#include <vtkPVMessage.pb.h>
Inherits Message.
| enum | : int { kGroupFieldNumber = 1, kNameFieldNumber = 2, kGlobalIdFieldNumber = 3 } |
| PXMRegistrationState_Entry () | |
| ~PXMRegistrationState_Entry () override | |
| constexpr | PXMRegistrationState_Entry (::PROTOBUF_NAMESPACE_ID::internal::ConstantInitialized) |
| PXMRegistrationState_Entry (const PXMRegistrationState_Entry &from) | |
| PXMRegistrationState_Entry (PXMRegistrationState_Entry &&from) noexcept | |
| PXMRegistrationState_Entry & | operator= (const PXMRegistrationState_Entry &from) |
| PXMRegistrationState_Entry & | operator= (PXMRegistrationState_Entry &&from) noexcept |
| const ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet & | unknown_fields () const |
| inline ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet * | mutable_unknown_fields () |
| void | Swap (PXMRegistrationState_Entry *other) |
| void | UnsafeArenaSwap (PXMRegistrationState_Entry *other) |
| PXMRegistrationState_Entry * | New (::PROTOBUF_NAMESPACE_ID::Arena *arena=nullptr) const final |
| void | CopyFrom (const PXMRegistrationState_Entry &from) |
| void | MergeFrom (const PXMRegistrationState_Entry &from) |
| PROTOBUF_ATTRIBUTE_REINITIALIZES void | Clear () final |
| bool | IsInitialized () const final |
| size_t | ByteSizeLong () const final |
| const char * | _InternalParse (const char *ptr, ::PROTOBUF_NAMESPACE_ID::internal::ParseContext *ctx) final |
| uint8_t * | _InternalSerialize (uint8_t *target, ::PROTOBUF_NAMESPACE_ID::io::EpsCopyOutputStream *stream) const final |
| int | GetCachedSize () const final |
| const ::PROTOBUF_NAMESPACE_ID::Message::ClassData * | GetClassData () const final |
| ::PROTOBUF_NAMESPACE_ID::Metadata | GetMetadata () const final |
| bool | has_group () const |
| void | clear_group () |
| const std::string & | group () const |
| template<typename ArgT0 = const std::string&, typename... ArgT> | |
| void | set_group (ArgT0 &&arg0, ArgT... args) |
| std::string * | mutable_group () |
| PROTOBUF_NODISCARD std::string * | release_group () |
| void | set_allocated_group (std::string *group) |
| bool | has_name () const |
| void | clear_name () |
| const std::string & | name () const |
| void | set_name (ArgT0 &&arg0, ArgT... args) |
| std::string * | mutable_name () |
| PROTOBUF_NODISCARD std::string * | release_name () |
| void | set_allocated_name (std::string *name) |
| bool | has_global_id () const |
| void | clear_global_id () |
| uint64_t | global_id () const |
| void | set_global_id (uint64_t value) |
| template<typename ArgT0 , typename... ArgT> | |
| PROTOBUF_ALWAYS_INLINE void | set_group (ArgT0 &&arg0, ArgT... args) |
| PROTOBUF_ALWAYS_INLINE void | set_name (ArgT0 &&arg0, ArgT... args) |
| static const ::PROTOBUF_NAMESPACE_ID::Descriptor * | descriptor () |
| static const ::PROTOBUF_NAMESPACE_ID::Descriptor * | GetDescriptor () |
| static const ::PROTOBUF_NAMESPACE_ID::Reflection * | GetReflection () |
| static const PXMRegistrationState_Entry & | default_instance () |
| static const PXMRegistrationState_Entry * | internal_default_instance () |
Static Public Attributes | |
| static constexpr int | kIndexInFileMessages |
| static const ClassData | _class_data_ |
| PXMRegistrationState_Entry (::PROTOBUF_NAMESPACE_ID::Arena *arena, bool is_message_owned=false) | |
Friends | |
| class | ::PROTOBUF_NAMESPACE_ID::internal::AnyMetadata |
| template<typename T > | |
| class | ::PROTOBUF_NAMESPACE_ID::Arena::InternalHelper |
| struct | ::TableStruct_vtkPVMessage_2eproto |
| void | swap (PXMRegistrationState_Entry &a, PXMRegistrationState_Entry &b) |
Definition at line 2427 of file vtkPVMessage.pb.h.
