| #define XDMF_REQUIRE_LARGE_FILE_SUPPORT |
Definition at line 8 of file XdmfConfig.h.
| #define _LARGEFILE_SOURCE |
Definition at line 11 of file XdmfConfig.h.
| #define _LARGEFILE64_SOURCE |
Definition at line 14 of file XdmfConfig.h.
| #define _LARGE_FILES |
Definition at line 17 of file XdmfConfig.h.
| #define _FILE_OFFSET_BITS 64 |
Definition at line 20 of file XdmfConfig.h.
| #define XDMF_WORDS_LITTLEENDIAN |
Definition at line 31 of file XdmfConfig.h.
| #define XDMF_BYTE_ORDER_LITTLE |
Definition at line 32 of file XdmfConfig.h.
| #define XDMF_SYSTEM Linux-6.8.0-138-generic |
Definition at line 35 of file XdmfConfig.h.
| #define XDMF_VOID_VALID |
Definition at line 37 of file XdmfConfig.h.
| #define XDMF_VOID void |
Definition at line 42 of file XdmfConfig.h.
| #define XDMF_PTR_VALID |
Definition at line 44 of file XdmfConfig.h.
| #define XDMF_PTR void * |
Definition at line 49 of file XdmfConfig.h.
| #define XDMF_CHAR_VALID |
Definition at line 51 of file XdmfConfig.h.
| #define XDMF_CHAR char |
Definition at line 56 of file XdmfConfig.h.
| #define XDMF_8_INT_VALID |
Definition at line 58 of file XdmfConfig.h.
| #define XDMF_8_INT char |
Definition at line 63 of file XdmfConfig.h.
| #define XDMF_8_U_INT unsigned char |
Definition at line 64 of file XdmfConfig.h.
| #define XDMF_16_INT_VALID |
Definition at line 66 of file XdmfConfig.h.
| #define XDMF_16_INT short |
Definition at line 71 of file XdmfConfig.h.
| #define XDMF_16_U_INT unsigned short |
Definition at line 72 of file XdmfConfig.h.
| #define XDMF_32_INT_VALID |
Definition at line 74 of file XdmfConfig.h.
| #define XDMF_32_INT int |
Definition at line 79 of file XdmfConfig.h.
| #define XDMF_32_U_INT unsigned int |
Definition at line 80 of file XdmfConfig.h.
| #define XDMF_32_S_INT int |
Definition at line 81 of file XdmfConfig.h.
| #define XDMF_32_FLOAT_VALID |
Definition at line 83 of file XdmfConfig.h.
| #define XDMF_32_FLOAT float |
Definition at line 88 of file XdmfConfig.h.
| #define XDMF_FLOAT float |
Definition at line 89 of file XdmfConfig.h.
| #define XDMF_64_FLOAT_VALID |
Definition at line 91 of file XdmfConfig.h.
| #define XDMF_64_FLOAT double |
Definition at line 96 of file XdmfConfig.h.
| #define XDMF_DOUBLE double |
Definition at line 97 of file XdmfConfig.h.
| #define SIZEOF_LONG_LONG 8 |
Definition at line 105 of file XdmfConfig.h.
| #define XDMF_64_INT long long |
Definition at line 109 of file XdmfConfig.h.
| #define HAVE_64_INT |
Definition at line 110 of file XdmfConfig.h.
| #define XDMF_have_64_bit_int |
Definition at line 111 of file XdmfConfig.h.
| #define XDMF_HAVE_64BIT_STREAMS |
Definition at line 119 of file XdmfConfig.h.
| #define XDMF_64BIT_CAST |
Definition at line 121 of file XdmfConfig.h.
| #define XDMF_USE_ANSI_STDLIB |
Definition at line 127 of file XdmfConfig.h.
| #define XDMF_LONG64 long long |
Definition at line 137 of file XdmfConfig.h.
| #define BUILD_SHARED_LIBS |
Definition at line 142 of file XdmfConfig.h.
| #define XDMF_NO_MPI |
Definition at line 152 of file XdmfConfig.h.
| #define Xdmf_EXPORTS |
Definition at line 157 of file XdmfConfig.h.
1.8.13 on Sat Aug 29 2026
