This class is a helper object to attach to a QTextEdit to add Python syntax highlighting to the text that is displayed. More...
#include <pqPythonSyntaxHighlighter.h>
Inherits QObject.
| typedef QObject | Superclass |
| pqPythonSyntaxHighlighter (QObject *p, QTextEdit &textEdit) | |
| Creates a pqPythonSyntaxHighlighter on the given QTextEdit. More... | |
| ~pqPythonSyntaxHighlighter () override=default | |
| bool | isReplacingTabs () const |
| Returns true if the tab key is being intercepted to insert spaces in the text edit. More... | |
| void | setReplaceTabs (bool replaceTabs) |
| Used to enable/disable tab key capture Passing true will cause the tab key to insert 4 spaces in the QTextEdit. More... | |
| QString | Highlight (const QString &src) const |
| Returns the highlighted input text. More... | |
| void | ConnectHighligter () const |
| Connects the highlighter to text. More... | |
| static void | ApplySyntaxFormatting (QTextDocument *dst, const QTextDocument &src) |
Copy character formatting (syntax colors) from src into dst without modifying dst's text. More... | |
| bool | eventFilter (QObject *, QEvent *) override |
| This event filter is applied to the TextEdit to translate presses of the Tab key into 4 spaces being inserted. More... | |
The pygments python module is used to generate syntax highlighting. Since mixing tabs and spaces is an error for python's indentation, tabs are highlighted in red.
The QTextEdit is set up so that it uses a fixed-width font and tabs are the width of 4 spaces by the constructor.
This will also optionally capture presses of the tab key that would go to the QTextEdit and insert 4 spaces instead of the tab. This option is enabled by default.
Definition at line 38 of file pqPythonSyntaxHighlighter.h.
| typedef QObject pqPythonSyntaxHighlighter::Superclass |
Definition at line 42 of file pqPythonSyntaxHighlighter.h.
explicit |
The highlighter is not directly connected to the QTextEdit object (see ConnectHighligter). NOTE: the optional tab key capture is enabled by the constructor
overridedefault |
| bool pqPythonSyntaxHighlighter::isReplacingTabs | ( | ) | const |
| void pqPythonSyntaxHighlighter::setReplaceTabs | ( | bool | replaceTabs | ) |
| QString pqPythonSyntaxHighlighter::Highlight | ( | const QString & | src | ) | const |
| void pqPythonSyntaxHighlighter::ConnectHighligter | ( | ) | const |
This is not automatically called by the constructor as we might want to defer the connection to another widget.
1.8.13 on Sat Aug 29 2026
