pqAnimationTimeWidget is a widget that can be used to show/set the current animation time.
#include <pqAnimationTimeWidget.h>
Inherits QWidget.
The widget allow the user to do the following:
- View and/or change the current time value (in seq modes), or current time step value (in snap-to-timesteps mode).
Definition at line 26 of file pqAnimationTimeWidget.h.
◆ RealNumberNotation
◆ pqAnimationTimeWidget()
| pqAnimationTimeWidget::pqAnimationTimeWidget |
QWidget * |
parent = nullptr | ) |
◆ ~pqAnimationTimeWidget()
| pqAnimationTimeWidget::~pqAnimationTimeWidget |
◆ animationScene()
| vtkSMProxy* pqAnimationTimeWidget::animationScene |
const |
Provides access to the animation scene proxy currently controlled/reflected by this widget.
◆ setAnimationScene()
| void pqAnimationTimeWidget::setAnimationScene |
pqAnimationScene * |
animationScene | ) |
Set the animation scene which is reflected/controlled by this widget.
◆ setTimestepValues()
| void pqAnimationTimeWidget::setTimestepValues |
const QList< QVariant > & |
list | ) |
Get/Set the list of timestep.
QList<QVariant> is a list of variants convertible to double.
◆ timestepValues()
| const QList<QVariant>& pqAnimationTimeWidget::timestepValues |
const |
◆ setStartTime()
| void pqAnimationTimeWidget::setStartTime |
double |
start | ) |
Get/Set the animation start time.
◆ startTime()
| double pqAnimationTimeWidget::startTime |
const |
◆ setEndTime()
| void pqAnimationTimeWidget::setEndTime |
double |
end | ) |
Get/Set the animation end time.
◆ endTime()
| double pqAnimationTimeWidget::endTime |
const |
◆ setNumberOfFrames()
| void pqAnimationTimeWidget::setNumberOfFrames |
int |
nbOfFrame | ) |
Get/Set the number of frames.
◆ numberOfFrames()
| int pqAnimationTimeWidget::numberOfFrames |
const |
◆ setCurrentTime()
| void pqAnimationTimeWidget::setCurrentTime |
double |
t | ) |
Set the current animation time.
◆ notation()
Return the notation used to display the number.
- See also
- setNotation()
◆ precision()
| int pqAnimationTimeWidget::precision |
const |
Return the precision used to display the number.
- See also
- setPrecision()
◆ setPlayMode()
| void pqAnimationTimeWidget::setPlayMode |
const QString & |
mode | ) |
Get/set the animation playback mode.
◆ playMode()
| QString pqAnimationTimeWidget::playMode |
const |
◆ setTimeLabel()
| void pqAnimationTimeWidget::setTimeLabel |
const QString & |
val | ) |
Get/set the label text to use for the "time" parameter.
◆ timeLabel()
| QString pqAnimationTimeWidget::timeLabel |
const |
◆ playModeChanged
| void pqAnimationTimeWidget::playModeChanged |
signal |
◆ dummySignal
| void pqAnimationTimeWidget::dummySignal |
signal |
◆ render
| void pqAnimationTimeWidget::render |
slot |
Re render the widget.
This can be helpful when notation/precision settings have changed.
◆ updateCurrentTime
| void pqAnimationTimeWidget::updateCurrentTime |
double |
t | ) |
protectedslot |
Update the current time in the widget GUI.
◆ playMode
readwrite |
◆ numberOfFrames
readwrite |
◆ startTime
readwrite |
◆ endTime
readwrite |
◆ timeLabel
readwrite |
◆ timestepValues
| QList<QVariant> pqAnimationTimeWidget::timestepValues |
readwrite |
