Inherits Message.
| | Message () |
| | ~Message () override |
| constexpr | Message (::PROTOBUF_NAMESPACE_ID::internal::ConstantInitialized) |
| | Message (const Message &from) |
| | Message (Message &&from) noexcept |
| Message & | operator= (const Message &from) |
| Message & | operator= (Message &&from) noexcept |
| const ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet & | unknown_fields () const |
| inline ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet * | mutable_unknown_fields () |
| void | Swap (Message *other) |
| void | UnsafeArenaSwap (Message *other) |
| Message * | New (::PROTOBUF_NAMESPACE_ID::Arena *arena=nullptr) const final |
| void | CopyFrom (const Message &from) |
| void | MergeFrom (const Message &from) |
| PROTOBUF_ATTRIBUTE_REINITIALIZES void | Clear () final |
| bool | IsInitialized () const final |
| size_t | ByteSizeLong () const final |
| const char * | _InternalParse (const char *ptr, ::PROTOBUF_NAMESPACE_ID::internal::ParseContext *ctx) final |
| uint8_t * | _InternalSerialize (uint8_t *target, ::PROTOBUF_NAMESPACE_ID::io::EpsCopyOutputStream *stream) const final |
| int | GetCachedSize () const final |
| const ::PROTOBUF_NAMESPACE_ID::Message::ClassData * | GetClassData () const final |
| ::PROTOBUF_NAMESPACE_ID::Metadata | GetMetadata () const final |
| bool | has_global_id () const |
| void | clear_global_id () |
| uint64_t | global_id () const |
| void | set_global_id (uint64_t value) |
| bool | has_location () const |
| void | clear_location () |
| uint32_t | location () const |
| void | set_location (uint32_t value) |
| bool | has_share_only () const |
| void | clear_share_only () |
| bool | share_only () const |
| void | set_share_only (bool value) |
| bool | has_req_def () const |
| void | clear_req_def () |
| bool | req_def () const |
| void | set_req_def (bool value) |
| bool | has_client_id () const |
| void | clear_client_id () |
| uint32_t | client_id () const |
| void | set_client_id (uint32_t value) |
| template<typename _proto_TypeTraits , ::PROTOBUF_NAMESPACE_ID::internal::FieldType _field_type, bool _is_packed> |
| bool | HasExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id) const |
| void | ClearExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id) |
| int | ExtensionSize (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id) const |
| _proto_TypeTraits::Singular::ConstType | GetExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id) const |
| _proto_TypeTraits::Singular::MutableType | MutableExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id) |
| void | SetExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id, typename _proto_TypeTraits::Singular::ConstType value) |
| void | SetAllocatedExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id, typename _proto_TypeTraits::Singular::MutableType value) |
| void | UnsafeArenaSetAllocatedExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id, typename _proto_TypeTraits::Singular::MutableType value) |
| PROTOBUF_NODISCARD _proto_TypeTraits::Singular::MutableType | ReleaseExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id) |
| _proto_TypeTraits::Singular::MutableType | UnsafeArenaReleaseExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id) |
| _proto_TypeTraits::Repeated::ConstType | GetExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id, int index) const |
| _proto_TypeTraits::Repeated::MutableType | MutableExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id, int index) |
| void | SetExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id, int index, typename _proto_TypeTraits::Repeated::ConstType value) |
| _proto_TypeTraits::Repeated::MutableType | AddExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id) |
| void | AddExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id, typename _proto_TypeTraits::Repeated::ConstType value) |
| const _proto_TypeTraits::Repeated::RepeatedFieldType & | GetRepeatedExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id) const |
| _proto_TypeTraits::Repeated::RepeatedFieldType * | MutableRepeatedExtension (const ::PROTOBUF_NAMESPACE_ID::internal::ExtensionIdentifier< Message, _proto_TypeTraits, _field_type, _is_packed > &id) |
