vtkPVMetaClipDataSet.h
2 // SPDX-FileCopyrightText: Copyright (c) Ken Martin, Will Schroeder, Bill Lorensen
10 #ifndef vtkPVMetaClipDataSet_h
11 #define vtkPVMetaClipDataSet_h
12
14 #include "vtkPVVTKExtensionsFiltersGeneralModule.h" //needed for exports
15
17
20 {
21 public:
23  void PrintSelf(ostream& os, vtkIndent indent) override;
24
25  static vtkPVMetaClipDataSet* New();
26
27  static const unsigned METACLIP_DATASET = 0;
28  static const unsigned METACLIP_HYPERTREEGRID = 1;
33  void PreserveInputCells(int keepCellAsIs);
35  void SetImplicitFunction(vtkImplicitFunction* func);
36
37  void SetInsideOut(int insideOut);
38
39  // Only available for cut -------------
40
44  void SetClipFunction(vtkImplicitFunction* func) { this->SetImplicitFunction(func); };
45
49  void SetDataSetClipFunction(vtkImplicitFunction* func);
50
54  void SetHyperTreeGridClipFunction(vtkImplicitFunction* func);
55
59  void SetValue(double value);
60
62  int idx, int port, int connection, int fieldAssociation, const char* name) override;
64  int idx, int port, int connection, int fieldAssociation, int fieldAttributeType) override;
65  void SetInputArrayToProcess(int idx, vtkInformation* info) override;
66
68  int idx, int port, int connection, const char* fieldName, const char* fieldType) override;
69
71
77  vtkSetMacro(ExactBoxClip, bool);
78  vtkGetMacro(ExactBoxClip, bool);
79  vtkBooleanMacro(ExactBoxClip, bool);
81
85  void SetUseValueAsOffset(int);
86
91  int ProcessRequest(
92  vtkInformation* request, vtkInformationVector** inInfo, vtkInformationVector* outInfo) override;
93
94  // Add validation for active filter so that the vtkExtractGeometry
95  // won't be used without ImplicifFuntion being set.
96  int ProcessRequest(
97  vtkInformation* request, vtkCollection* inInfo, vtkInformationVector* outInfo) override;
98
99  int RequestDataObject(vtkInformation* request, vtkInformationVector** inputVector,
100  vtkInformationVector* outputVector) override;
101
106  vtkMTimeType GetMTime() override;
107
108 protected:
110  ~vtkPVMetaClipDataSet() override;
111
112  // Check to see if this filter can do crinkle, return true if
113  // we need to switch active filter, so that we can switch back after.
114  bool SwitchFilterForCrinkle();
115
116  vtkImplicitFunction* ImplicitFunctions[2];
117
118 private:
120  void operator=(const vtkPVMetaClipDataSet&) = delete;
121
122  bool ExactBoxClip;
123
124  class vtkInternals;
125  vtkInternals* Internal;
126 };
127
128 #endif
Meta class for clip filter that will allow the user to switch between a regular clip filter or an ext...
void SetValue(vtkIdType valueIdx, ValueType value)
int ProcessRequest(vtkInformation *request, vtkInformationVector **inInfo, vtkInformationVector *outInfo) override
Forward those methods to the underneath filters.
static vtkPVDataSetAlgorithmSelectorFilter * New()
info
void SetClipFunction(vtkImplicitFunction *func)
Expose method from vtkCutter.
virtual int RequestDataObject(vtkInformation *, vtkInformationVector **, vtkInformationVector *outputVector)
vtkTypeUInt64 vtkMTimeType
virtual void SetInputArrayToProcess(int idx, int port, int connection, int fieldAssociation, const char *name)
name
is a generic vtkAlgorithm that allow the user to register several vtkAlgorithm to it and be able to s...
#define VTKPVVTKEXTENSIONSFILTERSGENERAL_EXPORT
value
Override GetMTime because we delegate to other filters to do the real work.
port
