Public Member Functions | Static Public Member Functions | Protected Member Functions | Friends | List of all members
pqTabbedMultiViewWidget::pqTabWidget Class Reference
Internal class used as the TabWidget. More...
#include <pqTabbedMultiViewWidget.h>
Inherits QTabWidget.
 pqTabWidget (QWidget *parentWdg=nullptr)
 ~pqTabWidget () override
virtual void setTabButton (int index, QTabBar::ButtonPosition position, QWidget *wdg)
 Set a button to use on the tab bar. More...
virtual int tabButtonIndex (QWidget *wdg, QTabBar::ButtonPosition position) const
 Given the QWidget pointer that points to the buttons (popout or close) in the tabbar, this returns the index of that that the button corresponds to. More...
virtual int addAsTab (pqMultiViewWidget *wdg, pqTabbedMultiViewWidget *self)
 Add a pqTabbedMultiViewWidget instance as a new tab. More...
void setReadOnly (bool val)
 When true the widget disable changes to the tabs i.e adding/removing tabs by user interaction. More...
bool readOnly () const
QSize preview (const QSize &)
 Enter/exit preview mode. More...
void setTabBarVisibility (bool)
 Get/Set tab bar visibility. More...
bool tabBarVisibility () const
static QString popoutLabelText (bool popped_out)
 Returns the label/tooltip to use for the popout button given the popped_out state. More...
static QStyle::StandardPixmap popoutLabelPixmap (bool popped_out)
 Returns the icon to use for the popout button given the popped_out state. More...
void createViewSelectorTabIfNeeded (int tabIndex)
Friends
class pqTabbedMultiViewWidget
Definition at line 213 of file pqTabbedMultiViewWidget.h.
◆ pqTabWidget()
pqTabbedMultiViewWidget::pqTabWidget::pqTabWidget ( QWidget *  parentWdg = nullptr)
◆ ~pqTabWidget()
pqTabbedMultiViewWidget::pqTabWidget::~pqTabWidget ( )
override
◆ setTabButton()
virtual void pqTabbedMultiViewWidget::pqTabWidget::setTabButton ( int  index,
QWidget *  wdg
◆ tabButtonIndex()
virtual int pqTabbedMultiViewWidget::pqTabWidget::tabButtonIndex ( QWidget *  wdg,
) const
◆ addAsTab()
virtual int pqTabbedMultiViewWidget::pqTabWidget::addAsTab ( pqMultiViewWidget *  wdg,
pqTabbedMultiViewWidget *  self
This will setup the appropriate tab-bar for this new tab (with 2 buttons for popout and close).
◆ popoutLabelText()
static QString pqTabbedMultiViewWidget::pqTabWidget::popoutLabelText ( bool  popped_out)
◆ popoutLabelPixmap()
static QStyle::StandardPixmap pqTabbedMultiViewWidget::pqTabWidget::popoutLabelPixmap ( bool  popped_out)
◆ setReadOnly()
void pqTabbedMultiViewWidget::pqTabWidget::setReadOnly ( bool  val)
◆ readOnly()
bool pqTabbedMultiViewWidget::pqTabWidget::readOnly ( ) const
inline
Definition at line 258 of file pqTabbedMultiViewWidget.h.
◆ preview()
QSize pqTabbedMultiViewWidget::pqTabWidget::preview ( const QSize &  )
◆ setTabBarVisibility()
void pqTabbedMultiViewWidget::pqTabWidget::setTabBarVisibility ( bool  )
Use this instead of directly calling this->tabBar()->setVisible() as that avoid interactions with preview mode.
◆ tabBarVisibility()
bool pqTabbedMultiViewWidget::pqTabWidget::tabBarVisibility ( ) const
inline
Definition at line 272 of file pqTabbedMultiViewWidget.h.
◆ createViewSelectorTabIfNeeded()
void pqTabbedMultiViewWidget::pqTabWidget::createViewSelectorTabIfNeeded ( int  tabIndex)
◆ pqTabbedMultiViewWidget
friend class pqTabbedMultiViewWidget
friend
Definition at line 281 of file pqTabbedMultiViewWidget.h.
