pqPythonCalculatorWidget is a property-widget that shows a Python calculator expression editor with input/array pickers. More...
#include <pqPythonCalculatorWidget.h>
| pqPythonCalculatorWidget (vtkSMProxy *proxy, vtkSMProperty *property, QWidget *parent=nullptr) | |
| ~pqPythonCalculatorWidget () override | |
Public Member Functions inherited from pqStringVectorPropertyWidget | |
| pqStringVectorPropertyWidget (vtkSMProperty *property, vtkSMProxy *proxy, QWidget *parent=nullptr) | |
| ~pqStringVectorPropertyWidget () override | |
| void | setReadOnly (bool readOnly) override |
| Set widget in read-only mode. More... | |
| virtual void | apply () |
| virtual void | reset () |
| pqView * | view () const |
| bool | showLabel () const |
| virtual void | select () |
Protected Slots | |
| void | updateInputs () |
| void | updateArrays () |
| void | arrayChosen (int index) |
| void | functionActivated (QTreeWidgetItem *item, int column) |
| void | filterFunctions (const QString &text) |
| void | changeAvailable () |
| void | changeFinished () |
| void | restartRequired () |
Static Public Member Functions inherited from pqStringVectorPropertyWidget | |
| static pqPropertyWidget * | createWidget (vtkSMStringVectorProperty *smproperty, vtkSMProxy *smproxy, QWidget *parent=nullptr) |
| Factory method to instantiate a hard-coded type of pqPropertyWidget subclass for the vtkSMStringVectorProperty. More... | |
| static void | processFileChooserHints (vtkPVXMLElement *hints, bool &directoryMode, bool &anyFile, QString &filter, bool &browseLocalFileSystem) |
| Method to process file-choice related hints. More... | |
| template<class T > | |
Definition at line 19 of file pqPythonCalculatorWidget.h.
| pqPythonCalculatorWidget::pqPythonCalculatorWidget | ( | vtkSMProxy * | proxy, |
| vtkSMProperty * | property, | ||
protectedslot |
protectedslot |
protectedslot |
protectedslot |
protectedslot |
1.8.13 on Tue Oct 13 2026
