1 # Install script for directory: /builds/gitlab-kitware-sciviz-ci/Remoting/Settings
40 # Set path to fallback-tool for dependency-resolution.
42  set(CMAKE_OBJDUMP "/usr/sbin/objdump")
46  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64/vtk/hierarchy/ParaView" TYPE FILE RENAME "vtkRemotingSettings-hierarchy.txt" FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/vtk/hierarchy/ParaView/vtkRemotingSettings-hierarchy.txt")
47 endif()
48
49 if(CMAKE_INSTALL_COMPONENT STREQUAL "runtime" OR NOT CMAKE_INSTALL_COMPONENT)
50  foreach(file
51  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingSettings-pv6.2.so.6.2"
52  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingSettings-pv6.2.so.1"
53  )
54  if(EXISTS "${file}" AND
55  NOT IS_SYMLINK "${file}")
56  file(RPATH_CHECK
57  FILE "${file}"
58  RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
59  endif()
60  endforeach()
61  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES
62  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRemotingSettings-pv6.2.so.6.2"
63  "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRemotingSettings-pv6.2.so.1"
64  )
65  foreach(file
66  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingSettings-pv6.2.so.6.2"
67  "$ENV{DESTDIR}${CMAKE_INSTALL_PREFIX}/lib64/libvtkRemotingSettings-pv6.2.so.1"
68  )
69  if(EXISTS "${file}" AND
70  NOT IS_SYMLINK "${file}")
71  file(RPATH_CHANGE
72  FILE "${file}"
73  OLD_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib:"
74  NEW_RPATH "\$ORIGIN:/usr/lib64/openmpi/lib")
75  if(CMAKE_INSTALL_DO_STRIP)
76  execute_process(COMMAND "/usr/sbin/strip" "${file}")
77  endif()
78  endif()
79  endforeach()
80 endif()
81
83  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/lib64" TYPE SHARED_LIBRARY FILES "/builds/gitlab-kitware-sciviz-ci/build/lib64/libvtkRemotingSettings-pv6.2.so")
84 endif()
85
86 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
87 endif()
88
89 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
90  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/Remoting/Settings/vtkPVGeneralSettings.h")
91 endif()
92
93 if(CMAKE_INSTALL_COMPONENT STREQUAL "development" OR NOT CMAKE_INSTALL_COMPONENT)
94  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/include/paraview-6.2" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Remoting/Settings/vtkRemotingSettingsModule.h")
95 endif()
96
97 if(CMAKE_INSTALL_COMPONENT STREQUAL "spdx" OR NOT CMAKE_INSTALL_COMPONENT)
98  file(INSTALL DESTINATION "${CMAKE_INSTALL_PREFIX}/share/doc/ParaView/spdx" TYPE FILE FILES "/builds/gitlab-kitware-sciviz-ci/build/Remoting/Settings/vtkRemotingSettings.spdx")
99 endif()
100
101 string(REPLACE ";" "\n" CMAKE_INSTALL_MANIFEST_CONTENT
102  "${CMAKE_INSTALL_MANIFEST_FILES}")
103 if(CMAKE_INSTALL_LOCAL_ONLY)
104  file(WRITE "/builds/gitlab-kitware-sciviz-ci/build/Remoting/Settings/install_local_manifest.txt"
105  "${CMAKE_INSTALL_MANIFEST_CONTENT}")
106 endif()
object for general options.
