vtkGlyph3DRepresentation Class Reference
vtkGlyph3DRepresentation is a representation that uses the vtkGlyph3DMapper for rendering glyphs. More...
#include <vtkGlyph3DRepresentation.h>
Inheritance diagram for vtkGlyph3DRepresentation:
Collaboration diagram for vtkGlyph3DRepresentation:
typedef vtkGeometryRepresentation Superclass
- Public Types inherited from vtkGeometryRepresentation
enum  RepresentationTypes { POINTS = VTK_POINTS, WIREFRAME = VTK_WIREFRAME, SURFACE = VTK_SURFACE, SURFACE_WITH_EDGES = 3 }
enum  DesiredOutputPrecision
void SetMeshVisibility (bool visible)
 Toggle the visibility of the original mesh. More...
void SetVisibility (bool) override
void SetMaskArray (const char *val)
void SetScaleArray (const char *val)
void SetOrientationArray (const char *val)
void SetSourceIndexArray (const char *val)
void SetScaling (bool val)
void SetScaleMode (int val)
void SetScaleFactor (double val)
void SetOrient (bool val)
void SetOrientationMode (int val)
void SetMasking (bool val)
void SetSourceIndexing (bool val)
void SetUseSourceTableTree (bool val)
void SetUseCullingAndLOD (bool val)
void SetNumberOfLOD (int val)
void SetLODDistanceAndTargetReduction (int index, float dist, float reduc)
void SetColorByLODIndex (bool val)
void SetInterpolateScalarsBeforeMapping (int val) override
void SetLookupTable (vtkScalarsToColors *val) override
void SetMapScalars (int val) override
 Sets if scalars are mapped through a color-map or are used directly as colors. More...
void SetStatic (int val) override
void SetOrientation (double, double, double) override
void SetOrigin (double, double, double) override
void SetPickable (int val) override
void SetPosition (double, double, double) override
void SetScale (double, double, double) override
void SetTexture (vtkTexture *) override
void SetUserTransform (const double[16]) override
void SetCoordinateSystem (int) override
- Public Member Functions inherited from vtkGeometryRepresentation
virtual void SetSuppressLOD (bool suppress)
 Enable/Disable LOD;. More...
virtual void SetRepresentation (const char *)
 Overload to set representation type using string. More...
vtkDataObject * GetRenderedDataObject (int port) override
virtual void SetNormalArray (const char *val)
 Set the normal array used for smooth shading. More...
virtual void SetTCoordArray (const char *val)
 Set the texture coordinates array used for texture mapping. More...
virtual void SetTangentArray (const char *val)
 Set the tangent coordinates array used for normal mapping. More...
virtual void SetUseOutline (int)
void SetTriangulate (int)
void SetNonlinearSubdivisionLevel (int)
void SetMatchBoundariesIgnoringCellOrder (int)
virtual void SetGenerateFeatureEdges (bool)
void SetComputePointNormals (bool)
void SetSplitting (bool)
void SetFeatureAngle (double)
virtual void SetAmbientColor (double r, double g, double b)
virtual void SetColor (double r, double g, double b)
virtual void SetDiffuseColor (double r, double g, double b)
virtual void SetLighting (bool lighting)
virtual void SetEdgeColor (double r, double g, double b)
virtual void SetInteractiveSelectionColor (double r, double g, double b)
virtual void SetInterpolation (int val)
virtual void SetLineWidth (double val)
virtual void SetOpacity (double val)
virtual void SetEdgeOpacity (double val)
virtual void SetPointSize (double val)
virtual void SetSpecularColor (double r, double g, double b)
virtual void SetSpecularPower (double val)
virtual void SetLuminosity (double val)
virtual void SetRenderPointsAsSpheres (bool)
virtual void SetRenderLinesAsTubes (bool)
virtual void SetRoughness (double val)
virtual void SetMetallic (double val)
virtual void SetEdgeTint (double r, double g, double b)
virtual void SetAnisotropy (double val)
