Public Types | Public Member Functions | Static Public Member Functions | Static Public Attributes | Protected Member Functions | Friends | List of all members
paraview_protobuf::LinkState_LinkDescription Class Referencefinal
#include <vtkPVMessage.pb.h>
Inherits Message.
enum  : int { kPropertyNameFieldNumber = 2, kProxyFieldNumber = 1, kDirectionFieldNumber = 3 }
typedef LinkState_LinkDescription_Direction Direction
 LinkState_LinkDescription ()
 ~LinkState_LinkDescription () override
constexpr LinkState_LinkDescription (::PROTOBUF_NAMESPACE_ID::internal::ConstantInitialized)
 LinkState_LinkDescription (const LinkState_LinkDescription &from)
 LinkState_LinkDescription (LinkState_LinkDescription &&from) noexcept
LinkState_LinkDescription & operator= (const LinkState_LinkDescription &from)
LinkState_LinkDescription & operator= (LinkState_LinkDescription &&from) noexcept
const ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet & unknown_fields () const
inline ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet * mutable_unknown_fields ()
void Swap (LinkState_LinkDescription *other)
void UnsafeArenaSwap (LinkState_LinkDescription *other)
LinkState_LinkDescription * New (::PROTOBUF_NAMESPACE_ID::Arena *arena=nullptr) const final
void CopyFrom (const LinkState_LinkDescription &from)
void MergeFrom (const LinkState_LinkDescription &from)
PROTOBUF_ATTRIBUTE_REINITIALIZES void Clear () final
bool IsInitialized () const final
size_t ByteSizeLong () const final
const char * _InternalParse (const char *ptr, ::PROTOBUF_NAMESPACE_ID::internal::ParseContext *ctx) final
uint8_t * _InternalSerialize (uint8_t *target, ::PROTOBUF_NAMESPACE_ID::io::EpsCopyOutputStream *stream) const final
int GetCachedSize () const final
const ::PROTOBUF_NAMESPACE_ID::Message::ClassData * GetClassData () const final
::PROTOBUF_NAMESPACE_ID::Metadata GetMetadata () const final
bool has_property_name () const
void clear_property_name ()
const std::string & property_name () const
template<typename ArgT0 = const std::string&, typename... ArgT>
void set_property_name (ArgT0 &&arg0, ArgT... args)
std::string * mutable_property_name ()
PROTOBUF_NODISCARD std::string * release_property_name ()
void set_allocated_property_name (std::string *property_name)
bool has_proxy () const
void clear_proxy ()
uint32_t proxy () const
void set_proxy (uint32_t value)
bool has_direction () const
void clear_direction ()
::paraview_protobuf::LinkState_LinkDescription_Direction direction () const
void set_direction (::paraview_protobuf::LinkState_LinkDescription_Direction value)
template<typename ArgT0 , typename... ArgT>
PROTOBUF_ALWAYS_INLINE void set_property_name (ArgT0 &&arg0, ArgT... args)
static const ::PROTOBUF_NAMESPACE_ID::Descriptor * descriptor ()
static const ::PROTOBUF_NAMESPACE_ID::Descriptor * GetDescriptor ()
static const ::PROTOBUF_NAMESPACE_ID::Reflection * GetReflection ()
static const LinkState_LinkDescription & default_instance ()
static const LinkState_LinkDescription * internal_default_instance ()
static bool Direction_IsValid (int value)
static const ::PROTOBUF_NAMESPACE_ID::EnumDescriptor * Direction_descriptor ()
template<typename T >
static const std::string & Direction_Name (T enum_t_value)
static bool Direction_Parse (::PROTOBUF_NAMESPACE_ID::ConstStringParam name, Direction *value)
static constexpr int kIndexInFileMessages
static const ClassData _class_data_
static constexpr Direction NONE
static constexpr Direction INPUT
static constexpr Direction OUTPUT
static constexpr Direction Direction_MIN
static constexpr Direction Direction_MAX
static constexpr int Direction_ARRAYSIZE
 LinkState_LinkDescription (::PROTOBUF_NAMESPACE_ID::Arena *arena, bool is_message_owned=false)
Friends
class ::PROTOBUF_NAMESPACE_ID::internal::AnyMetadata
class ::PROTOBUF_NAMESPACE_ID::Arena::InternalHelper
struct ::TableStruct_vtkPVMessage_2eproto
void swap (LinkState_LinkDescription &a, LinkState_LinkDescription &b)
Definition at line 3378 of file vtkPVMessage.pb.h.
