Signals | Public Member Functions | Static Public Member Functions | Protected Slots | Protected Member Functions | List of all members
pqPipelineFilter Class Reference
#include <pqPipelineFilter.h>
Inheritance diagram for pqPipelineFilter:
Collaboration diagram for pqPipelineFilter:
Signals
void producerChanged (const QString &inputportname)
 fired whenever an input connection changes. More...
- Signals inherited from pqPipelineSource
void connectionAdded (pqPipelineSource *source, pqPipelineSource *consumer, int srcOutputPort)
 fired when a connection is created between two pqPipelineSources. More...
void preConnectionAdded (pqPipelineSource *source, pqPipelineSource *consumer, int srcOutputPort)
void connectionRemoved (pqPipelineSource *source, pqPipelineSource *consumer, int srcOutputPort)
 fired when a connection is broken between two pqPipelineSources. More...
void preConnectionRemoved (pqPipelineSource *source, pqPipelineSource *consumer, int srcOutputPort)
void representationAdded (pqPipelineSource *source, pqDataRepresentation *repr, int srcOutputPort)
 fired when a representation is added. More...
void representationRemoved (pqPipelineSource *source, pqDataRepresentation *repr, int srcOutputPort)
 fired when a representation is removed. More...
void visibilityChanged (pqPipelineSource *source, pqDataRepresentation *repr)
 Fired when the visbility of a representation for the source changes. More...
void dataUpdated (pqPipelineSource *source)
 Fired right after the underlying algorithm updates (executes). More...
void selectionChanged (pqOutputPort *port)
 Fired when the selection on a port has changed. More...
- Signals inherited from pqProxy
void nameChanged (pqServerManagerModelItem *)
 Fired when the name of the proxy is changed. More...
void modifiedStateChanged (pqServerManagerModelItem *)
 Fired when the modified status changes for the proxy. More...
 pqPipelineFilter (QString name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr)
 ~pqPipelineFilter () override
int getNumberOfInputPorts () const
 Returns the number of input ports available on this filter. More...
QString getInputPortName (int index) const
 Returns the name of the input port at a given index. More...
int getNumberOfInputs (const QString &portname) const
 Returns the number of input proxies connected to given named input port. More...
QList< pqOutputPort * > getInputs (const QString &portname) const
 Returns the input proxies connected to the given named input port. More...
QList< pqOutputPort * > getAllInputs () const
 Returns inputs connected to all input ports connections. More...
QMap< QString, QList< pqOutputPort * > > getNamedInputs () const
 Returns a map of input port name to the list of output ports that are set as the input to that port. More...
pqOutputPortgetInput (const QString &portname, int index) const
 Returns a pair (input, output port) at the given index on the given named input port. More...
int getInputCount () const
 Get number of inputs. More...
QList< pqOutputPort * > getInputs () const
 Get a list of all inputs. More...
pqPipelineSourcegetInput (int index) const
 Get input at given index. More...
pqOutputPortgetAnyInput () const
 Get first available input, any port, any index. More...
int replaceInput () const
 "Replace input" is a hint given to the GUI to turn off input visibility when the filter is created. More...
- Public Member Functions inherited from pqPipelineSource
 pqPipelineSource (const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr)
 ~pqPipelineSource () override
int getNumberOfOutputPorts () const
 A source may have multiple output ports. More...
pqOutputPortgetOutputPort (int outputport) const
 Returns the pqOutputPort for the given output port. More...
pqOutputPortgetOutputPort (const QString &portName) const
 Returns the pqOutputPort given the name of the port. More...
QList< pqOutputPort * > getOutputPorts () const
 Returns all the output ports. More...
int getNumberOfConsumers (int outputport) const
 Returns the number of consumers connected to the given output port. More...
int getNumberOfConsumers () const
 Get the number of consumers connected to output port 0. More...
pqPipelineSourcegetConsumer (int outputport, int index) const
 Get the consumer at a particulat index on a given output port. More...
pqPipelineSourcegetConsumer (int index) const
 Get consumer at a particular index on output port 0. More...