virtual void SetAnisotropyRotation (double val)
virtual void SetBaseIOR (double val)
virtual void SetCoatIOR (double val)
virtual void SetCoatStrength (double val)
virtual void SetCoatRoughness (double val)
virtual void SetCoatNormalScale (double val)
virtual void SetCoatColor (double r, double g, double b)
virtual void SetBaseColorTexture (vtkTexture *tex)
virtual void SetMaterialTexture (vtkTexture *tex)
virtual void SetAnisotropyTexture (vtkTexture *tex)
virtual void SetNormalTexture (vtkTexture *tex)
virtual void SetCoatNormalTexture (vtkTexture *tex)
virtual void SetEmissiveTexture (vtkTexture *tex)
virtual void SetNormalScale (double val)
virtual void SetOcclusionStrength (double val)
virtual void SetEmissiveFactor (double rval, double gval, double bval)
virtual void SetShowTexturesOnBackface (bool)
virtual void SetTextureTransform (vtkTransform *)
virtual vtkTransform * GetTextureTransform ()
virtual void SetRepeatTextures (bool)
virtual bool GetRepeatTextures ()
virtual void SetInterpolateTextures (bool)
virtual bool GetInterpolateTextures ()
virtual void SetUseMipmapTextures (bool)
virtual bool GetUseMipmapTextures ()
virtual void SetColorMissingArraysWithNanColor (bool val)
virtual void SetSeamlessU (bool)
virtual void SetSeamlessV (bool)
virtual void SetSelection (vtkSelection *selection)
 Sets the selection used by the mapper. More...
vtkPVLODActor * GetActor ()
 Provides access to the actor used by this representation. More...
const char * GetColorArrayName ()
 Convenience method to get the array name used to scalar color with. More...
virtual void SetMaterial (const char *)
 For OSPRay, choose from among available materials. More...
virtual void SetShaderReplacements (const char *)
 Specify shader replacements using a Json string. More...
void SetArrayIdNames (const char *pointArray, const char *cellArray) override
void SetBlockColorsDistinctValues (int distinctValues)
 Determines the number of distinct values in vtkBlockColors See also vtkGeometryFilterDispatcher. More...
int GetBlockColorsDistinctValues ()
virtual void DisableLightingOn ()
 Disables the lighting on the object. More...
virtual void DisableLightingOff ()
virtual void SetDisableLighting (bool)
virtual bool GetDisableLighting ()
virtual void SetAmbient (double)
 Set the lighting properties of the object. More...
virtual void SetDiffuse (double)
virtual void SetSpecular (double)
virtual double GetAmbient ()
virtual double GetDiffuse ()
virtual double GetSpecular ()
void SetCoordinateShiftScaleMethod (int val)
 Set the shift scale method for the point coordinates see vtkOpenGLVertexBufferObject.h for more information. More...
int GetCoordinateShiftScaleMethod ()
virtual void SetRepresentation (int)
 Set the representation type. More...
virtual int GetRepresentation ()
virtual void SetRequestGhostCellsIfNeeded (bool)
 Representations that use geometry representation as the internal representation should turn this flag off so that we don't end up requesting ghost cells twice. More...
virtual bool GetRequestGhostCellsIfNeeded ()
virtual void RequestGhostCellsIfNeededOn ()
virtual void RequestGhostCellsIfNeededOff ()
virtual void SetActiveAssembly (const char *)
 Get/Set the name of the assembly to use for mapping block visibilities, colors and opacities. More...
virtual char * GetActiveAssembly ()
void AddBlockSelector (const char *selector)
 Update list of selectors that determine the selected blocks. More...
void RemoveAllBlockSelectors ()
void SetBlockColor (const char *selector, double r, double g, double b)
 Set the color for a single block. More...
void RemoveAllBlockColors ()
void SetBlockOpacity (const char *selector, double opacity)
 Set the opacity for a single block. More...