◆ Direction
Definition at line 3504 of file vtkPVMessage.pb.h.
◆ anonymous enum
anonymous enum : int
Enumerator
kProxyFieldNumber
Definition at line 3538 of file vtkPVMessage.pb.h.
◆ LinkState_LinkDescription() [1/5]
paraview_protobuf::LinkState_LinkDescription::LinkState_LinkDescription ( )
inline
Definition at line 3381 of file vtkPVMessage.pb.h.
◆ ~LinkState_LinkDescription()
paraview_protobuf::LinkState_LinkDescription::~LinkState_LinkDescription ( )
override
◆ LinkState_LinkDescription() [2/5]
constexpr paraview_protobuf::LinkState_LinkDescription::LinkState_LinkDescription ( ::PROTOBUF_NAMESPACE_ID::internal::ConstantInitialized  )
explicit
◆ LinkState_LinkDescription() [3/5]
paraview_protobuf::LinkState_LinkDescription::LinkState_LinkDescription ( const LinkState_LinkDescription &  from)
◆ LinkState_LinkDescription() [4/5]
paraview_protobuf::LinkState_LinkDescription::LinkState_LinkDescription ( LinkState_LinkDescription &&  from)
inlinenoexcept
Definition at line 3386 of file vtkPVMessage.pb.h.
◆ LinkState_LinkDescription() [5/5]
paraview_protobuf::LinkState_LinkDescription::LinkState_LinkDescription ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena,
bool  is_message_owned = false
explicitprotected
◆ operator=() [1/2]
LinkState_LinkDescription& paraview_protobuf::LinkState_LinkDescription::operator= ( const LinkState_LinkDescription &  from)
inline
Definition at line 3391 of file vtkPVMessage.pb.h.
◆ operator=() [2/2]
LinkState_LinkDescription& paraview_protobuf::LinkState_LinkDescription::operator= ( LinkState_LinkDescription &&  from)
inlinenoexcept
Definition at line 3395 of file vtkPVMessage.pb.h.
◆ unknown_fields()
const ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet& paraview_protobuf::LinkState_LinkDescription::unknown_fields ( ) const
inline
Definition at line 3409 of file vtkPVMessage.pb.h.
◆ mutable_unknown_fields()
inline ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet* paraview_protobuf::LinkState_LinkDescription::mutable_unknown_fields ( )
inline
Definition at line 3412 of file vtkPVMessage.pb.h.
◆ descriptor()
static const ::PROTOBUF_NAMESPACE_ID::Descriptor* paraview_protobuf::LinkState_LinkDescription::descriptor ( )
inlinestatic
Definition at line 3416 of file vtkPVMessage.pb.h.
◆ GetDescriptor()
static const ::PROTOBUF_NAMESPACE_ID::Descriptor* paraview_protobuf::LinkState_LinkDescription::GetDescriptor ( )
inlinestatic
Definition at line 3419 of file vtkPVMessage.pb.h.
◆ GetReflection()
static const ::PROTOBUF_NAMESPACE_ID::Reflection* paraview_protobuf::LinkState_LinkDescription::GetReflection ( )
inlinestatic
Definition at line 3422 of file vtkPVMessage.pb.h.
◆ default_instance()
static const LinkState_LinkDescription& paraview_protobuf::LinkState_LinkDescription::default_instance ( )
inlinestatic
Definition at line 3425 of file vtkPVMessage.pb.h.
◆ internal_default_instance()
static const LinkState_LinkDescription* paraview_protobuf::LinkState_LinkDescription::internal_default_instance ( )
inlinestatic
Definition at line 3428 of file vtkPVMessage.pb.h.
◆ Swap()
void paraview_protobuf::LinkState_LinkDescription::Swap ( LinkState_LinkDescription *  other)
inline
Definition at line 3438 of file vtkPVMessage.pb.h.
◆ UnsafeArenaSwap()
void paraview_protobuf::LinkState_LinkDescription::UnsafeArenaSwap ( LinkState_LinkDescription *  other)
inline
Definition at line 3451 of file vtkPVMessage.pb.h.
