pqColorChooserButton is a QToolButton subclass suitable for showing a a button that allows the use to select/change color.
#include <pqColorChooserButton.h>
It renders a color swatch next to the button text matching the chosen color.
Definition at line 18 of file pqColorChooserButton.h.
◆ pqColorChooserButton()
| pqColorChooserButton::pqColorChooserButton |
QWidget * |
p | ) |
constructor requires a QComboBox
◆ chosenColor()
| QColor pqColorChooserButton::chosenColor |
const |
◆ chosenColorRgbF()
| QVariantList pqColorChooserButton::chosenColorRgbF |
const |
Returns the chosen color as a QVariantList with exatctly 3 QVariants with values in the range [0, 1] for each of the 3 color components.
◆ chosenColorRgbaF()
| QVariantList pqColorChooserButton::chosenColorRgbaF |
const |
Returns the chosen color as a QVariantList with exatctly 4 QVariants with values in the range [0, 1] for each of the 4 color components.
◆ setIconRadiusHeightRatio()
| void pqColorChooserButton::setIconRadiusHeightRatio |
double |
val | ) |
◆ iconRadiusHeightRatio()
| double pqColorChooserButton::iconRadiusHeightRatio |
const |
◆ showAlphaChannel()
| bool pqColorChooserButton::showAlphaChannel |
const |
When true, the widget will allow users to choose the alpha channel.
Definition at line 58 of file pqColorChooserButton.h.
◆ setShowAlphaChannel()
| void pqColorChooserButton::setShowAlphaChannel |
bool |
val | ) |
◆ chosenColorChanged
| void pqColorChooserButton::chosenColorChanged |
const QColor & |
signal |
signal color changed.
This is fired in setChosenColor() only when the color is indeed different.
◆ validColorChosen
| void pqColorChooserButton::validColorChosen |
const QColor & |
signal |
◆ setChosenColor
| virtual void pqColorChooserButton::setChosenColor |
const QColor & |
virtualslot |
◆ setChosenColorRgbF
| void pqColorChooserButton::setChosenColorRgbF |
const QVariantList & |
slot |
set the color as a QVariantList with exactly 3 QVariants with values in the range [0, 1] for each of the 3 color components.
◆ setChosenColorRgbaF
| void pqColorChooserButton::setChosenColorRgbaF |
slot |
set the color as a QVariantList with exactly 4 QVariants with values in the range [0, 1] for each of the 4 color components.
◆ chooseColor
| virtual void pqColorChooserButton::chooseColor |
virtualslot |
show a dialog to choose the color
◆ resizeEvent()
| void pqColorChooserButton::resizeEvent |
QResizeEvent * |
rEvent | ) |
overridden to resize the color icon.
◆ renderColorSwatch()
| QIcon pqColorChooserButton::renderColorSwatch |
const QColor & |
renders an icon for the color.
◆ Color
| double pqColorChooserButton::Color[4] |
◆ IconRadiusHeightRatio
| double pqColorChooserButton::IconRadiusHeightRatio |
◆ ShowAlphaChannel
| bool pqColorChooserButton::ShowAlphaChannel |
◆ chosenColor
readwrite |
◆ chosenColorRgbF
readwrite |
◆ chosenColorRgbaF
readwrite |
◆ showAlphaChannel
readwrite |
