#include <pqDataInformationModel.h>
Inherits QAbstractTableModel.
Definition at line 15 of file pqDataInformationModel.h.
◆ pqDataInformationModel()
| pqDataInformationModel::pqDataInformationModel |
QObject * |
_parent = nullptr | ) |
◆ ~pqDataInformationModel()
| pqDataInformationModel::~pqDataInformationModel |
◆ rowCount()
| int pqDataInformationModel::rowCount |
const QModelIndex & |
parent = QModelIndex() | ) |
const |
QAbstractTableModel API.
Returns the number of rows under the given parent.
◆ columnCount()
| int pqDataInformationModel::columnCount |
const |
Returns the number of columns for the given parent.
◆ data()
| QVariant pqDataInformationModel::data |
index, |
int |
role = Qt::DisplayRole |
| const |
Returns the data stored under the given role for the item referred to by the index.
◆ headerData()
| QVariant pqDataInformationModel::headerData |
int |
section, |
Qt::Orientation |
orientation, |
int |
| const |
Returns the data for the given role and section in the header with the specified orientation.
◆ getIndexFor()
| QModelIndex pqDataInformationModel::getIndexFor |
pqOutputPort * |
item | ) |
const |
Given a pqOutputPort, get the index for it, if present in this model, otherwise returns invalid index.
◆ getItemFor()
Given a valid index, returns the pqOutputPort item corresponding to it.
◆ flags()
| Qt::ItemFlags pqDataInformationModel::flags |
index | ) |
const |
Method needed for copy/past cell editor.
◆ setData()
| bool pqDataInformationModel::setData |
index, |
const QVariant & |
value, |
int |
role = Qt::EditRole |
◆ addSource
Called when a new source/filter is registered.
◆ removeSource
Called when a new source/filter is unregistered.
◆ setActiveView
| void pqDataInformationModel::setActiveView |
pqView * |
view | ) |
slot |
Called when the active view changes.
Need to correctly show the geometry size for the source.
