Public Types | Public Member Functions | Static Public Member Functions | Static Public Attributes | Protected Member Functions | Friends | List of all members
paraview_protobuf::ClientsInformation_ClientInfo Class Referencefinal
#include <vtkPVMessage.pb.h>
Inherits Message.
enum  : int {
  kNameFieldNumber = 2, kUserFieldNumber = 1, kIsMasterFieldNumber = 3, kFollowCamFieldNumber = 4,
  kDisableFurtherConnectionsFieldNumber = 5, kConnectIdFieldNumber = 6
 ClientsInformation_ClientInfo ()
 ~ClientsInformation_ClientInfo () override
constexpr ClientsInformation_ClientInfo (::PROTOBUF_NAMESPACE_ID::internal::ConstantInitialized)
 ClientsInformation_ClientInfo (const ClientsInformation_ClientInfo &from)
 ClientsInformation_ClientInfo (ClientsInformation_ClientInfo &&from) noexcept
ClientsInformation_ClientInfo & operator= (const ClientsInformation_ClientInfo &from)
ClientsInformation_ClientInfo & operator= (ClientsInformation_ClientInfo &&from) noexcept
const ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet & unknown_fields () const
inline ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet * mutable_unknown_fields ()
void Swap (ClientsInformation_ClientInfo *other)
void UnsafeArenaSwap (ClientsInformation_ClientInfo *other)
ClientsInformation_ClientInfo * New (::PROTOBUF_NAMESPACE_ID::Arena *arena=nullptr) const final
void CopyFrom (const ClientsInformation_ClientInfo &from)
void MergeFrom (const ClientsInformation_ClientInfo &from)
PROTOBUF_ATTRIBUTE_REINITIALIZES void Clear () final
bool IsInitialized () const final
size_t ByteSizeLong () const final
const char * _InternalParse (const char *ptr, ::PROTOBUF_NAMESPACE_ID::internal::ParseContext *ctx) final
uint8_t * _InternalSerialize (uint8_t *target, ::PROTOBUF_NAMESPACE_ID::io::EpsCopyOutputStream *stream) const final
int GetCachedSize () const final
const ::PROTOBUF_NAMESPACE_ID::Message::ClassData * GetClassData () const final
::PROTOBUF_NAMESPACE_ID::Metadata GetMetadata () const final
bool has_name () const
void clear_name ()
const std::string & name () const
template<typename ArgT0 = const std::string&, typename... ArgT>
void set_name (ArgT0 &&arg0, ArgT... args)
std::string * mutable_name ()
PROTOBUF_NODISCARD std::string * release_name ()
void set_allocated_name (std::string *name)
bool has_user () const
void clear_user ()
uint32_t user () const
void set_user (uint32_t value)
bool has_is_master () const
void clear_is_master ()
bool is_master () const
void set_is_master (bool value)
bool has_follow_cam () const
void clear_follow_cam ()
bool follow_cam () const
void set_follow_cam (bool value)
bool has_disable_further_connections () const
void clear_disable_further_connections ()
bool disable_further_connections () const
void set_disable_further_connections (bool value)
bool has_connect_id () const
void clear_connect_id ()
uint32_t connect_id () const
void set_connect_id (uint32_t value)
template<typename ArgT0 , typename... ArgT>
PROTOBUF_ALWAYS_INLINE void set_name (ArgT0 &&arg0, ArgT... args)
static const ::PROTOBUF_NAMESPACE_ID::Descriptor * descriptor ()
static const ::PROTOBUF_NAMESPACE_ID::Descriptor * GetDescriptor ()
static const ::PROTOBUF_NAMESPACE_ID::Reflection * GetReflection ()
static const ClientsInformation_ClientInfo & default_instance ()
static const ClientsInformation_ClientInfo * internal_default_instance ()
static constexpr int kIndexInFileMessages
static const ClassData _class_data_
 ClientsInformation_ClientInfo (::PROTOBUF_NAMESPACE_ID::Arena *arena, bool is_message_owned=false)
Friends
class ::PROTOBUF_NAMESPACE_ID::internal::AnyMetadata
template<typename T >
class ::PROTOBUF_NAMESPACE_ID::Arena::InternalHelper
struct ::TableStruct_vtkPVMessage_2eproto
void swap (ClientsInformation_ClientInfo &a, ClientsInformation_ClientInfo &b)
Definition at line 4063 of file vtkPVMessage.pb.h.