void RemoveAllBlockOpacities ()
void SetBlockInterpolateScalarsBeforeMapping (const char *selector, bool interpolate)
 Set if to interpolate scalars before mapping for a single block. More...
void RemoveAllBlockInterpolateScalarsBeforeMappings ()
void SetBlockMapScalars (const char *selector, int val)
 Set the block to map scalars for a single block. More...
void RemoveAllBlockMapScalars ()
void SetBlockArrayName (const char *selector, int assoc, const char *arrayName)
 Set the color array for a single block. More...
void RemoveAllBlockArrayNames ()
void SetBlockLookupTable (vtkScalarsToColors *lut)
 Set the look up table for a single block. More...
void RemoveAllBlockLookupTables ()
virtual void SetEnableScaling (int v)
 For OSPRay controls sizing of implicit spheres (points) and cylinders (lines) More...
virtual void SetScalingArrayName (const char *)
virtual void SetScalingFunction (vtkPiecewiseFunction *pwf)
virtual void SetUseDataPartitions (bool)
 Specify whether or not to redistribute the data. More...
virtual bool GetUseDataPartitions ()
virtual void SetUseShaderReplacements (bool)
 Specify whether or not to shader replacements string must be used. More...
virtual bool GetUseShaderReplacements ()
void SetPlaceHolderDataType (int datatype)
 Set/Get the placeholder data type. More...
virtual int GetPlaceHolderDataType ()
virtual void MarkModified ()
virtual bool GetVisibility ()
double GetCacheKey () const
vtkView * GetView () const
bool GetNeedsUpdate ()
 Set the update time. More...
void ResetUpdateTime ()
virtual bool GetSelectable ()
virtual void SelectableOn ()
virtual void SelectableOff ()
vtkTable * GetTableOutput ()
vtkGraph * GetGraphOutput ()
vtkDataObject * GetInput ()
vtkDataObject * GetOutput ()
int HasExecutive ()
int GetNumberOfInputPorts ()
int GetNumberOfOutputPorts ()
void RemoveAllInputs ()
virtual double GetProgress ()
virtual void Update ()
void ReleaseDataFlagOn ()
void ReleaseDataFlagOff ()
int * GetUpdateExtent ()
int GetUpdatePiece ()
int GetUpdatePiece (int port)
int GetUpdateGhostLevel ()
static vtkGlyph3DRepresentation * New ()
static vtkGlyph3DRepresentation * SafeDownCast (vtkObject *o)
- Static Public Member Functions inherited from vtkGeometryRepresentation
static vtkGeometryRepresentation * New ()
static vtkGeometryRepresentation * SafeDownCast (vtkObject *o)
static bool GetBounds (vtkDataObject *dataObject, double bounds[6], vtkCompositeDataDisplayAttributes *cdAttributes)
 Convenience method to get bounds from a dataset/composite dataset. More...
static vtkAlgorithm * New ()
 vtkGlyph3DRepresentation ()
 ~vtkGlyph3DRepresentation () override
void SetupDefaults () override
 This method is called in the constructor. More...
 Subclasses should override this to connect inputs to the internal pipeline as necessary. More...
 Overridden to request single piece from the Glyph source. More...
vtkPVLODActor * GetRenderedProp () override
 Used in ConvertSelection to locate the prop used for actual rendering. More...
void UpdateColoringParameters () override
 Overridden to ensure that the coloring decisions are passed over to the glyph mapper. More...
void ComputeGlyphBounds (double bounds[6])
 Determines bounds using the vtkGlyph3DMapper. More...