QList< pqPipelineSource * > getAllConsumers () const
 Returns a list of consumers for all output ports. More...
QList< pqDataRepresentation * > getRepresentations (int outputport, pqView *view) const
 Returns a list of representations for this source in the given view. More...
QList< pqDataRepresentation * > getRepresentations (pqView *view) const
pqDataRepresentationgetRepresentation (int outputport, pqView *view) const
 Returns the first representation for this source in the given view. More...
pqDataRepresentationgetRepresentation (pqView *view) const
QList< pqView * > getViews () const
 Returns a list of render modules in which this source has representations added (the representations may not be visible). More...
void renderAllViews (bool force=false)
 This method updates all render modules to which all representations for this source belong, if force is true, it for an immediate render otherwise render on idle. More...
void updatePipeline ()
 Update the pipeline with the current time. More...
vtkSMSourceProxygetSourceProxy ()
 Return the vtkSMSourceProxy instance corresponding to this pqPipelineSource. More...
- Public Member Functions inherited from pqProxy
 pqProxy (const QString &group, const QString &name, vtkSMProxy *proxy, pqServer *server, QObject *parent=nullptr)
 ~pqProxy () override
pqServergetServer () const
 Get the server on which this proxy exists. More...
void rename (const QString &newname)
 This is a convenience method. More...
const QString & getSMName ()
 Get the name with which this proxy is registered on the server manager. More...
const QString & getSMGroup ()
vtkSMProxygetProxy () const
 Get the vtkSMProxy this object stands for. More...
ModifiedState modifiedState () const
 Gets whether or not the source has been modified. More...
void setModifiedState (ModifiedState modified)
 Sets whether or not the source has been modified. More...
vtkPVXMLElementgetHints () const
 Returns the hints for this proxy, if any. More...
QList< vtkSMProxy * > getHelperProxies () const
 Returns a list of all helper proxies. More...
QList< vtkSMProxy * > getHelperProxies (const QString &key) const
 Returns a list of all the helper proxies added with a given key. More...
QList< QString > getHelperKeys () const
 Returns the keys for helper proxies. More...
virtual void addHelperProxy (const QString &key, vtkSMProxy *)
 Concept of helper proxies: A pqProxy is created for every important vtkSMProxy registered. More...
void removeHelperProxy (const QString &key, vtkSMProxy *)
void updateHelperProxies () const
 Updates the internal datastructures using the proxies currently registered under the group that would be used for helper proxies. More...
vtkSMSessionProxyManagerproxyManager () const
 Returns the proxy manager by calling this->getProxy()->GetProxyManager();. More...
bool userModifiedSMName ()
 Return whether or not the user has modified the GUI name of the source. More...
- Public Member Functions inherited from pqServerManagerModelItem
 pqServerManagerModelItem (QObject *parent=nullptr)
 ~pqServerManagerModelItem () override
static QList< const char * > getInputPorts (vtkSMProxy *)
 Returns the inputs ports on any proxy. More...
static QList< const char * > getRequiredInputPorts (vtkSMProxy *)
 Returns the required inputs ports on any proxy. More...
- Static Public Member Functions inherited from pqProxy
static pqProxyfindProxyWithHelper (vtkSMProxy *aproxy, QString &key)
 Returns a pqProxy instance, of any, whose helper proxy is the aproxy. More...
static pqProxyfindProxy (vtkSMProxy *aproxy)
 Returns a pqProxy found under current pqServer and matching given vtkSMProxy. More...
Protected Slots
void inputChanged (vtkObject *, unsigned long, void *client_data)
 process some change in the input property for the proxy. More...
- Protected Slots inherited from pqPipelineSource
void onRepresentationVisibilityChanged ()
 Called when the visibility of any representation for this source changes. More...
- Protected Slots inherited from pqProxy
void onProxyRegistered (const QString &, const QString &, vtkSMProxy *)
void onProxyUnRegistered (const QString &, const QString &, vtkSMProxy *)
void initialize () override
 Use this method to initialize the pqObject state using the underlying vtkSMProxy. More...
void inputChanged (const QString &portname)
 Called when a input property changes. More...