◆ anonymous enum
anonymous enum : int
Enumerator
kNameFieldNumber
kUserFieldNumber
Definition at line 4191 of file vtkPVMessage.pb.h.
◆ ClientsInformation_ClientInfo() [1/5]
paraview_protobuf::ClientsInformation_ClientInfo::ClientsInformation_ClientInfo ( )
inline
Definition at line 4066 of file vtkPVMessage.pb.h.
◆ ~ClientsInformation_ClientInfo()
paraview_protobuf::ClientsInformation_ClientInfo::~ClientsInformation_ClientInfo ( )
override
◆ ClientsInformation_ClientInfo() [2/5]
constexpr paraview_protobuf::ClientsInformation_ClientInfo::ClientsInformation_ClientInfo ( ::PROTOBUF_NAMESPACE_ID::internal::ConstantInitialized  )
explicit
◆ ClientsInformation_ClientInfo() [3/5]
paraview_protobuf::ClientsInformation_ClientInfo::ClientsInformation_ClientInfo ( const ClientsInformation_ClientInfo &  from)
◆ ClientsInformation_ClientInfo() [4/5]
paraview_protobuf::ClientsInformation_ClientInfo::ClientsInformation_ClientInfo ( ClientsInformation_ClientInfo &&  from)
inlinenoexcept
Definition at line 4071 of file vtkPVMessage.pb.h.
◆ ClientsInformation_ClientInfo() [5/5]
paraview_protobuf::ClientsInformation_ClientInfo::ClientsInformation_ClientInfo ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena,
bool  is_message_owned = false
explicitprotected
◆ operator=() [1/2]
ClientsInformation_ClientInfo& paraview_protobuf::ClientsInformation_ClientInfo::operator= ( const ClientsInformation_ClientInfo &  from)
inline
Definition at line 4076 of file vtkPVMessage.pb.h.
◆ operator=() [2/2]
ClientsInformation_ClientInfo& paraview_protobuf::ClientsInformation_ClientInfo::operator= ( ClientsInformation_ClientInfo &&  from)
inlinenoexcept
Definition at line 4080 of file vtkPVMessage.pb.h.
◆ unknown_fields()
const ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet& paraview_protobuf::ClientsInformation_ClientInfo::unknown_fields ( ) const
inline
Definition at line 4094 of file vtkPVMessage.pb.h.
◆ mutable_unknown_fields()
inline ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet* paraview_protobuf::ClientsInformation_ClientInfo::mutable_unknown_fields ( )
inline
Definition at line 4097 of file vtkPVMessage.pb.h.
◆ descriptor()
static const ::PROTOBUF_NAMESPACE_ID::Descriptor* paraview_protobuf::ClientsInformation_ClientInfo::descriptor ( )
inlinestatic
Definition at line 4101 of file vtkPVMessage.pb.h.
◆ GetDescriptor()
static const ::PROTOBUF_NAMESPACE_ID::Descriptor* paraview_protobuf::ClientsInformation_ClientInfo::GetDescriptor ( )
inlinestatic
Definition at line 4104 of file vtkPVMessage.pb.h.
◆ GetReflection()
static const ::PROTOBUF_NAMESPACE_ID::Reflection* paraview_protobuf::ClientsInformation_ClientInfo::GetReflection ( )
inlinestatic
Definition at line 4107 of file vtkPVMessage.pb.h.
◆ default_instance()
static const ClientsInformation_ClientInfo& paraview_protobuf::ClientsInformation_ClientInfo::default_instance ( )
inlinestatic
Definition at line 4110 of file vtkPVMessage.pb.h.
◆ internal_default_instance()
static const ClientsInformation_ClientInfo* paraview_protobuf::ClientsInformation_ClientInfo::internal_default_instance ( )
inlinestatic
Definition at line 4113 of file vtkPVMessage.pb.h.
◆ Swap()
void paraview_protobuf::ClientsInformation_ClientInfo::Swap ( ClientsInformation_ClientInfo *  other)
inline
Definition at line 4123 of file vtkPVMessage.pb.h.
◆ UnsafeArenaSwap()
void paraview_protobuf::ClientsInformation_ClientInfo::UnsafeArenaSwap ( ClientsInformation_ClientInfo *  other)
inline
Definition at line 4136 of file vtkPVMessage.pb.h.
