Static Public Member Functions | List of all members
pqParaViewMenuBuilders Class Reference
pqParaViewMenuBuilders provides helper methods to build menus that are exactly as used by ParaView client. More...
#include <pqParaViewMenuBuilders.h>
static void buildFileMenu (QMenu &menu)
 Builds standard File menu. More...
static void buildEditMenu (QMenu &menu, pqPropertiesPanel *propertiesPanel=nullptr)
 Builds the standard Edit menu. More...
static void buildSourcesMenu (QMenu &menu, QMainWindow *mainWindow=nullptr)
 Builds "Sources" menu. More...
static void buildFiltersMenu (QMenu &menu, QMainWindow *mainWindow=nullptr, bool hideDisabled=false, bool quickLaunchable=true)
 Builds "Filters" menu. More...
static void buildExtractorsMenu (QMenu &menu, QMainWindow *mainWindow=nullptr, bool hideDisabled=false, bool quickLaunchable=true)
 Builds "Extractors" menu. More...
static void buildToolsMenu (QMenu &menu)
 Builds the "Tools" menu. More...
static void buildCatalystMenu (QMenu &menu)
 Builds the "Catalyst" menu. More...
static void buildViewMenu (QMenu &menu, QMainWindow &window)
 Builds the "View" menu. More...
static void buildMacrosMenu (QMenu &menu)
 Builds the "Macros" menu. More...
static void buildHelpMenu (QMenu &menu)
 Builds the help menu. More...
static void buildPipelineBrowserContextMenu (QMenu &menu, QMainWindow *window=nullptr)
 Builds the context menu shown over the pipeline browser for some common pipeline operations. More...
static void buildToolbars (QMainWindow &mainWindow)
 Builds and adds all standard ParaView toolbars. More...
Simply call the appropriate method with the menu as an argument, and it will be populated with actions and reactions for standard ParaView behavior.
Definition at line 21 of file pqParaViewMenuBuilders.h.
◆ buildFileMenu()
static void pqParaViewMenuBuilders::buildFileMenu ( QMenu &  menu)
◆ buildEditMenu()
static void pqParaViewMenuBuilders::buildEditMenu ( QMenu &  menu,
pqPropertiesPanel *  propertiesPanel = nullptr
◆ buildSourcesMenu()
static void pqParaViewMenuBuilders::buildSourcesMenu ( QMenu &  menu,
QMainWindow *  mainWindow = nullptr
If you want to automatically add toolbars for sources as requested in the configuration pass in a non-null main window.
◆ buildFiltersMenu()
static void pqParaViewMenuBuilders::buildFiltersMenu ( QMenu &  menu,
QMainWindow *  mainWindow = nullptr,
bool  hideDisabled = false,
bool  quickLaunchable = true
If you want to automatically add toolbars for filters as requested in the configuration pass in a non-null main window. If you do not want to add the actions from the filters menu to quick launch maintained by pqApplicationCore (see pqPVApplicationCore::registerForQuicklaunch), then pass quickLaunchable == false.
◆ buildExtractorsMenu()
static void pqParaViewMenuBuilders::buildExtractorsMenu ( QMenu &  menu,
◆ buildToolsMenu()
static void pqParaViewMenuBuilders::buildToolsMenu ( QMenu &  menu)
◆ buildCatalystMenu()
static void pqParaViewMenuBuilders::buildCatalystMenu ( QMenu &  menu)
◆ buildViewMenu()
static void pqParaViewMenuBuilders::buildViewMenu ( QMenu &  menu,
QMainWindow &  window
◆ buildMacrosMenu()
static void pqParaViewMenuBuilders::buildMacrosMenu ( QMenu &  menu)
This menu is automatically hidden is python support is not enabled.
◆ buildHelpMenu()
static void pqParaViewMenuBuilders::buildHelpMenu ( QMenu &  menu)
◆ buildPipelineBrowserContextMenu()
static void pqParaViewMenuBuilders::buildPipelineBrowserContextMenu ( QMenu &  menu,
QMainWindow *  window = nullptr
◆ buildToolbars()
static void pqParaViewMenuBuilders::buildToolbars ( QMainWindow &  mainWindow)