- Protected Member Functions inherited from vtkGeometryRepresentation
 vtkGeometryRepresentation ()
 ~vtkGeometryRepresentation () override
void HandleGeometryRepresentationProgress (vtkObject *caller, unsigned long, void *)
void PopulateBlockAttributes (vtkCompositeDataDisplayAttributes *attrs, vtkDataObject *outputData)
 Block attributes in a mapper are referenced to each block through DataObject pointers. More...
void ComputeVisibleDataBounds ()
 Computes the bounds of the visible data based on the block visibilities in the composite data attributes of the mapper. More...
void UpdateShaderReplacements ()
 Update the mapper with the shader replacement strings if feature is enabled. More...
virtual bool NeedsOrderedCompositing ()
 Returns true if this representation has translucent geometry. More...
virtual void SetPointArrayToProcess (int p, const char *val)
 Used by SetNormalArray, SetTCoordArray and SetTangentArray. More...
void UpdateGeneralTextureTransform ()
 This is called whenever the texture transformation matrix changes. More...
 vtkPVDataRepresentation ()
 vtkDataRepresentation ()
 ~vtkDataRepresentation ()
 vtkPassInputTypeAlgorithm ()
 ~vtkPassInputTypeAlgorithm ()
 vtkAlgorithm ()
 ~vtkAlgorithm ()
vtkAlgorithm * GlyphMultiBlockMaker
vtkGlyph3DMapper * GlyphMapper
vtkGlyph3DMapper * LODGlyphMapper
vtkPVLODActor * GlyphActor
vtkArrowSource * DummySource
bool MeshVisibility
- Protected Attributes inherited from vtkGeometryRepresentation
vtkAlgorithm * GeometryFilter
vtkAlgorithm * MultiBlockMaker
vtkGeometryRepresentation_detail::DecimationFilterType * Decimator
vtkGeometryFilterDispatcher * LODOutlineFilter
vtkMapper * Mapper
vtkMapper * LODMapper
vtkPVLODActor * Actor
vtkProperty * Property
char * ActiveAssembly = nullptr
bool RepeatTextures
bool InterpolateTextures
bool UseMipmapTextures
vtkTransform * TextureTransform
double Ambient
double Specular
double Diffuse
int Representation
bool SuppressLOD
bool RequestGhostCellsIfNeeded
double VisibleDataBounds [6]
vtkTimeStamp VisibleDataBoundsTime
vtkPiecewiseFunction * PWF
bool UseDataPartitions
bool UseShaderReplacements
std::string ShaderReplacementsString
bool BlockAttrChanged = false
vtkTimeStamp BlockAttributeTime
bool UpdateBlockAttrLOD = false
int PlaceHolderDataType = VTK_PARTITIONED_DATA_SET_COLLECTION
std::vector< std::string > BlockSelectors
 Configurable through vtkGeometryRepresentation API. More...
std::vector< std::pair< std::string, vtkVector3d > > BlockColors
std::vector< std::pair< std::string, double > > BlockOpacities
std::vector< std::pair< std::string, bool > > BlockInterpolateScalarsBeforeMapping
std::vector< std::pair< std::string, int > > BlockColorModes
std::vector< std::pair< std::string, std::pair< int, std::string > > > BlockArrayNames
std::vector< vtkScalarsToColors * > BlockLookupTables
std::vector< std::pair< std::string, bool > > BlockScalarVisibilities
 Configured internally in vtkGeometryRepresentation. More...
std::vector< std::pair< std::string, bool > > BlockUseLookupTableScalarRanges
std::vector< std::pair< vtkDataObject *, vtkIdType > > BlockFieldDataTupleIds
double UpdateTime
bool UpdateTimeValid
unsigned int UniqueIdentifier
bool Selectable
int SelectionType
Command * Observer
vtkInformation * Information
double Progress
char * ProgressText
unsigned long ErrorCode
 SINGLE_PRECISION
 DOUBLE_PRECISION
 DEFAULT_PRECISION
int AbortExecute
Note that vtkGlyph3DRepresentation requires that the "glyph" source data is available on all rendering processes.
Definition at line 21 of file vtkGlyph3DRepresentation.h.
Definition at line 25 of file vtkGlyph3DRepresentation.h.
