pqOutputPortComboBox is a combo-box that shows all outputports for all sources/filters.
#include <pqOutputPortComboBox.h>
Inherits QComboBox.
Definition at line 18 of file pqOutputPortComboBox.h.
◆ pqOutputPortComboBox()
| pqOutputPortComboBox::pqOutputPortComboBox |
QWidget * |
parent = nullptr | ) |
◆ ~pqOutputPortComboBox()
| pqOutputPortComboBox::~pqOutputPortComboBox |
◆ setAutoUpdateIndex()
| void pqOutputPortComboBox::setAutoUpdateIndex |
bool |
val | ) |
Enable/Disable changing of the combo-box selected index based on the active source/port.
Default is true i.e. enabled.
Definition at line 31 of file pqOutputPortComboBox.h.
◆ autoUpdateIndex()
| bool pqOutputPortComboBox::autoUpdateIndex |
const |
◆ addCustomEntry()
| void pqOutputPortComboBox::addCustomEntry |
const QString & |
label, |
pqOutputPort * |
port |
Makes is possible to add custom items to the combo-box.
port can be nullptr.
◆ currentPort()
Returns the currently selected output port.
◆ fillExistingPorts()
| void pqOutputPortComboBox::fillExistingPorts |
May be called once after creation to initialize the widget with already existing sources.
◆ setCurrentPort
| void pqOutputPortComboBox::setCurrentPort |
pqOutputPort * |
port | ) |
slot |
Sets the current index to be the one representing the indicated port.
◆ currentIndexChanged
| void pqOutputPortComboBox::currentIndexChanged |
pqOutputPort * |
signal |
Fired when the current index changes.
◆ AutoUpdateIndex
| bool pqOutputPortComboBox::AutoUpdateIndex |