LinkState_LinkDescription* paraview_protobuf::LinkState_LinkDescription::New ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena = nullptr) const
inlinefinal
Definition at line 3459 of file vtkPVMessage.pb.h.
◆ CopyFrom()
void paraview_protobuf::LinkState_LinkDescription::CopyFrom ( const LinkState_LinkDescription &  from)
◆ MergeFrom()
void paraview_protobuf::LinkState_LinkDescription::MergeFrom ( const LinkState_LinkDescription &  from)
◆ Clear()
PROTOBUF_ATTRIBUTE_REINITIALIZES void paraview_protobuf::LinkState_LinkDescription::Clear ( )
final
◆ IsInitialized()
bool paraview_protobuf::LinkState_LinkDescription::IsInitialized ( ) const
final
◆ ByteSizeLong()
size_t paraview_protobuf::LinkState_LinkDescription::ByteSizeLong ( ) const
final
◆ _InternalParse()
const char* paraview_protobuf::LinkState_LinkDescription::_InternalParse ( const char *  ptr,
::PROTOBUF_NAMESPACE_ID::internal::ParseContext *  ctx
final
◆ _InternalSerialize()
uint8_t* paraview_protobuf::LinkState_LinkDescription::_InternalSerialize ( uint8_t *  target,
::PROTOBUF_NAMESPACE_ID::io::EpsCopyOutputStream *  stream
) const
final
◆ GetCachedSize()
int paraview_protobuf::LinkState_LinkDescription::GetCachedSize ( ) const
inlinefinal
Definition at line 3476 of file vtkPVMessage.pb.h.
◆ GetClassData()
const ::PROTOBUF_NAMESPACE_ID::Message::ClassData* paraview_protobuf::LinkState_LinkDescription::GetClassData ( ) const
final
◆ GetMetadata()
::PROTOBUF_NAMESPACE_ID::Metadata paraview_protobuf::LinkState_LinkDescription::GetMetadata ( ) const
final
◆ Direction_IsValid()
static bool paraview_protobuf::LinkState_LinkDescription::Direction_IsValid ( int  value)
inlinestatic
Definition at line 3511 of file vtkPVMessage.pb.h.
◆ Direction_descriptor()
static const ::PROTOBUF_NAMESPACE_ID::EnumDescriptor* paraview_protobuf::LinkState_LinkDescription::Direction_descriptor ( )
inlinestatic
Definition at line 3521 of file vtkPVMessage.pb.h.
◆ Direction_Name()
static const std::string& paraview_protobuf::LinkState_LinkDescription::Direction_Name ( T  enum_t_value)
inlinestatic
Definition at line 3525 of file vtkPVMessage.pb.h.
◆ Direction_Parse()
static bool paraview_protobuf::LinkState_LinkDescription::Direction_Parse ( ::PROTOBUF_NAMESPACE_ID::ConstStringParam  name,
Direction *  value
inlinestatic
Definition at line 3531 of file vtkPVMessage.pb.h.
◆ has_property_name()
bool paraview_protobuf::LinkState_LinkDescription::has_property_name ( ) const
inline
Definition at line 6380 of file vtkPVMessage.pb.h.
◆ clear_property_name()
void paraview_protobuf::LinkState_LinkDescription::clear_property_name ( )
inline
Definition at line 6383 of file vtkPVMessage.pb.h.
◆ property_name()
const std::string & paraview_protobuf::LinkState_LinkDescription::property_name ( ) const
inline
Definition at line 6387 of file vtkPVMessage.pb.h.
◆ set_property_name() [1/2]
void paraview_protobuf::LinkState_LinkDescription::set_property_name ( ArgT0 &&  arg0,
ArgT...  args
◆ mutable_property_name()
std::string * paraview_protobuf::LinkState_LinkDescription::mutable_property_name ( )
inline
Definition at line 6398 of file vtkPVMessage.pb.h.
◆ release_property_name()
std::string * paraview_protobuf::LinkState_LinkDescription::release_property_name ( )
inline
Definition at line 6414 of file vtkPVMessage.pb.h.
◆ set_allocated_property_name()
void paraview_protobuf::LinkState_LinkDescription::set_allocated_property_name ( std::string *  property_name)
inline
Definition at line 6428 of file vtkPVMessage.pb.h.
