#include <pqPythonMacroSupervisor.h>
Inherits QObject.
| void | onMacroTriggered () |
| | If the sender is a QAction managed by this class, the fileName will be looked up and the signal requestExecuteScript will be emitted. More...
| void | onDeleteMacroTriggered () |
| | If the sender is a QAction managed by this class, the fileName will be moved (deleted), and the macro will be removed. More...
| void | onEditMacroTriggered () |
| | If the sender is a QAction managed by this class, the macro file will be open in a python edit. More...
Definition at line 17 of file pqPythonMacroSupervisor.h.
◆ pqPythonMacroSupervisor()
| pqPythonMacroSupervisor::pqPythonMacroSupervisor |
QObject * |
p = nullptr | ) |
◆ ~pqPythonMacroSupervisor()
| pqPythonMacroSupervisor::~pqPythonMacroSupervisor |
◆ addWidgetForRunMacros()
| void pqPythonMacroSupervisor::addWidgetForRunMacros |
QWidget * |
widget | ) |
Add a widget to be given macro actions.
QActions representing script macros will be added to the widget. This could be a QToolBar, QMenu, or other type of widget.
◆ addWidgetForEditMacros()
| void pqPythonMacroSupervisor::addWidgetForEditMacros |
QWidget * |
widget | ) |
◆ addWidgetForDeleteMacros()
| void pqPythonMacroSupervisor::addWidgetForDeleteMacros |
QWidget * |
widget | ) |
◆ getMacro()
| QAction* pqPythonMacroSupervisor::getMacro |
const QString & |
fileName | ) |
Lookup and return a macro action by fileName (absolute path of macro file).
If it does not exist, return null.
◆ getStoredMacros()
| static QMap<QString, QString> pqPythonMacroSupervisor::getStoredMacros |
Get macros from known macro directories (see getMacrosFilePaths) In the returned map, the keys are fileNames and values are macro names.
◆ hideFile()
| static void pqPythonMacroSupervisor::hideFile |
const QString & |
fileName | ) |
Hide file by prepending a `.
` to its name. Hidden file in macro directory are not loaded.
◆ macroNameFromFileName()
| static QString pqPythonMacroSupervisor::macroNameFromFileName |
const QString & |
fileName | ) |
Get a macro name from the fileName (absolute path of macro file).
◆ setNameForMacro()
| static void pqPythonMacroSupervisor::setNameForMacro |
const QString & |
macroPath, |
const QString & |
name |
◆ macroToolTipFromFileName()
| static QString pqPythonMacroSupervisor::macroToolTipFromFileName |
const QString & |
fileName | ) |
Get a macro tooltip from the fileName (absolute path of macro file).
◆ setTooltipForMacro()
| static void pqPythonMacroSupervisor::setTooltipForMacro |
const QString & |
macroPath, |
const QString & |
name |
◆ iconPathFromFileName()
| static QString pqPythonMacroSupervisor::iconPathFromFileName |
const QString & |
fileName | ) |
Get an icon path from the fileName (absolute path of macro file).
If no corresponding icon, return an empty string.
◆ setIconForMacro()
| static void pqPythonMacroSupervisor::setIconForMacro |
const QString & |
macroPath, |
const QString & |
iconPath |
◆ getMacrosFilePaths()
| static QStringList pqPythonMacroSupervisor::getMacrosFilePaths |
Get a list a "*.py" files from macro directories.
◆ executeScriptRequested
| void pqPythonMacroSupervisor::executeScriptRequested |
const QString & |
fileName | ) |
signal |
Emitted when a macro has been triggered.
◆ onAddedMacro
| void pqPythonMacroSupervisor::onAddedMacro |
signal |
Emitted when a macro has been added.
◆ onEditMacro
| void pqPythonMacroSupervisor::onEditMacro |
const QString & |
fileName | ) |
signal |
Emitted when a macro has to be edited.
◆ addMacro [1/3]
| void pqPythonMacroSupervisor::addMacro |
const QString & |
macroName, |
const QString & |
tip, |
const QString & |
fileName |
slot |
Add an action with the given name and fileName.
If there is already a macro with the given fileName it's macroname will be updated to the one given. Macro names do not have to be unique.
◆ addMacro [2/3]
const QString & |
macroName, |
const QString & |
fileName |
slot |
◆ addMacro [3/3]
const QString & |
fileName | ) |
slot |
◆ removeMacro
| void pqPythonMacroSupervisor::removeMacro |
const QString & |
fileName | ) |
slot |
Remove an action from the UI, with the given fileName (absolute path of macro file).
Note, this does not remove the macro from a future load, you must call hideFile yourself (or manually remove the file from the settings dir).
◆ updateMacroList
| void pqPythonMacroSupervisor::updateMacroList |
slot |
Update Macro list widgets and actions...
◆ onMacroTriggered
| void pqPythonMacroSupervisor::onMacroTriggered |
protectedslot |
◆ onDeleteMacroTriggered
| void pqPythonMacroSupervisor::onDeleteMacroTriggered |
protectedslot |
◆ onEditMacroTriggered
| void pqPythonMacroSupervisor::onEditMacroTriggered |
protectedslot |
◆ addWidgetForMacros()
| void pqPythonMacroSupervisor::addWidgetForMacros |
QWidget * |
widget, |
int |
actionType |
◆ resetActions()
| void pqPythonMacroSupervisor::resetActions |
Removes all actions and re-adds actions for each macro stored.
