#include <vtkPVMessage.pb.h>
Inherits Message.
| enum | : int { kKeyFieldNumber = 1, kValueFieldNumber = 2 } |
| ProxyState_Annotation () | |
| ~ProxyState_Annotation () override | |
| constexpr | ProxyState_Annotation (::PROTOBUF_NAMESPACE_ID::internal::ConstantInitialized) |
| ProxyState_Annotation (const ProxyState_Annotation &from) | |
| ProxyState_Annotation (ProxyState_Annotation &&from) noexcept | |
| ProxyState_Annotation & | operator= (const ProxyState_Annotation &from) |
| ProxyState_Annotation & | operator= (ProxyState_Annotation &&from) noexcept |
| const ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet & | unknown_fields () const |
| inline ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet * | mutable_unknown_fields () |
| void | Swap (ProxyState_Annotation *other) |
| void | UnsafeArenaSwap (ProxyState_Annotation *other) |
| ProxyState_Annotation * | New (::PROTOBUF_NAMESPACE_ID::Arena *arena=nullptr) const final |
| void | CopyFrom (const ProxyState_Annotation &from) |
| void | MergeFrom (const ProxyState_Annotation &from) |
| PROTOBUF_ATTRIBUTE_REINITIALIZES void | Clear () final |
| bool | IsInitialized () const final |
| size_t | ByteSizeLong () const final |
| const char * | _InternalParse (const char *ptr, ::PROTOBUF_NAMESPACE_ID::internal::ParseContext *ctx) final |
| uint8_t * | _InternalSerialize (uint8_t *target, ::PROTOBUF_NAMESPACE_ID::io::EpsCopyOutputStream *stream) const final |
| int | GetCachedSize () const final |
| const ::PROTOBUF_NAMESPACE_ID::Message::ClassData * | GetClassData () const final |
| ::PROTOBUF_NAMESPACE_ID::Metadata | GetMetadata () const final |
| bool | has_key () const |
| void | clear_key () |
| const std::string & | key () const |
| template<typename ArgT0 = const std::string&, typename... ArgT> | |
| void | set_key (ArgT0 &&arg0, ArgT... args) |
| std::string * | mutable_key () |
| PROTOBUF_NODISCARD std::string * | release_key () |
| void | set_allocated_key (std::string *key) |
| bool | has_value () const |
| void | clear_value () |
| const std::string & | value () const |
| void | set_value (ArgT0 &&arg0, ArgT... args) |
| std::string * | mutable_value () |
| PROTOBUF_NODISCARD std::string * | release_value () |
| void | set_allocated_value (std::string *value) |
| template<typename ArgT0 , typename... ArgT> | |
| PROTOBUF_ALWAYS_INLINE void | set_key (ArgT0 &&arg0, ArgT... args) |
| PROTOBUF_ALWAYS_INLINE void | set_value (ArgT0 &&arg0, ArgT... args) |
| static const ::PROTOBUF_NAMESPACE_ID::Descriptor * | descriptor () |
| static const ::PROTOBUF_NAMESPACE_ID::Descriptor * | GetDescriptor () |
| static const ::PROTOBUF_NAMESPACE_ID::Reflection * | GetReflection () |
| static const ProxyState_Annotation & | default_instance () |
| static const ProxyState_Annotation * | internal_default_instance () |
Static Public Attributes | |
| static constexpr int | kIndexInFileMessages |
| static const ClassData | _class_data_ |
| ProxyState_Annotation (::PROTOBUF_NAMESPACE_ID::Arena *arena, bool is_message_owned=false) | |
Friends | |
| class | ::PROTOBUF_NAMESPACE_ID::internal::AnyMetadata |
| template<typename T > | |
| class | ::PROTOBUF_NAMESPACE_ID::Arena::InternalHelper |
| struct | ::TableStruct_vtkPVMessage_2eproto |
| void | swap (ProxyState_Annotation &a, ProxyState_Annotation &b) |
Definition at line 1685 of file vtkPVMessage.pb.h.
| anonymous enum : int |
| Enumerator | |
| kKeyFieldNumber | |
| kValueFieldNumber | |
Definition at line 1813 of file vtkPVMessage.pb.h.
Definition at line 1688 of file vtkPVMessage.pb.h.
explicit |
| paraview_protobuf::ProxyState_Annotation::ProxyState_Annotation | ( | const ProxyState_Annotation & | from | ) |
inlinenoexcept |
Definition at line 1693 of file vtkPVMessage.pb.h.
explicitprotected |
Definition at line 1698 of file vtkPVMessage.pb.h.
inlinenoexcept |
Definition at line 1702 of file vtkPVMessage.pb.h.
Definition at line 1716 of file vtkPVMessage.pb.h.
Definition at line 1719 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 1723 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 1726 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 1729 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 1732 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 1735 of file vtkPVMessage.pb.h.
Definition at line 1745 of file vtkPVMessage.pb.h.
Definition at line 1758 of file vtkPVMessage.pb.h.
inlinefinal |
Definition at line 1766 of file vtkPVMessage.pb.h.
| void paraview_protobuf::ProxyState_Annotation::CopyFrom | ( | const ProxyState_Annotation & | from | ) |
| void paraview_protobuf::ProxyState_Annotation::MergeFrom | ( | const ProxyState_Annotation & | from | ) |
final |
final |
final |
final |
final |
inlinefinal |
Definition at line 1783 of file vtkPVMessage.pb.h.
final |
final |
Definition at line 5493 of file vtkPVMessage.pb.h.
Definition at line 5496 of file vtkPVMessage.pb.h.
Definition at line 5500 of file vtkPVMessage.pb.h.
| void paraview_protobuf::ProxyState_Annotation::set_key | ( | ArgT0 && | arg0, |
| ArgT... | args | ||
Definition at line 5511 of file vtkPVMessage.pb.h.
Definition at line 5527 of file vtkPVMessage.pb.h.
Definition at line 5541 of file vtkPVMessage.pb.h.
Definition at line 5562 of file vtkPVMessage.pb.h.
Definition at line 5565 of file vtkPVMessage.pb.h.
Definition at line 5569 of file vtkPVMessage.pb.h.
| void paraview_protobuf::ProxyState_Annotation::set_value | ( | ArgT0 && | arg0, |
| ArgT... | args | ||
Definition at line 5580 of file vtkPVMessage.pb.h.
Definition at line 5596 of file vtkPVMessage.pb.h.
Definition at line 5610 of file vtkPVMessage.pb.h.
Definition at line 5506 of file vtkPVMessage.pb.h.
Definition at line 5575 of file vtkPVMessage.pb.h.
friend |
Definition at line 1792 of file vtkPVMessage.pb.h.
friend |
Definition at line 1860 of file vtkPVMessage.pb.h.
friend |
Definition at line 1867 of file vtkPVMessage.pb.h.
friend |
Definition at line 1742 of file vtkPVMessage.pb.h.
Definition at line 1739 of file vtkPVMessage.pb.h.
Definition at line 1804 of file vtkPVMessage.pb.h.