◆ has_proxy()
bool paraview_protobuf::LinkState_LinkDescription::has_proxy ( ) const
inline
Definition at line 6352 of file vtkPVMessage.pb.h.
◆ clear_proxy()
void paraview_protobuf::LinkState_LinkDescription::clear_proxy ( )
inline
Definition at line 6355 of file vtkPVMessage.pb.h.
◆ proxy()
uint32_t paraview_protobuf::LinkState_LinkDescription::proxy ( ) const
inline
Definition at line 6362 of file vtkPVMessage.pb.h.
◆ set_proxy()
void paraview_protobuf::LinkState_LinkDescription::set_proxy ( uint32_t  value)
inline
Definition at line 6370 of file vtkPVMessage.pb.h.
◆ has_direction()
bool paraview_protobuf::LinkState_LinkDescription::has_direction ( ) const
inline
Definition at line 6449 of file vtkPVMessage.pb.h.
◆ clear_direction()
void paraview_protobuf::LinkState_LinkDescription::clear_direction ( )
inline
Definition at line 6452 of file vtkPVMessage.pb.h.
◆ direction()
paraview_protobuf::LinkState_LinkDescription_Direction paraview_protobuf::LinkState_LinkDescription::direction ( ) const
inline
Definition at line 6459 of file vtkPVMessage.pb.h.
◆ set_direction()
void paraview_protobuf::LinkState_LinkDescription::set_direction ( ::paraview_protobuf::LinkState_LinkDescription_Direction  value)
inline
Definition at line 6468 of file vtkPVMessage.pb.h.
◆ set_property_name() [2/2]
PROTOBUF_ALWAYS_INLINE void paraview_protobuf::LinkState_LinkDescription::set_property_name ( ArgT0 &&  arg0,
ArgT...  args
inline
Definition at line 6393 of file vtkPVMessage.pb.h.
◆ ::PROTOBUF_NAMESPACE_ID::internal::AnyMetadata
friend class ::PROTOBUF_NAMESPACE_ID::internal::AnyMetadata
friend
Definition at line 3485 of file vtkPVMessage.pb.h.
◆ ::PROTOBUF_NAMESPACE_ID::Arena::InternalHelper
friend class ::PROTOBUF_NAMESPACE_ID::Arena::InternalHelper
friend
Definition at line 3594 of file vtkPVMessage.pb.h.
◆ ::TableStruct_vtkPVMessage_2eproto
friend struct ::TableStruct_vtkPVMessage_2eproto
friend
Definition at line 3602 of file vtkPVMessage.pb.h.
◆ swap
void swap ( LinkState_LinkDescription &  a,
LinkState_LinkDescription &  b
friend
Definition at line 3435 of file vtkPVMessage.pb.h.
◆ kIndexInFileMessages
constexpr int paraview_protobuf::LinkState_LinkDescription::kIndexInFileMessages
Initial value:
16
Definition at line 3432 of file vtkPVMessage.pb.h.
◆ _class_data_
const ClassData paraview_protobuf::LinkState_LinkDescription::_class_data_
Definition at line 3497 of file vtkPVMessage.pb.h.
◆ NONE
constexpr Direction paraview_protobuf::LinkState_LinkDescription::NONE
Initial value:
Definition at line 3505 of file vtkPVMessage.pb.h.
◆ INPUT
constexpr Direction paraview_protobuf::LinkState_LinkDescription::INPUT
Initial value:
Definition at line 3507 of file vtkPVMessage.pb.h.
◆ OUTPUT
constexpr Direction paraview_protobuf::LinkState_LinkDescription::OUTPUT
Initial value:
Definition at line 3509 of file vtkPVMessage.pb.h.
◆ Direction_MIN
constexpr Direction paraview_protobuf::LinkState_LinkDescription::Direction_MIN
Initial value:
Definition at line 3514 of file vtkPVMessage.pb.h.
◆ Direction_MAX
constexpr Direction paraview_protobuf::LinkState_LinkDescription::Direction_MAX
Initial value:
Definition at line 3516 of file vtkPVMessage.pb.h.
◆ Direction_ARRAYSIZE
constexpr int paraview_protobuf::LinkState_LinkDescription::Direction_ARRAYSIZE
