pqProxiesWidget similar to pqProxyWidget with the difference being that unlike pqProxyWidget, pqProxiesWidget supports showing of multiple proxies in the same widget.
#include <pqProxiesWidget.h>
Inherits QWidget.
| void | clear () |
| | Remove all proxy widgets added to the panel. More...
| void | addProxy (vtkSMProxy *, const QString &componentName=QString(), const QStringList &properties=QStringList(), bool applyChangesImmediately=false, bool showHeadersFooters=true) |
| | Add the widgets for a proxy. More...
| void | updateLayout () |
| | Call this method once after all proxies have been added (or after clear) to update the layout for the panel. More...
| bool | filterWidgets (bool show_advanced=false, const QString &filterText=QString()) |
| | Updates the property widgets shown based on the filterText or show_advanced flag. More...
| void | apply () const |
| | Accepts the property widget changes changes. More...
| void | reset () const |
| | Cleans the property widget changes and resets the widgets. More...
| void | setView (pqView *) |
| | Set the current view to use to show 3D widgets, if any for the panel. More...
| void | updatePanel () |
| | Same as calling filterWidgets() with the arguments specified to the most recent call to filterWidgets(). More...
Internally, it indeed creates a pqProxyWidget for each of the added proxies.
To use this class, add all proxies to show in this panel using addProxy() and then call updateLayout() to update the layout.
pqProxiesWidget supports grouping of proxies in components (separated by using a pqExpanderButton). To use pqExpanderButton simply use a non-empty componentName when calling addProxy().
pqProxiesWidget provides API such as filterWidgets(), apply(), etc. the calls to which are simply forwarded to the internal pqProxyWidget instances. Similarly, pqProxiesWidget also forwards signals fired by pqProxyWidget such as changeFinished(), changeAvailable(), and restartRequired().
Definition at line 33 of file pqProxiesWidget.h.
◆ pqProxiesWidget()
| pqProxiesWidget::pqProxiesWidget |
QWidget * |
parent = nullptr, |
Qt::WindowFlags |
flags = Qt::WindowFlags{} |
◆ ~pqProxiesWidget()
| pqProxiesWidget::~pqProxiesWidget |
◆ expanderState()
| QMap<QString, bool> pqProxiesWidget::expanderState |
const |
Returns a map indicating which expand buttons are expanded and which ones aren't.
Useful to save and then restore the state when resetting the panel. The key is the text used for componentName argument to addProxy call. The value is true for expanded, false otherwise.
◆ setExpanderState()
| void pqProxiesWidget::setExpanderState |
const QMap< QString, bool > & |
state | ) |
Set the expander state.
If any key is unrecognized, it will be silently ignored. State for expanders not referred to in the state is left unchanged.
◆ clear
| void pqProxiesWidget::clear |
slot |
◆ addProxy
| void pqProxiesWidget::addProxy |
vtkSMProxy * |
const QString & |
componentName = QString(), |
const QStringList & |
properties = QStringList(), |
bool |
applyChangesImmediately = false, |
bool |
showHeadersFooters = true |
slot |
◆ updateLayout
| void pqProxiesWidget::updateLayout |
slot |
◆ filterWidgets
| bool pqProxiesWidget::filterWidgets |
bool |
show_advanced = false, |
const QString & |
filterText = QString() |
slot |
Calling filterWidgets() without any arguments will result in the panel showing all the non-advanced properties. Returns true, if any widgets were shown.
◆ apply
| void pqProxiesWidget::apply |
const |
slot |
◆ reset
| void pqProxiesWidget::reset |
const |
slot |
◆ setView
| void pqProxiesWidget::setView |
pqView * |
slot |
◆ updatePanel
| void pqProxiesWidget::updatePanel |
slot |
◆ changeAvailable
| void pqProxiesWidget::changeAvailable |
vtkSMProxy * |
proxy | ) |
signal |
This signal is fired as soon as the user starts editing in the widget.
The editing may not be complete.
◆ changeFinished
| void pqProxiesWidget::changeFinished |
vtkSMProxy * |
proxy | ) |
signal |
◆ restartRequired
| void pqProxiesWidget::restartRequired |
vtkSMProxy * |
proxy | ) |
signal |
Indicates that a restart of the program is required for the setting to take effect.
