#include <vtkPVMessage.pb.h>
Inherits Message.
| enum | : int { kGroupFieldNumber = 1, kNameFieldNumber = 2, kXmlFieldNumber = 3 } |
| ProxyDefinitionState_ProxyXMLDefinition () | |
| ~ProxyDefinitionState_ProxyXMLDefinition () override | |
| constexpr | ProxyDefinitionState_ProxyXMLDefinition (::PROTOBUF_NAMESPACE_ID::internal::ConstantInitialized) |
| ProxyDefinitionState_ProxyXMLDefinition (const ProxyDefinitionState_ProxyXMLDefinition &from) | |
| ProxyDefinitionState_ProxyXMLDefinition (ProxyDefinitionState_ProxyXMLDefinition &&from) noexcept | |
| ProxyDefinitionState_ProxyXMLDefinition & | operator= (const ProxyDefinitionState_ProxyXMLDefinition &from) |
| ProxyDefinitionState_ProxyXMLDefinition & | operator= (ProxyDefinitionState_ProxyXMLDefinition &&from) noexcept |
| const ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet & | unknown_fields () const |
| inline ::PROTOBUF_NAMESPACE_ID::UnknownFieldSet * | mutable_unknown_fields () |
| void | Swap (ProxyDefinitionState_ProxyXMLDefinition *other) |
| void | UnsafeArenaSwap (ProxyDefinitionState_ProxyXMLDefinition *other) |
| ProxyDefinitionState_ProxyXMLDefinition * | New (::PROTOBUF_NAMESPACE_ID::Arena *arena=nullptr) const final |
| void | CopyFrom (const ProxyDefinitionState_ProxyXMLDefinition &from) |
| void | MergeFrom (const ProxyDefinitionState_ProxyXMLDefinition &from) |
| PROTOBUF_ATTRIBUTE_REINITIALIZES void | Clear () final |
| bool | IsInitialized () const final |
| size_t | ByteSizeLong () const final |
| const char * | _InternalParse (const char *ptr, ::PROTOBUF_NAMESPACE_ID::internal::ParseContext *ctx) final |
| uint8_t * | _InternalSerialize (uint8_t *target, ::PROTOBUF_NAMESPACE_ID::io::EpsCopyOutputStream *stream) const final |
| int | GetCachedSize () const final |
| const ::PROTOBUF_NAMESPACE_ID::Message::ClassData * | GetClassData () const final |
| ::PROTOBUF_NAMESPACE_ID::Metadata | GetMetadata () const final |
| bool | has_group () const |
| void | clear_group () |
| const std::string & | group () const |
| template<typename ArgT0 = const std::string&, typename... ArgT> | |
| void | set_group (ArgT0 &&arg0, ArgT... args) |
| std::string * | mutable_group () |
| PROTOBUF_NODISCARD std::string * | release_group () |
| void | set_allocated_group (std::string *group) |
| bool | has_name () const |
| void | clear_name () |
| const std::string & | name () const |
| void | set_name (ArgT0 &&arg0, ArgT... args) |
| std::string * | mutable_name () |
| PROTOBUF_NODISCARD std::string * | release_name () |
| void | set_allocated_name (std::string *name) |
| bool | has_xml () const |
| void | clear_xml () |
| const std::string & | xml () const |
| void | set_xml (ArgT0 &&arg0, ArgT... args) |
| std::string * | mutable_xml () |
| PROTOBUF_NODISCARD std::string * | release_xml () |
| void | set_allocated_xml (std::string *xml) |
| template<typename ArgT0 , typename... ArgT> | |
| PROTOBUF_ALWAYS_INLINE void | set_group (ArgT0 &&arg0, ArgT... args) |
| PROTOBUF_ALWAYS_INLINE void | set_name (ArgT0 &&arg0, ArgT... args) |
| PROTOBUF_ALWAYS_INLINE void | set_xml (ArgT0 &&arg0, ArgT... args) |
| static const ::PROTOBUF_NAMESPACE_ID::Descriptor * | descriptor () |
| static const ::PROTOBUF_NAMESPACE_ID::Descriptor * | GetDescriptor () |
| static const ::PROTOBUF_NAMESPACE_ID::Reflection * | GetReflection () |
| static const ProxyDefinitionState_ProxyXMLDefinition & | default_instance () |
| static const ProxyDefinitionState_ProxyXMLDefinition * | internal_default_instance () |
Static Public Attributes | |
| static constexpr int | kIndexInFileMessages |
| static const ClassData | _class_data_ |
| ProxyDefinitionState_ProxyXMLDefinition (::PROTOBUF_NAMESPACE_ID::Arena *arena, bool is_message_owned=false) | |
Friends | |
| class | ::PROTOBUF_NAMESPACE_ID::internal::AnyMetadata |
| template<typename T > | |
| class | ::PROTOBUF_NAMESPACE_ID::Arena::InternalHelper |
| struct | ::TableStruct_vtkPVMessage_2eproto |
| void | swap (ProxyDefinitionState_ProxyXMLDefinition &a, ProxyDefinitionState_ProxyXMLDefinition &b) |
Definition at line 2767 of file vtkPVMessage.pb.h.
