| | called to set the active view. More...
| | This signal is emitted when the current view changes. More...
| void | changeAvailable () |
| | This signal is fired as soon as the user starts editing in the widget. More...
| void | changeFinished () |
| | This signal is fired as soon as the user is done with making an atomic change. More...
| void | restartRequired () |
| | Indicates that a restart of the program is required for the setting to take effect. More...
| template<class T > |
| | Parse a XML element as a list of label to use for this widget. More...
Used to select readers to show or hide.
This widget is used in the settings to show a checklist of available readers, letting the user exclude some of them from the list shown in the File .. Open dialog.
- See also
- pqArraySelectorPropertyWidget
Definition at line 23 of file pqReaderSelectionPropertyWidget.h.