ClientsInformation_ClientInfo* paraview_protobuf::ClientsInformation_ClientInfo::New ( ::PROTOBUF_NAMESPACE_ID::Arena *  arena = nullptr) const
inlinefinal
Definition at line 4144 of file vtkPVMessage.pb.h.
◆ CopyFrom()
void paraview_protobuf::ClientsInformation_ClientInfo::CopyFrom ( const ClientsInformation_ClientInfo &  from)
◆ MergeFrom()
void paraview_protobuf::ClientsInformation_ClientInfo::MergeFrom ( const ClientsInformation_ClientInfo &  from)
◆ Clear()
PROTOBUF_ATTRIBUTE_REINITIALIZES void paraview_protobuf::ClientsInformation_ClientInfo::Clear ( )
final
◆ IsInitialized()
bool paraview_protobuf::ClientsInformation_ClientInfo::IsInitialized ( ) const
final
◆ ByteSizeLong()
size_t paraview_protobuf::ClientsInformation_ClientInfo::ByteSizeLong ( ) const
final
◆ _InternalParse()
const char* paraview_protobuf::ClientsInformation_ClientInfo::_InternalParse ( const char *  ptr,
::PROTOBUF_NAMESPACE_ID::internal::ParseContext *  ctx
final
◆ _InternalSerialize()
uint8_t* paraview_protobuf::ClientsInformation_ClientInfo::_InternalSerialize ( uint8_t *  target,
::PROTOBUF_NAMESPACE_ID::io::EpsCopyOutputStream *  stream
) const
final
◆ GetCachedSize()
int paraview_protobuf::ClientsInformation_ClientInfo::GetCachedSize ( ) const
inlinefinal
Definition at line 4161 of file vtkPVMessage.pb.h.
◆ GetClassData()
const ::PROTOBUF_NAMESPACE_ID::Message::ClassData* paraview_protobuf::ClientsInformation_ClientInfo::GetClassData ( ) const
final
◆ GetMetadata()
::PROTOBUF_NAMESPACE_ID::Metadata paraview_protobuf::ClientsInformation_ClientInfo::GetMetadata ( ) const
final
◆ has_name()
bool paraview_protobuf::ClientsInformation_ClientInfo::has_name ( ) const
inline
Definition at line 6522 of file vtkPVMessage.pb.h.
◆ clear_name()
void paraview_protobuf::ClientsInformation_ClientInfo::clear_name ( )
inline
Definition at line 6525 of file vtkPVMessage.pb.h.
◆ name()
const std::string & paraview_protobuf::ClientsInformation_ClientInfo::name ( ) const
inline
Definition at line 6529 of file vtkPVMessage.pb.h.
◆ set_name() [1/2]
void paraview_protobuf::ClientsInformation_ClientInfo::set_name ( ArgT0 &&  arg0,
ArgT...  args
◆ mutable_name()
std::string * paraview_protobuf::ClientsInformation_ClientInfo::mutable_name ( )
inline
Definition at line 6540 of file vtkPVMessage.pb.h.
◆ release_name()
std::string * paraview_protobuf::ClientsInformation_ClientInfo::release_name ( )
inline
Definition at line 6556 of file vtkPVMessage.pb.h.
◆ set_allocated_name()
void paraview_protobuf::ClientsInformation_ClientInfo::set_allocated_name ( std::string *  name)
inline
Definition at line 6570 of file vtkPVMessage.pb.h.
◆ has_user()
bool paraview_protobuf::ClientsInformation_ClientInfo::has_user ( ) const
inline
Definition at line 6494 of file vtkPVMessage.pb.h.
◆ clear_user()
void paraview_protobuf::ClientsInformation_ClientInfo::clear_user ( )
inline
Definition at line 6497 of file vtkPVMessage.pb.h.
◆ user()
uint32_t paraview_protobuf::ClientsInformation_ClientInfo::user ( ) const
inline
Definition at line 6504 of file vtkPVMessage.pb.h.
◆ set_user()
void paraview_protobuf::ClientsInformation_ClientInfo::set_user ( uint32_t  value)
inline
Definition at line 6512 of file vtkPVMessage.pb.h.
◆ has_is_master()
bool paraview_protobuf::ClientsInformation_ClientInfo::has_is_master ( ) const
inline
Definition at line 6591 of file vtkPVMessage.pb.h.
◆ clear_is_master()
void paraview_protobuf::ClientsInformation_ClientInfo::clear_is_master ( )
inline
Definition at line 6594 of file vtkPVMessage.pb.h.
