This is a ComboBox that is used on the display tab to select available ShaderReplacements presets paths saved in vtkSMSettings.
#include <pqShaderReplacementsComboBox.h>
Inherits QComboBox.
Definition at line 14 of file pqShaderReplacementsComboBox.h.
◆ pqShaderReplacementsComboBox()
| pqShaderReplacementsComboBox::pqShaderReplacementsComboBox |
QWidget * |
parent = nullptr | ) |
◆ ~pqShaderReplacementsComboBox()
| pqShaderReplacementsComboBox::~pqShaderReplacementsComboBox |
overridedefault |
◆ getPathIndex()
| int pqShaderReplacementsComboBox::getPathIndex |
const QString & |
presetPath | ) |
const |
Return the combobox entry index corresponding to the provided preset path.
Returned value is 0 if not found.
◆ setPath()
| void pqShaderReplacementsComboBox::setPath |
const QString & |
presetPath | ) |
Select the combobox entry corresponding to the provided path.
◆ populate()
| void pqShaderReplacementsComboBox::populate |
Clear current combobox content and repopulate it with the shader replacement presets using the files declared in vtkSMSettings.
◆ showPopup()
| void pqShaderReplacementsComboBox::showPopup |
◆ ShaderReplacementPathsSettings
| const char* pqShaderReplacementsComboBox::ShaderReplacementPathsSettings |
