Manage an action and/or widget's responsivity to a shortcut.
#include <pqModalShortcut.h>
Inherits QObject.
This object will add and remove a connection between a widget/action and a QShortcut as required by the pqKeySequences manager to prevent any ambiguous activations.
Definition at line 21 of file pqModalShortcut.h.
◆ Superclass
◆ ~pqModalShortcut()
| pqModalShortcut::~pqModalShortcut |
◆ pqModalShortcut()
| pqModalShortcut::pqModalShortcut |
const QKeySequence & |
key, |
QAction * |
action = nullptr, |
QWidget * |
parent = nullptr |
◆ setContextWidget()
| void pqModalShortcut::setContextWidget |
QWidget * |
contextWidget, |
Qt::ShortcutContext |
contextArea = Qt::WindowShortcut |
If the shortcut should be restricted to a particular widget (such as a pqView), use this method to set and update the widget during the life of the pqModalShortcut.
◆ isEnabled()
| bool pqModalShortcut::isEnabled |
const |
◆ setEnabled()
| void pqModalShortcut::setEnabled |
bool |
shouldEnable, |
bool |
changeFocus = true |
◆ keySequence()
| QKeySequence pqModalShortcut::keySequence |
const |
◆ enabled
| void pqModalShortcut::enabled |
signal |
Called from setEnabled() whenever it is passed true.
This is used by pqKeySequences to disable any sibling shortcuts with the same keysequence.
This may also be used by widgets to update their visual state, indicating they are now accepting shortcuts.
◆ disabled
| void pqModalShortcut::disabled |
signal |
Called from setEnabled() whenever it is passed false.
This may be used by widgets to update their visual state, indicating they are no longer accepting shortcuts.
◆ unregister
| void pqModalShortcut::unregister |
signal |
Called from the destructor.
This is used by pqKeySequences to clean its records.
◆ activated
| void pqModalShortcut::activated |
signal |
Invoked when the key sequence is pressed.
◆ pqKeySequences
◆ m_key
| QKeySequence pqModalShortcut::m_key |
◆ m_shortcut
| QPointer<QShortcut> pqModalShortcut::m_shortcut |
◆ m_action
| QPointer<QAction> pqModalShortcut::m_action |