- Protected Member Functions inherited from pqPipelineSource
void removeConsumer (int outputport, pqPipelineSource *)
 called by pqPipelineFilter when the connections change. More...
void addConsumer (int outputport, pqPipelineSource *)
- Protected Member Functions inherited from pqProxy
void setSMName (const QString &new_name)
 Make this pqProxy take on a new identity. More...
virtual void addInternalHelperProxy (const QString &key, vtkSMProxy *) const
virtual void removeInternalHelperProxy (const QString &key, vtkSMProxy *) const
- Protected Member Functions inherited from pqServerManagerModelItem
vtkEventQtSlotConnectgetConnector ()
 All subclasses generally need some vtkEventQtSlotConnect instance to connect to VTK events. More...
- Public Types inherited from pqProxy
enum  ModifiedState { UNINITIALIZED, MODIFIED, UNMODIFIED }
 The modification state of this proxy. More...
Definition at line 19 of file pqPipelineFilter.h.
◆ pqPipelineFilter()
pqPipelineFilter::pqPipelineFilter ( QString  name,
vtkSMProxy proxy,
pqServer server,
QObject *  parent = nullptr
◆ ~pqPipelineFilter()
pqPipelineFilter::~pqPipelineFilter ( )
override
◆ getInputPorts()
static QList<const char*> pqPipelineFilter::getInputPorts ( vtkSMProxy )
◆ getRequiredInputPorts()
static QList<const char*> pqPipelineFilter::getRequiredInputPorts ( vtkSMProxy )
This is generally same as getInputPorts() except if the property has a "hint" saying it's optional.
◆ getNumberOfInputPorts()
int pqPipelineFilter::getNumberOfInputPorts ( ) const
◆ getInputPortName()
QString pqPipelineFilter::getInputPortName ( int  index) const
◆ getNumberOfInputs()
int pqPipelineFilter::getNumberOfInputs ( const QString &  portname) const
◆ getInputs() [1/2]
QList<pqOutputPort*> pqPipelineFilter::getInputs ( const QString &  portname) const
◆ getAllInputs()
QList<pqOutputPort*> pqPipelineFilter::getAllInputs ( ) const
◆ getNamedInputs()
QMap<QString, QList<pqOutputPort*> > pqPipelineFilter::getNamedInputs ( ) const
◆ getInput() [1/2]
pqOutputPort* pqPipelineFilter::getInput ( const QString &  portname,
int  index
) const
◆ getInputCount()
int pqPipelineFilter::getInputCount ( ) const
inline
Definition at line 80 of file pqPipelineFilter.h.
◆ getInputs() [2/2]
QList<pqOutputPort*> pqPipelineFilter::getInputs ( ) const
inline
Definition at line 85 of file pqPipelineFilter.h.
◆ getInput() [2/2]
pqPipelineSource* pqPipelineFilter::getInput ( int  index) const
◆ getAnyInput()
pqOutputPort* pqPipelineFilter::getAnyInput ( ) const
Return nullptr if none are available.
◆ replaceInput()
int pqPipelineFilter::replaceInput ( ) const
Returns if this proxy replaces input on creation. This checks the "Hints" for the proxy, if any. If a <Visibility> element is present with replace_input="0", then this method returns false, otherwise true.
◆ producerChanged
void pqPipelineFilter::producerChanged ( const QString &  inputportname)
signal
◆ inputChanged [1/2]
void pqPipelineFilter::inputChanged ( vtkObject ,
unsigned  long,
void *  client_data
protectedslot
◆ initialize()
void pqPipelineFilter::initialize ( )
overrideprotectedvirtual
This needs to be done only once, after the object has been created.
Reimplemented from pqProxy.
◆ inputChanged() [2/2]
void pqPipelineFilter::inputChanged ( const QString &  portname)
portname is the name of the input port represented by the property.