| anonymous enum : int |
| Enumerator | |
| kGroupFieldNumber | |
| kNameFieldNumber | |
| kGlobalIdFieldNumber | |
Definition at line 2555 of file vtkPVMessage.pb.h.
Definition at line 2430 of file vtkPVMessage.pb.h.
explicit |
| paraview_protobuf::PXMRegistrationState_Entry::PXMRegistrationState_Entry | ( | const PXMRegistrationState_Entry & | from | ) |
inlinenoexcept |
Definition at line 2435 of file vtkPVMessage.pb.h.
explicitprotected |
Definition at line 2440 of file vtkPVMessage.pb.h.
inlinenoexcept |
Definition at line 2444 of file vtkPVMessage.pb.h.
Definition at line 2458 of file vtkPVMessage.pb.h.
Definition at line 2461 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 2465 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 2468 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 2471 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 2474 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 2477 of file vtkPVMessage.pb.h.
Definition at line 2487 of file vtkPVMessage.pb.h.
Definition at line 2500 of file vtkPVMessage.pb.h.
inlinefinal |
Definition at line 2508 of file vtkPVMessage.pb.h.
| void paraview_protobuf::PXMRegistrationState_Entry::CopyFrom | ( | const PXMRegistrationState_Entry & | from | ) |
| void paraview_protobuf::PXMRegistrationState_Entry::MergeFrom | ( | const PXMRegistrationState_Entry & | from | ) |
final |
final |
final |
final |
final |
inlinefinal |
Definition at line 2525 of file vtkPVMessage.pb.h.
final |
final |
Definition at line 5955 of file vtkPVMessage.pb.h.
Definition at line 5958 of file vtkPVMessage.pb.h.
Definition at line 5962 of file vtkPVMessage.pb.h.
| void paraview_protobuf::PXMRegistrationState_Entry::set_group | ( | ArgT0 && | arg0, |
| ArgT... | args | ||
Definition at line 5973 of file vtkPVMessage.pb.h.
Definition at line 5989 of file vtkPVMessage.pb.h.
Definition at line 6003 of file vtkPVMessage.pb.h.
Definition at line 6024 of file vtkPVMessage.pb.h.
Definition at line 6027 of file vtkPVMessage.pb.h.
Definition at line 6031 of file vtkPVMessage.pb.h.
| void paraview_protobuf::PXMRegistrationState_Entry::set_name | ( | ArgT0 && | arg0, |
| ArgT... | args | ||
Definition at line 6042 of file vtkPVMessage.pb.h.
Definition at line 6058 of file vtkPVMessage.pb.h.
Definition at line 6072 of file vtkPVMessage.pb.h.
Definition at line 6093 of file vtkPVMessage.pb.h.
Definition at line 6096 of file vtkPVMessage.pb.h.
Definition at line 6103 of file vtkPVMessage.pb.h.
Definition at line 6111 of file vtkPVMessage.pb.h.
Definition at line 5968 of file vtkPVMessage.pb.h.
Definition at line 6037 of file vtkPVMessage.pb.h.
friend |
Definition at line 2534 of file vtkPVMessage.pb.h.
friend |
Definition at line 2616 of file vtkPVMessage.pb.h.
friend |
Definition at line 2624 of file vtkPVMessage.pb.h.
friend |
Definition at line 2484 of file vtkPVMessage.pb.h.
Definition at line 2481 of file vtkPVMessage.pb.h.
Definition at line 2546 of file vtkPVMessage.pb.h.
1.8.13 on Sat Aug 29 2026
