Public Types | Public Member Functions | Static Public Member Functions | Static Public Attributes | Protected Member Functions | Friends | List of all members
paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition Class Referencefinal
#include <vtkPVMessage.pb.h>
Inherits Message.
enum  : int { kGroupFieldNumber = 1, kNameFieldNumber = 2, kXmlFieldNumber = 3 }
 ProxyDefinitionState_ProxyXMLDefinition ()
 ~ProxyDefinitionState_ProxyXMLDefinition () override
constexpr ProxyDefinitionState_ProxyXMLDefinition (::PROTOBUF_NAMESPACE_ID::internal::ConstantInitialized)
 ProxyDefinitionState_ProxyXMLDefinition (const ProxyDefinitionState_ProxyXMLDefinition &from)
 ProxyDefinitionState_ProxyXMLDefinition (ProxyDefinitionState_ProxyXMLDefinition &&from) noexcept
ProxyDefinitionState_ProxyXMLDefinition & operator= (const ProxyDefinitionState_ProxyXMLDefinition &from)
ProxyDefinitionState_ProxyXMLDefinition & operator= (ProxyDefinitionState_ProxyXMLDefinition &&from) noexcept
const ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet & unknown_fields () const
inline ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet * mutable_unknown_fields ()
void Swap (ProxyDefinitionState_ProxyXMLDefinition *other)
void UnsafeArenaSwap (ProxyDefinitionState_ProxyXMLDefinition *other)
ProxyDefinitionState_ProxyXMLDefinition * New (::PROTOBUF_NAMESPACE_ID::Arena *arena=nullptr) const final
void CopyFrom (const ProxyDefinitionState_ProxyXMLDefinition &from)
void MergeFrom (const ProxyDefinitionState_ProxyXMLDefinition &from)
PROTOBUF_ATTRIBUTE_REINITIALIZES void Clear () final
bool IsInitialized () const final
size_t ByteSizeLong () const final
const char * _InternalParse (const char *ptr, ::PROTOBUF_NAMESPACE_ID::internal::ParseContext *ctx) final
uint8_t * _InternalSerialize (uint8_t *target, ::PROTOBUF_NAMESPACE_ID::io::EpsCopyOutputStream *stream) const final
int GetCachedSize () const final
const ::PROTOBUF_NAMESPACE_ID::Message::ClassData * GetClassData () const final
::PROTOBUF_NAMESPACE_ID::Metadata GetMetadata () const final
bool has_group () const
void clear_group ()
const std::string & group () const
template<typename ArgT0 = const std::string&, typename... ArgT>
void set_group (ArgT0 &&arg0, ArgT... args)
std::string * mutable_group ()
PROTOBUF_NODISCARD std::string * release_group ()
void set_allocated_group (std::string *group)
bool has_name () const
void clear_name ()
const std::string & name () const
void set_name (ArgT0 &&arg0, ArgT... args)
std::string * mutable_name ()
PROTOBUF_NODISCARD std::string * release_name ()
void set_allocated_name (std::string *name)
bool has_xml () const
void clear_xml ()
const std::string & xml () const
void set_xml (ArgT0 &&arg0, ArgT... args)
std::string * mutable_xml ()
PROTOBUF_NODISCARD std::string * release_xml ()
void set_allocated_xml (std::string *xml)
template<typename ArgT0 , typename... ArgT>
PROTOBUF_ALWAYS_INLINE void set_group (ArgT0 &&arg0, ArgT... args)
PROTOBUF_ALWAYS_INLINE void set_name (ArgT0 &&arg0, ArgT... args)
PROTOBUF_ALWAYS_INLINE void set_xml (ArgT0 &&arg0, ArgT... args)
static const ::PROTOBUF_NAMESPACE_ID::Descriptor * descriptor ()
static const ::PROTOBUF_NAMESPACE_ID::Descriptor * GetDescriptor ()
static const ::PROTOBUF_NAMESPACE_ID::Reflection * GetReflection ()
static const ProxyDefinitionState_ProxyXMLDefinition & default_instance ()
static const ProxyDefinitionState_ProxyXMLDefinition * internal_default_instance ()
static constexpr int kIndexInFileMessages
static const ClassData _class_data_
 ProxyDefinitionState_ProxyXMLDefinition (::PROTOBUF_NAMESPACE_ID::Arena *arena, bool is_message_owned=false)
Friends
class ::PROTOBUF_NAMESPACE_ID::internal::AnyMetadata
template<typename T >
class ::PROTOBUF_NAMESPACE_ID::Arena::InternalHelper
struct ::TableStruct_vtkPVMessage_2eproto
void swap (ProxyDefinitionState_ProxyXMLDefinition &a, ProxyDefinitionState_ProxyXMLDefinition &b)
Definition at line 2767 of file vtkPVMessage.pb.h.
◆ anonymous enum
anonymous enum : int
Enumerator
kGroupFieldNumber
kNameFieldNumber
kXmlFieldNumber
Definition at line 2895 of file vtkPVMessage.pb.h.