| anonymous enum : int |
| Enumerator | |
| kGroupFieldNumber | |
| kNameFieldNumber | |
| kXmlFieldNumber | |
Definition at line 2895 of file vtkPVMessage.pb.h.
Definition at line 2770 of file vtkPVMessage.pb.h.
explicit |
| paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::ProxyDefinitionState_ProxyXMLDefinition | ( | const ProxyDefinitionState_ProxyXMLDefinition & | from | ) |
inlinenoexcept |
Definition at line 2775 of file vtkPVMessage.pb.h.
explicitprotected |
Definition at line 2780 of file vtkPVMessage.pb.h.
inlinenoexcept |
Definition at line 2784 of file vtkPVMessage.pb.h.
Definition at line 2798 of file vtkPVMessage.pb.h.
Definition at line 2801 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 2805 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 2808 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 2811 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 2814 of file vtkPVMessage.pb.h.
inlinestatic |
Definition at line 2817 of file vtkPVMessage.pb.h.
Definition at line 2827 of file vtkPVMessage.pb.h.
Definition at line 2840 of file vtkPVMessage.pb.h.
inlinefinal |
Definition at line 2848 of file vtkPVMessage.pb.h.
| void paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::CopyFrom | ( | const ProxyDefinitionState_ProxyXMLDefinition & | from | ) |
| void paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::MergeFrom | ( | const ProxyDefinitionState_ProxyXMLDefinition & | from | ) |
final |
final |
final |
final |
final |
inlinefinal |
Definition at line 2865 of file vtkPVMessage.pb.h.
final |
final |
Definition at line 6129 of file vtkPVMessage.pb.h.
Definition at line 6132 of file vtkPVMessage.pb.h.
Definition at line 6136 of file vtkPVMessage.pb.h.
| void paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::set_group | ( | ArgT0 && | arg0, |
| ArgT... | args | ||
Definition at line 6147 of file vtkPVMessage.pb.h.
Definition at line 6163 of file vtkPVMessage.pb.h.
Definition at line 6177 of file vtkPVMessage.pb.h.
Definition at line 6198 of file vtkPVMessage.pb.h.
Definition at line 6201 of file vtkPVMessage.pb.h.
Definition at line 6205 of file vtkPVMessage.pb.h.
| void paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::set_name | ( | ArgT0 && | arg0, |
| ArgT... | args | ||
Definition at line 6216 of file vtkPVMessage.pb.h.
Definition at line 6232 of file vtkPVMessage.pb.h.
Definition at line 6246 of file vtkPVMessage.pb.h.
Definition at line 6267 of file vtkPVMessage.pb.h.
Definition at line 6270 of file vtkPVMessage.pb.h.
Definition at line 6274 of file vtkPVMessage.pb.h.
| void paraview_protobuf::ProxyDefinitionState_ProxyXMLDefinition::set_xml | ( | ArgT0 && | arg0, |
| ArgT... | args | ||
Definition at line 6285 of file vtkPVMessage.pb.h.
Definition at line 6301 of file vtkPVMessage.pb.h.
Definition at line 6315 of file vtkPVMessage.pb.h.
Definition at line 6142 of file vtkPVMessage.pb.h.
Definition at line 6211 of file vtkPVMessage.pb.h.
Definition at line 6280 of file vtkPVMessage.pb.h.
friend |
Definition at line 2874 of file vtkPVMessage.pb.h.
friend |
Definition at line 2961 of file vtkPVMessage.pb.h.
friend |
Definition at line 2969 of file vtkPVMessage.pb.h.
friend |
Definition at line 2824 of file vtkPVMessage.pb.h.
Definition at line 2821 of file vtkPVMessage.pb.h.
Definition at line 2886 of file vtkPVMessage.pb.h.
