Public Slots | Public Member Functions | Static Public Member Functions | Protected Member Functions | List of all members
pqLoadStateReaction Class Reference
#include <pqLoadStateReaction.h>
Inheritance diagram for pqLoadStateReaction:
Collaboration diagram for pqLoadStateReaction:
Public Slots
void updateEnableState () override
 Updates the enabled state. More...
 pqLoadStateReaction (QAction *parent)
 Constructor. More...
- Public Member Functions inherited from pqReaction
 pqReaction (QAction *parent, Qt::ConnectionType type=Qt::AutoConnection)
 ~pqReaction () override
QAction * parentAction () const
 Provides access to the parent action. More...
static void loadState (const QString &filename, bool dialogBlocked=false, pqServer *server=nullptr, vtkTypeUInt32 location=0x10)
 Loads the state file. More...
static void loadState ()
static void activateView ()
 Set default active view after state is loaded. More...
void onTriggered () override
 Called when the action is triggered. More...
- Protected Slots inherited from pqReaction
virtual void updateEnableState ()
virtual void updateMasterEnableState (bool)
- Protected Attributes inherited from pqReaction
bool IsMaster
Definition at line 17 of file pqLoadStateReaction.h.
◆ pqLoadStateReaction()
pqLoadStateReaction::pqLoadStateReaction ( QAction *  parent)
Constructor.
Parent cannot be nullptr.
◆ loadState() [1/2]
static void pqLoadStateReaction::loadState ( const QString &  filename,
bool  dialogBlocked = false,
pqServer *  server = nullptr,
vtkTypeUInt32  location = 0x10
Note that this method is static. Applications can simply use this without having to create a reaction instance. If no server is specified, active server is used.
◆ loadState() [2/2]
static void pqLoadStateReaction::loadState ( )
◆ activateView()
static void pqLoadStateReaction::activateView ( )
Make the first view active.
◆ updateEnableState
void pqLoadStateReaction::updateEnableState ( )
overrideslot
◆ onTriggered()
void pqLoadStateReaction::onTriggered ( )
inlineoverrideprotectedvirtual
Definition at line 53 of file pqLoadStateReaction.h.