◆ ProxyDefinitionState_ProxyXMLDefinition() [1/5]
paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::ProxyDefinitionState_ProxyXMLDefinition ( )
inline
Definition at line 2770 of file vtkPVMessage.pb.h.
◆ ~ProxyDefinitionState_ProxyXMLDefinition()
paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::~ProxyDefinitionState_ProxyXMLDefinition ( )
override
◆ ProxyDefinitionState_ProxyXMLDefinition() [2/5]
constexpr paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::ProxyDefinitionState_ProxyXMLDefinition ( ::PROTOBUF_NAMESPACE_ID::internal::ConstantInitialized  )
explicit
◆ ProxyDefinitionState_ProxyXMLDefinition() [3/5]
paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::ProxyDefinitionState_ProxyXMLDefinition ( const ProxyDefinitionState_ProxyXMLDefinition &  from)
◆ ProxyDefinitionState_ProxyXMLDefinition() [4/5]
paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::ProxyDefinitionState_ProxyXMLDefinition ( ProxyDefinitionState_ProxyXMLDefinition &&  from)
inlinenoexcept
Definition at line 2775 of file vtkPVMessage.pb.h.
◆ ProxyDefinitionState_ProxyXMLDefinition() [5/5]
paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::ProxyDefinitionState_ProxyXMLDefinition ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena,
bool  is_message_owned = false
explicitprotected
◆ operator=() [1/2]
ProxyDefinitionState_ProxyXMLDefinition& paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::operator= ( const ProxyDefinitionState_ProxyXMLDefinition &  from)
inline
Definition at line 2780 of file vtkPVMessage.pb.h.
◆ operator=() [2/2]
ProxyDefinitionState_ProxyXMLDefinition& paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::operator= ( ProxyDefinitionState_ProxyXMLDefinition &&  from)
inlinenoexcept
Definition at line 2784 of file vtkPVMessage.pb.h.
◆ unknown_fields()
const ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet& paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::unknown_fields ( ) const
inline
Definition at line 2798 of file vtkPVMessage.pb.h.
◆ mutable_unknown_fields()
inline ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet* paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::mutable_unknown_fields ( )
inline
Definition at line 2801 of file vtkPVMessage.pb.h.
◆ descriptor()
static const ::PROTOBUF_NAMESPACE_ID::Descriptor* paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::descriptor ( )
inlinestatic
Definition at line 2805 of file vtkPVMessage.pb.h.
◆ GetDescriptor()
static const ::PROTOBUF_NAMESPACE_ID::Descriptor* paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::GetDescriptor ( )
inlinestatic
Definition at line 2808 of file vtkPVMessage.pb.h.
◆ GetReflection()
static const ::PROTOBUF_NAMESPACE_ID::Reflection* paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::GetReflection ( )
inlinestatic
Definition at line 2811 of file vtkPVMessage.pb.h.
◆ default_instance()
static const ProxyDefinitionState_ProxyXMLDefinition& paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::default_instance ( )
inlinestatic
Definition at line 2814 of file vtkPVMessage.pb.h.
◆ internal_default_instance()
static const ProxyDefinitionState_ProxyXMLDefinition* paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::internal_default_instance ( )
inlinestatic
Definition at line 2817 of file vtkPVMessage.pb.h.
◆ Swap()
void paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::Swap ( ProxyDefinitionState_ProxyXMLDefinition *  other)
inline
Definition at line 2827 of file vtkPVMessage.pb.h.
◆ UnsafeArenaSwap()
void paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::UnsafeArenaSwap ( ProxyDefinitionState_ProxyXMLDefinition *  other)
inline
Definition at line 2840 of file vtkPVMessage.pb.h.
ProxyDefinitionState_ProxyXMLDefinition* paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::New ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena = nullptr) const
inlinefinal
Definition at line 2848 of file vtkPVMessage.pb.h.
◆ CopyFrom()
void paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::CopyFrom ( const ProxyDefinitionState_ProxyXMLDefinition &  from)
◆ MergeFrom()
void paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::MergeFrom ( const ProxyDefinitionState_ProxyXMLDefinition &  from)
◆ Clear()
PROTOBUF_ATTRIBUTE_REINITIALIZES void paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::Clear ( )
final
◆ IsInitialized()
bool paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::IsInitialized ( ) const
final
◆ ByteSizeLong()
size_t paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::ByteSizeLong ( ) const
final
◆ _InternalParse()
const char* paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::_InternalParse ( const char *  ptr,
::PROTOBUF_NAMESPACE_ID::internal::ParseContext *  ctx
final
◆ _InternalSerialize()
uint8_t* paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::_InternalSerialize ( uint8_t *  target,
::PROTOBUF_NAMESPACE_ID::io::EpsCopyOutputStream *  stream
) const
final
◆ GetCachedSize()
int paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::GetCachedSize ( ) const
inlinefinal
Definition at line 2865 of file vtkPVMessage.pb.h.