◆ vtkGlyph3DRepresentation()
vtkGlyph3DRepresentation::vtkGlyph3DRepresentation ( )
◆ ~vtkGlyph3DRepresentation()
vtkGlyph3DRepresentation::~vtkGlyph3DRepresentation ( )
static vtkGlyph3DRepresentation* vtkGlyph3DRepresentation::New ( )
virtual const char* vtkGlyph3DRepresentation::GetClassName ( )
Reimplemented from vtkGeometryRepresentation.
static int vtkGlyph3DRepresentation::IsTypeOf ( const char *  type)
virtual int vtkGlyph3DRepresentation::IsA ( const char *  type)
static vtkGlyph3DRepresentation* vtkGlyph3DRepresentation::SafeDownCast ( vtkObject *  o)
void vtkGlyph3DRepresentation::PrintSelf ( ostream &  os,
◆ ProcessViewRequest()
int vtkGlyph3DRepresentation::ProcessViewRequest ( vtkInformationRequestKey *  request_type,
vtkInformation *  inInfo,
vtkInformation *  outInfo
◆ SetMeshVisibility()
void vtkGlyph3DRepresentation::SetMeshVisibility ( bool  visible)
If this->GetVisibility() is false, then this has no effect.
◆ SetVisibility()
void vtkGlyph3DRepresentation::SetVisibility ( bool  )
When the visibility of representation of false, all view passes are ignored.
◆ SetMaskArray()
void vtkGlyph3DRepresentation::SetMaskArray ( const char *  val)
◆ SetScaleArray()
void vtkGlyph3DRepresentation::SetScaleArray ( const char *  val)
◆ SetOrientationArray()
void vtkGlyph3DRepresentation::SetOrientationArray ( const char *  val)
◆ SetSourceIndexArray()
void vtkGlyph3DRepresentation::SetSourceIndexArray ( const char *  val)
◆ SetScaling()
void vtkGlyph3DRepresentation::SetScaling ( bool  val)
◆ SetScaleMode()
void vtkGlyph3DRepresentation::SetScaleMode ( int  val)
◆ SetScaleFactor()
void vtkGlyph3DRepresentation::SetScaleFactor ( double  val)
◆ SetOrient()
void vtkGlyph3DRepresentation::SetOrient ( bool  val)
◆ SetOrientationMode()
void vtkGlyph3DRepresentation::SetOrientationMode ( int  val)
◆ SetMasking()
void vtkGlyph3DRepresentation::SetMasking ( bool  val)
◆ SetSourceIndexing()
void vtkGlyph3DRepresentation::SetSourceIndexing ( bool  val)
◆ SetUseSourceTableTree()
void vtkGlyph3DRepresentation::SetUseSourceTableTree ( bool  val)
◆ SetUseCullingAndLOD()
void vtkGlyph3DRepresentation::SetUseCullingAndLOD ( bool  val)
◆ SetNumberOfLOD()
void vtkGlyph3DRepresentation::SetNumberOfLOD ( int  val)
◆ SetLODDistanceAndTargetReduction()
void vtkGlyph3DRepresentation::SetLODDistanceAndTargetReduction ( int  index,
float  dist,
float  reduc
◆ SetColorByLODIndex()
void vtkGlyph3DRepresentation::SetColorByLODIndex ( bool  val)
◆ SetInterpolateScalarsBeforeMapping()
void vtkGlyph3DRepresentation::SetInterpolateScalarsBeforeMapping ( int  val)
◆ SetLookupTable()
void vtkGlyph3DRepresentation::SetLookupTable ( vtkScalarsToColors *  val)
◆ SetMapScalars()
void vtkGlyph3DRepresentation::SetMapScalars ( int  val)
0 maps to VTK_COLOR_MODE_DIRECT_SCALARS 1 maps to VTK_COLOR_MODE_MAP_SCALARS
See also
vtkScalarsToColors::MapScalars
◆ SetStatic()
void vtkGlyph3DRepresentation::SetStatic ( int  val)
See also
◆ SetOrientation()
void vtkGlyph3DRepresentation::SetOrientation ( double  ,
double  ,
double
