pqPropertyLinksConnection is used by pqPropertyLinks to keep a QObject and vtkSMProperty linked together.
#include <pqPropertyLinksConnection.h>
Inherits QObject.
pqPropertyLinksConnection handles most common types of connections. Developers can subclass this to customize the mechanisms for copy values from Qt to ServerManager and vice-versa.
Definition at line 26 of file pqPropertyLinksConnection.h.
◆ pqPropertyLinksConnection()
| pqPropertyLinksConnection::pqPropertyLinksConnection |
QObject * |
qobject, |
const char * |
qproperty, |
const char * |
qsignal, |
vtkSMProxy * |
smproxy, |
vtkSMProperty * |
smproperty, |
int |
smindex, |
bool |
use_unchecked_modified_event, |
QObject * |
parentObject = nullptr |
This also sets up observers to monitor any changes.
This does not change any values on either items.
◆ ~pqPropertyLinksConnection()
| pqPropertyLinksConnection::~pqPropertyLinksConnection |
◆ setUseUncheckedProperties()
| void pqPropertyLinksConnection::setUseUncheckedProperties |
bool |
useUnchecked | ) |
◆ operator==()
◆ objectQt()
| QObject* pqPropertyLinksConnection::objectQt |
const |
◆ propertyQt()
| const QString& pqPropertyLinksConnection::propertyQt |
const |
◆ proxy()
| vtkSMProxy* pqPropertyLinksConnection::proxy |
const |
◆ proxySM()
| vtkSMProxy* pqPropertyLinksConnection::proxySM |
const |
◆ propertySM()
◆ indexSM()
| int pqPropertyLinksConnection::indexSM |
const |
◆ setTraceChanges()
| void pqPropertyLinksConnection::setTraceChanges |
bool |
trace | ) |
◆ traceChanges()
| bool pqPropertyLinksConnection::traceChanges |
const |
◆ copyValuesFromServerManagerToQt
| void pqPropertyLinksConnection::copyValuesFromServerManagerToQt |
bool |
use_unchecked | ) |
slot |
Copy values from ServerManager to Qt.
If use_unchecked is true, unchecked SMProperty values are used.
◆ copyValuesFromQtToServerManager
| void pqPropertyLinksConnection::copyValuesFromQtToServerManager |
bool |
use_unchecked | ) |
slot |
Copy values from Qt to ServerManager.
If use_unchecked is true, unchecked values for SMProperty are updated.
◆ setQtValue()
| virtual void pqPropertyLinksConnection::setQtValue |
const QVariant & |
value | ) |
protectedvirtual |
These are the methods that subclasses can override to customize how values are updated in either directions.
◆ setServerManagerValue()
| virtual void pqPropertyLinksConnection::setServerManagerValue |
bool |
use_unchecked, |
const QVariant & |
value |
protectedvirtual |
◆ currentQtValue()
| virtual QVariant pqPropertyLinksConnection::currentQtValue |
const |
protectedvirtual |
◆ currentServerManagerValue()
| virtual QVariant pqPropertyLinksConnection::currentServerManagerValue |
bool |
use_unchecked | ) |
const |
protectedvirtual |
◆ qtpropertyModified
| void pqPropertyLinksConnection::qtpropertyModified |
signal |
◆ smpropertyModified
| void pqPropertyLinksConnection::smpropertyModified |
signal |