◆ GetClassData()
const ::PROTOBUF_NAMESPACE_ID::Message::ClassData* paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::GetClassData ( ) const
final
◆ GetMetadata()
::PROTOBUF_NAMESPACE_ID::Metadata paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::GetMetadata ( ) const
final
◆ has_group()
bool paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::has_group ( ) const
inline
Definition at line 6129 of file vtkPVMessage.pb.h.
◆ clear_group()
void paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::clear_group ( )
inline
Definition at line 6132 of file vtkPVMessage.pb.h.
◆ group()
const std::string & paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::group ( ) const
inline
Definition at line 6136 of file vtkPVMessage.pb.h.
◆ set_group() [1/2]
void paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::set_group ( ArgT0 &&  arg0,
ArgT...  args
◆ mutable_group()
std::string * paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::mutable_group ( )
inline
Definition at line 6147 of file vtkPVMessage.pb.h.
◆ release_group()
std::string * paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::release_group ( )
inline
Definition at line 6163 of file vtkPVMessage.pb.h.
◆ set_allocated_group()
void paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::set_allocated_group ( std::string *  group)
inline
Definition at line 6177 of file vtkPVMessage.pb.h.
◆ has_name()
bool paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::has_name ( ) const
inline
Definition at line 6198 of file vtkPVMessage.pb.h.
◆ clear_name()
void paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::clear_name ( )
inline
Definition at line 6201 of file vtkPVMessage.pb.h.
◆ name()
const std::string & paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::name ( ) const
inline
Definition at line 6205 of file vtkPVMessage.pb.h.
◆ set_name() [1/2]
void paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::set_name ( ArgT0 &&  arg0,
ArgT...  args
◆ mutable_name()
std::string * paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::mutable_name ( )
inline
Definition at line 6216 of file vtkPVMessage.pb.h.
◆ release_name()
std::string * paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::release_name ( )
inline
Definition at line 6232 of file vtkPVMessage.pb.h.
◆ set_allocated_name()
void paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::set_allocated_name ( std::string *  name)
inline
Definition at line 6246 of file vtkPVMessage.pb.h.
◆ has_xml()
bool paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::has_xml ( ) const
inline
Definition at line 6267 of file vtkPVMessage.pb.h.
◆ clear_xml()
void paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::clear_xml ( )
inline
Definition at line 6270 of file vtkPVMessage.pb.h.
◆ xml()
const std::string & paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::xml ( ) const
inline
Definition at line 6274 of file vtkPVMessage.pb.h.
◆ set_xml() [1/2]
void paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::set_xml ( ArgT0 &&  arg0,
ArgT...  args
◆ mutable_xml()
std::string * paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::mutable_xml ( )
inline
Definition at line 6285 of file vtkPVMessage.pb.h.
◆ release_xml()
std::string * paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::release_xml ( )
inline
Definition at line 6301 of file vtkPVMessage.pb.h.
◆ set_allocated_xml()
void paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::set_allocated_xml ( std::string *  xml)
inline
Definition at line 6315 of file vtkPVMessage.pb.h.
◆ set_group() [2/2]
PROTOBUF_ALWAYS_INLINE void paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::set_group ( ArgT0 &&  arg0,
ArgT...  args
inline
Definition at line 6142 of file vtkPVMessage.pb.h.
◆ set_name() [2/2]
PROTOBUF_ALWAYS_INLINE void paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::set_name ( ArgT0 &&  arg0,
ArgT...  args
inline
Definition at line 6211 of file vtkPVMessage.pb.h.
◆ set_xml() [2/2]
PROTOBUF_ALWAYS_INLINE void paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::set_xml ( ArgT0 &&  arg0,
ArgT...  args
inline
Definition at line 6280 of file vtkPVMessage.pb.h.
◆ ::PROTOBUF_NAMESPACE_ID::internal::AnyMetadata
friend class ::PROTOBUF_NAMESPACE_ID::internal::AnyMetadata
friend
Definition at line 2874 of file vtkPVMessage.pb.h.
◆ ::PROTOBUF_NAMESPACE_ID::Arena::InternalHelper
friend class ::PROTOBUF_NAMESPACE_ID::Arena::InternalHelper
friend
Definition at line 2961 of file vtkPVMessage.pb.h.
◆ ::TableStruct_vtkPVMessage_2eproto
friend struct ::TableStruct_vtkPVMessage_2eproto
friend
Definition at line 2969 of file vtkPVMessage.pb.h.
◆ swap
Definition at line 2824 of file vtkPVMessage.pb.h.
◆ kIndexInFileMessages
constexpr int paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::kIndexInFileMessages
Initial value:
12
Definition at line 2821 of file vtkPVMessage.pb.h.
◆ _class_data_
const ClassData paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::_class_data_
Definition at line 2886 of file vtkPVMessage.pb.h.
