalAdaptorTreeWidget::setItemCreatorFunction |
QTreeWidgetItem * |
fptr)(QTreeWidget *, const QStringList & | ) |
This adaptor create QTreeWidgetItem instances by default when new entries are to be shown in the widget.
To change the type of QTreeWidgetItem subclass created, simply set a function pointer to a callback which will be called every time a new item is needed. The signature for the callback is: QTreeWidgetItem* callback(QTreeWidget* parent, const QStringList& val)
Definition at line 60 of file pqSignalAdaptorTreeWidget.h.
◆ valuesChanged
| void pqSignalAdaptorTreeWidget::valuesChanged |
signal |
◆ tableGrown
| void pqSignalAdaptorTreeWidget::tableGrown |
QTreeWidgetItem * |
item | ) |
signal |
This only supported for editable pqTreeWidget instances.
◆ setValues
| void pqSignalAdaptorTreeWidget::setValues |
slot |
◆ growTable
| QTreeWidgetItem* pqSignalAdaptorTreeWidget::growTable |
slot |
We add a new row to simplify editing.
◆ values
readwrite |
