pqRescaleScalarRangeToCustomDialog provides a dialog to be able to rescale the active lookup table's range to a custom range.
#include <pqRescaleScalarRangeToCustomDialog.h>
Inherits QDialog.
| void | apply () |
| | Fired when the user wants to apply his changes. More...
| std::unique_ptr< pqRescaleScalarRangeToCustomDialogForm > | Form |
Definition at line 19 of file pqRescaleScalarRangeToCustomDialog.h.
◆ pqRescaleScalarRangeToCustomDialog()
| pqRescaleScalarRangeToCustomDialog::pqRescaleScalarRangeToCustomDialog |
QWidget * |
parent = nullptr | ) |
◆ ~pqRescaleScalarRangeToCustomDialog()
| pqRescaleScalarRangeToCustomDialog::~pqRescaleScalarRangeToCustomDialog |
◆ minimum()
| double pqRescaleScalarRangeToCustomDialog::minimum |
const |
Get the minimum of the color map range.
◆ maximum()
| double pqRescaleScalarRangeToCustomDialog::maximum |
const |
Get the maximum of the color map range.
◆ showOpacityControls()
| void pqRescaleScalarRangeToCustomDialog::showOpacityControls |
bool |
show | ) |
Show or hide the opacity controls.
◆ opacityMinimum()
| double pqRescaleScalarRangeToCustomDialog::opacityMinimum |
const |
Get the minimum of the opacity map range.
◆ opacityMaximum()
| double pqRescaleScalarRangeToCustomDialog::opacityMaximum |
const |
Get the maximum of the opacity map range.
◆ setRange()
| void pqRescaleScalarRangeToCustomDialog::setRange |
double |
min, |
double |
max |
Initialize the range for the color map.
◆ setOpacityRange()
| void pqRescaleScalarRangeToCustomDialog::setOpacityRange |
double |
min, |
double |
max |
Initialize the range for a separate opacity map, if the option is available.
◆ setLock()
| void pqRescaleScalarRangeToCustomDialog::setLock |
bool |
lock | ) |
Initialize AutomaticRescaling checkbox value.
◆ doLock()
| bool pqRescaleScalarRangeToCustomDialog::doLock |
const |
Get lock value from AutomaticRescaling checkbox.
◆ apply
| void pqRescaleScalarRangeToCustomDialog::apply |
signal |
◆ validate
| void pqRescaleScalarRangeToCustomDialog::validate |
protectedslot |
Check that minimum scalar value < maximum scalar value.
Deactivate apply and rescale button if that's not the case.
◆ rescale
| void pqRescaleScalarRangeToCustomDialog::rescale |
protectedslot |
Emit apply and close the dialog.
◆ Form
| std::unique_ptr<pqRescaleScalarRangeToCustomDialogForm> pqRescaleScalarRangeToCustomDialog::Form |
