1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOGeneral
40 # Set path to fallback-tool for dependency-resolution.
42  set(CMAKE_OBJDUMP "/usr/sbin/objdump")
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkPVVTKExtensionsIOGeneral-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkPVVTKExtensionsIOGeneral-hierarchy.txt")
47 endif()
48
49 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime" OR NOT CMAKE_INSTALL_COMPONENT)
50  foreach(file
51  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOGeneral-pv6.2.so.6.2"
52  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOGeneral-pv6.2.so.1"
53  )
54  if(EXISTS "${file}" AND
55  NOT IS_SYMLINK "${file}")
56  file(RPATH_CHECK
57  FILE "${file}"
58  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
59  endif()
60  endforeach()
61  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
62  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsIOGeneral-pv6.2.so.6.2"
63  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsIOGeneral-pv6.2.so.1"
64  )
65  foreach(file
66  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOGeneral-pv6.2.so.6.2"
67  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkPVVTKExtensionsIOGeneral-pv6.2.so.1"
68  )
69  if(EXISTS "${file}" AND
70  NOT IS_SYMLINK "${file}")
71  file(RPATH_CHANGE
72  FILE "${file}"
73  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
74  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
75  if(CMAKE_INSTALL_DO_STRIP)
76  execute_process(COMMAND "/usr/sbin/strip" "${file}")
77  endif()
78  endif()
79  endforeach()
80 endif()
81
83  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkPVVTKExtensionsIOGeneral-pv6.2.so")
84 endif()
85
86 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
87 endif()
88
89 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
90  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2" TYPE FILE FILES
91  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOGeneral/vtkEnsembleDataReader.h"
92  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOGeneral/vtkNastranBDFReader.h"
93  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOGeneral/vtkPhastaReader.h"
94  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOGeneral/vtkPPhastaReader.h"
95  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOGeneral/vtkPVPLYWriter.h"
96  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOGeneral/vtkUnstructuredPOPReader.h"
97  "/builds/gitlab-kitware-sciviz-ci/VTKExtensions/IOGeneral/vtkVRMLSource.h"
98  )
99 endif()
100
101 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
102  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTKExtensions/IOGeneral/vtkPVVTKExtensionsIOGeneralModule.h")
103 endif()
104
105 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx" OR NOT CMAKE_INSTALL_COMPONENT)
106  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/VTKExtensions/IOGeneral/vtkPVVTKExtensionsIOGeneral.spdx")
107 endif()
108
109 string(REPLACE ";" "\n" CMAKE_INSTALL_MANIFEST_CONTENT
110  "${CMAKE_INSTALL_MANIFEST_FILES}")
111 if(CMAKE_INSTALL_LOCAL_ONLY)
112  file(WRITE "/builds/gitlab-kitware-sciviz-ci/build/VTKExtensions/IOGeneral/install_local_manifest.txt"
113  "${CMAKE_INSTALL_MANIFEST_CONTENT}")
114 endif()
reader for ensemble data sets
Reader for RPI's PHASTA software.
provides a ParaView friendly API for vtkPLYWriter.
parallel Phasta meta-file reader vtkPPhastaReader reads XML based Phasta meta-files and the underlyin...
Wrapper around the vtkVRMLImporter that makes it availalable as a data source.
Definition: vtkVRMLSource.h:20
Reader for Bulk Data Format from Nastran.