◆ SetOrigin()
void vtkGlyph3DRepresentation::SetOrigin ( double  ,
double  ,
double
◆ SetPickable()
void vtkGlyph3DRepresentation::SetPickable ( int  val)
◆ SetPosition()
void vtkGlyph3DRepresentation::SetPosition ( double  ,
double  ,
double
◆ SetScale()
void vtkGlyph3DRepresentation::SetScale ( double  ,
double  ,
double
◆ SetTexture()
void vtkGlyph3DRepresentation::SetTexture ( vtkTexture *  )
◆ SetUserTransform()
void vtkGlyph3DRepresentation::SetUserTransform ( const double  [16])
◆ SetCoordinateSystem()
void vtkGlyph3DRepresentation::SetCoordinateSystem ( int  )
◆ SetupDefaults()
void vtkGlyph3DRepresentation::SetupDefaults ( )
overrideprotectedvirtual
If the subclasses override any of the iVar vtkObject's of this class e.g. the Mappers, GeometryFilter etc., they should call this method again in their constructor. It must be totally safe to call this method repeatedly.
◆ FillInputPortInformation()
int vtkGlyph3DRepresentation::FillInputPortInformation ( int  port,
vtkInformation *  info
Fill input port information.
◆ RequestData()
int vtkGlyph3DRepresentation::RequestData ( vtkInformation *  ,
vtkInformationVector **  ,
Since most representations are "meta-filters" (i.e. filters containing other filters), you should create shallow copies of your input before connecting to the internal pipeline. The convenience method GetInternalOutputPort will create a cached shallow copy of a specified input for you. The related helper functions GetInternalAnnotationOutputPort, GetInternalSelectionOutputPort should be used to obtain a selection or annotation port whose selections are localized for a particular input data object.
◆ RequestUpdateExtent()
int vtkGlyph3DRepresentation::RequestUpdateExtent ( vtkInformation *  request,
◆ AddToView()
bool vtkGlyph3DRepresentation::AddToView ( vtkView *  view)
◆ RemoveFromView()
bool vtkGlyph3DRepresentation::RemoveFromView ( vtkView *  view)
◆ GetRenderedProp()
vtkPVLODActor* vtkGlyph3DRepresentation::GetRenderedProp ( )
inlineoverrideprotectedvirtual
Definition at line 122 of file vtkGlyph3DRepresentation.h.
◆ UpdateColoringParameters()
void vtkGlyph3DRepresentation::UpdateColoringParameters ( )
◆ ComputeGlyphBounds()
void vtkGlyph3DRepresentation::ComputeGlyphBounds ( double  bounds[6])
◆ GlyphMultiBlockMaker
vtkAlgorithm* vtkGlyph3DRepresentation::GlyphMultiBlockMaker
Definition at line 135 of file vtkGlyph3DRepresentation.h.
◆ GlyphMapper
vtkGlyph3DMapper* vtkGlyph3DRepresentation::GlyphMapper
Definition at line 137 of file vtkGlyph3DRepresentation.h.
◆ LODGlyphMapper
vtkGlyph3DMapper* vtkGlyph3DRepresentation::LODGlyphMapper
Definition at line 138 of file vtkGlyph3DRepresentation.h.
◆ GlyphActor
vtkPVLODActor* vtkGlyph3DRepresentation::GlyphActor
Definition at line 140 of file vtkGlyph3DRepresentation.h.
◆ DummySource
vtkArrowSource* vtkGlyph3DRepresentation::DummySource
Definition at line 141 of file vtkGlyph3DRepresentation.h.
◆ MeshVisibility
bool vtkGlyph3DRepresentation::MeshVisibility
Definition at line 143 of file vtkGlyph3DRepresentation.h.
