Functions
se_create_data.h File Reference
#include "vtkPVAdaptorsCamModule.h"
Include dependency graph for se_create_data.h:
Functions
void VTKPVADAPTORSCAM_EXPORT se_coprocessorinitializewithpython_ (const char *pythonScriptName)
 Initializes the Catalyst Coprocessor. More...
void VTKPVADAPTORSCAM_EXPORT se_create_grid_ (int *ne, int *np, int *nlon, double *lonRad, int *nlat, double *latRad, int *nlev, double *lev, int *nCells2d, int *maxNcols, int *mpiRank)
 Creates grids for 2d and 3d cubed-spheres. More...
void VTKPVADAPTORSCAM_EXPORT se_add_chunk_ (int *nstep, int *chunkSize, double *lonRad, double *latRad, double *psScalar, double *tScalar, double *uScalar, double *vScalar)
 for timestep 0: creates the points and cells for the grids. More...
int VTKPVADAPTORSCAM_EXPORT se_requestdatadescription_ (int *timeStep, double *time)
 Checks if Catalyst needs to coprocess data. More...
int VTKPVADAPTORSCAM_EXPORT se_needtocreategrid_ ()
 Checks if the grids need to be created. More...
void VTKPVADAPTORSCAM_EXPORT se_coprocess_ ()
 calls the coprocessor More...
void VTKPVADAPTORSCAM_EXPORT se_catalyst_finalize_ ()
Function Documentation
◆ se_coprocessorinitializewithpython_()
void VTKPVADAPTORSCAM_EXPORT se_coprocessorinitializewithpython_ ( const char *  pythonScriptName)
Warning
Make sure you pass a zero terminated string
◆ se_create_grid_()
void VTKPVADAPTORSCAM_EXPORT se_create_grid_ ( int *  ne,
int *  np,
int *  nlon,
double *  lonRad,
int *  nlat,
double *  latRad,
int *  nlev,
double *  lev,
int *  nCells2d,
int *  maxNcols,
int *  mpiRank
◆ se_add_chunk_()
void VTKPVADAPTORSCAM_EXPORT se_add_chunk_ ( int *  nstep,
int *  chunkSize,
double *  lonRad,
double *  latRad,
double *  psScalar,
double *  tScalar,
double *  uScalar,
double *  vScalar
for all timesteps: copies data from the simulation to Catalyst.
◆ se_requestdatadescription_()
int VTKPVADAPTORSCAM_EXPORT se_requestdatadescription_ ( int *  timeStep,
double *  time
◆ se_needtocreategrid_()
int VTKPVADAPTORSCAM_EXPORT se_needtocreategrid_ ( )
◆ se_coprocess_()
void VTKPVADAPTORSCAM_EXPORT se_coprocess_ ( )
◆ se_catalyst_finalize_()
void VTKPVADAPTORSCAM_EXPORT se_catalyst_finalize_ ( )