◆ is_master()
bool paraview_protobuf::ClientsInformation_ClientInfo::is_master ( ) const
inline
Definition at line 6601 of file vtkPVMessage.pb.h.
◆ set_is_master()
void paraview_protobuf::ClientsInformation_ClientInfo::set_is_master ( bool  value)
inline
Definition at line 6609 of file vtkPVMessage.pb.h.
◆ has_follow_cam()
bool paraview_protobuf::ClientsInformation_ClientInfo::has_follow_cam ( ) const
inline
Definition at line 6619 of file vtkPVMessage.pb.h.
◆ clear_follow_cam()
void paraview_protobuf::ClientsInformation_ClientInfo::clear_follow_cam ( )
inline
Definition at line 6622 of file vtkPVMessage.pb.h.
◆ follow_cam()
bool paraview_protobuf::ClientsInformation_ClientInfo::follow_cam ( ) const
inline
Definition at line 6629 of file vtkPVMessage.pb.h.
◆ set_follow_cam()
void paraview_protobuf::ClientsInformation_ClientInfo::set_follow_cam ( bool  value)
inline
Definition at line 6637 of file vtkPVMessage.pb.h.
◆ has_disable_further_connections()
bool paraview_protobuf::ClientsInformation_ClientInfo::has_disable_further_connections ( ) const
inline
Definition at line 6647 of file vtkPVMessage.pb.h.
◆ clear_disable_further_connections()
void paraview_protobuf::ClientsInformation_ClientInfo::clear_disable_further_connections ( )
inline
Definition at line 6650 of file vtkPVMessage.pb.h.
◆ disable_further_connections()
bool paraview_protobuf::ClientsInformation_ClientInfo::disable_further_connections ( ) const
inline
Definition at line 6657 of file vtkPVMessage.pb.h.
◆ set_disable_further_connections()
void paraview_protobuf::ClientsInformation_ClientInfo::set_disable_further_connections ( bool  value)
inline
Definition at line 6665 of file vtkPVMessage.pb.h.
◆ has_connect_id()
bool paraview_protobuf::ClientsInformation_ClientInfo::has_connect_id ( ) const
inline
Definition at line 6675 of file vtkPVMessage.pb.h.
◆ clear_connect_id()
void paraview_protobuf::ClientsInformation_ClientInfo::clear_connect_id ( )
inline
Definition at line 6678 of file vtkPVMessage.pb.h.
◆ connect_id()
uint32_t paraview_protobuf::ClientsInformation_ClientInfo::connect_id ( ) const
inline
Definition at line 6685 of file vtkPVMessage.pb.h.
◆ set_connect_id()
void paraview_protobuf::ClientsInformation_ClientInfo::set_connect_id ( uint32_t  value)
inline
Definition at line 6693 of file vtkPVMessage.pb.h.
◆ set_name() [2/2]
PROTOBUF_ALWAYS_INLINE void paraview_protobuf::ClientsInformation_ClientInfo::set_name ( ArgT0 &&  arg0,
ArgT...  args
inline
Definition at line 6535 of file vtkPVMessage.pb.h.
◆ ::PROTOBUF_NAMESPACE_ID::internal::AnyMetadata
friend class ::PROTOBUF_NAMESPACE_ID::internal::AnyMetadata
friend
Definition at line 4170 of file vtkPVMessage.pb.h.
◆ ::PROTOBUF_NAMESPACE_ID::Arena::InternalHelper
friend class ::PROTOBUF_NAMESPACE_ID::Arena::InternalHelper
friend
Definition at line 4284 of file vtkPVMessage.pb.h.
◆ ::TableStruct_vtkPVMessage_2eproto
friend struct ::TableStruct_vtkPVMessage_2eproto
friend
Definition at line 4297 of file vtkPVMessage.pb.h.
◆ swap
void swap ( ClientsInformation_ClientInfo &  a,
ClientsInformation_ClientInfo &  b
friend
Definition at line 4120 of file vtkPVMessage.pb.h.
◆ kIndexInFileMessages
constexpr int paraview_protobuf::ClientsInformation_ClientInfo::kIndexInFileMessages
Initial value:
20
Definition at line 4117 of file vtkPVMessage.pb.h.
◆ _class_data_
const ClassData paraview_protobuf::ClientsInformation_ClientInfo::_class_data_
Definition at line 4182 of file vtkPVMessage.pb.h.
