Public Slots | Public Member Functions | Protected Slots | Protected Member Functions | List of all members
pqColorMapEditor Class Reference
pqColorMapEditor is a widget that can be used to edit the active color-map, if any. More...
#include <pqColorMapEditor.h>
Inherits QWidget.
Public Slots
void setSelectedPropertiesType (int selectedPropertiesType)
 Set the selected properties type. More...
 pqColorMapEditor (QWidget *parent=nullptr)
 ~pqColorMapEditor () override
Protected Slots
void updatePanel ()
 slot called to update the visible widgets. More...
void renderViews ()
 render's view when transfer function is modified. More...
void saveAsDefault ()
 Save the current transfer function(s) as default. More...
void saveAsArrayDefault ()
 Save the current transfer function(s) as default for arrays with the same name as the selected array. More...
void restoreDefaults ()
 Restore the defaults (undoes effects of saveAsDefault()). More...
void setAutoUpdate (bool)
 called when AutoUpdate button is toggled. More...
void updateIfNeeded ()
void updateScalarBarButtons ()
 update the enabled state for show/edit scalar bar buttons. More...
void updateColorArraySelectorWidgets ()
void updateOpacityArraySelectorWidgets ()
void updateColor2ArraySelectorWidgets ()
void updateActive (bool forceUpdate)
 slot called to update the currently showing proxies. More...
void updateActive ()
void setRepresentation (pqDataRepresentation *repr, bool forceUpdate=false)
void setColorTransferFunctions (std::vector< vtkSMProxy *> ctfs)
void setColorTransferFunction (vtkSMProxy *ctf)
The panel is implemented as an auto-generated panel (similar to the Properties panel) that shows the properties on the lookup-table proxy. Custom widgets such as pqColorOpacityEditorWidget, pqColorAnnotationsPropertyWidget, and others are used to control certain properties on the proxy.
Definition at line 24 of file pqColorMapEditor.h.
◆ pqColorMapEditor()
pqColorMapEditor::pqColorMapEditor ( QWidget *  parent = nullptr)
◆ ~pqColorMapEditor()
pqColorMapEditor::~pqColorMapEditor ( )
override
◆ setSelectedPropertiesType
void pqColorMapEditor::setSelectedPropertiesType ( int  selectedPropertiesType)
slot
◆ updateActive [1/2]
void pqColorMapEditor::updateActive ( bool  forceUpdate)
protectedslot
◆ updateActive [2/2]
void pqColorMapEditor::updateActive ( )
inlineprotectedslot
Definition at line 45 of file pqColorMapEditor.h.
◆ updatePanel
void pqColorMapEditor::updatePanel ( )
protectedslot
◆ renderViews
void pqColorMapEditor::renderViews ( )
protectedslot
◆ saveAsDefault
void pqColorMapEditor::saveAsDefault ( )
protectedslot
◆ saveAsArrayDefault
void pqColorMapEditor::saveAsArrayDefault ( )
protectedslot
◆ restoreDefaults
void pqColorMapEditor::restoreDefaults ( )
protectedslot
◆ setAutoUpdate
void pqColorMapEditor::setAutoUpdate ( bool  )
protectedslot
◆ updateIfNeeded
void pqColorMapEditor::updateIfNeeded ( )
protectedslot
◆ setRepresentation()
void pqColorMapEditor::setRepresentation ( pqDataRepresentation *  repr,
bool  forceUpdate = false
◆ setColorTransferFunctions()
void pqColorMapEditor::setColorTransferFunctions ( std::vector< vtkSMProxy *>  ctfs)
◆ setColorTransferFunction()
void pqColorMapEditor::setColorTransferFunction ( vtkSMProxy *  ctf)
inlineprotected
Definition at line 84 of file pqColorMapEditor.h.
◆ updateScalarBarButtons
void pqColorMapEditor::updateScalarBarButtons ( )
protectedslot
◆ updateColorArraySelectorWidgets
void pqColorMapEditor::updateColorArraySelectorWidgets ( )
protectedslot
◆ updateOpacityArraySelectorWidgets
void pqColorMapEditor::updateOpacityArraySelectorWidgets ( )
protectedslot
◆ updateColor2ArraySelectorWidgets
void pqColorMapEditor::updateColor2ArraySelectorWidgets ( )
protectedslot
